Question about Hotpoint Washing Machines
Hotpoint Ultima WMD940 F-03 showing on display
  • 8,197 Answers
The error code F03 indicates a problem with the pump out of the washer or a failure of the pressure switch that controls the water fill. This is a problem that you should have a technician diagnose and repair.
Good Luck
Please rate FixYa!
Posted on Dec 19, 2008
Hi,how can i reset the language on my wmd960 hotpoint ultima,thanks
1. Switch on the power and when the language is displayed - press the child lock+ temperature+ spin buttons simultaneously for about 5 seconds. Release the child lock button when other languages appear. Scroll down using temperature button-until English is dispalyed. Select using child lock button.
Jan 14, 2011 | Hotpoint Ultima WF860 Front Load Washer
On the digital display it is coming up F-01 on my hotpoint ultima WD 860
F01: Aquarius and Ultima models may show this. It could be a faulty motor or motor control board. The motor tachometer could also be faulty. Some machines have a little rotating magnet and sensor, and the magnet can become detached (not sure about these though on this model). NOTE: if this code is not constant, and tending to come up during spin, check the drive belt for wear or slack, and check the motor brushes.
Jan 28, 2010 | Hotpoint Washing Machines
Hotpoint Ultima Super Silent. Was & Dry
High Temperature Rise in Drying:
check fan motor & filter for blockage. basically a reduced airflow within drum unit
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
When I start a program, It displays
try this - press start, press start again. Now press the on/off button and the start button at the same time and hold them down for 5-10 seconds until the display shows d-end or d-off.
Oct 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT WF840P SHOWS TEST IN DISPLAY AND WILL NOT OPERATE
turn on while pressing the on and start buttons at the same time until 'dOFF' appears.
Feb 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
Test
Hi i have a hotpoint wd 860 washer dryer the display is showing f 08 heater relay cannot be activated.can you please tell me how i can fix this problem myself.Thank You
Jan 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have an e15 code on the lcd display
Are you sure it is E15 and not F15?
F15 on an lcd display washer/dryer indicates dryer element faulty. this being the case then it will probably require a new element fitting.
Hope this helps
Dec 05, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Washing Machines Logo
463 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
