Question about HP Pavilion dv6000z Notebook
Heating problem The fan of laptop has stopped due to that laptop's temprature is rised above 80 degrees .So plz tell me If i want to replace the fan ,how much it will be take ? thanx
  • 60 Answers
Does the fan acctually work when you first turn your lappy on?
Posted on Dec 19, 2008
Need settings for limit/fan control switch
Possibly it had the 70 on it and someone bumped it up already. I'm uncertain, I'm a straight cool/ minimal heat pump tech in SWFL. I am certain 10 degrees isn't hurting anything, replace with what is in there.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 24, 2017 | Heating & Cooling
How water temprature not going above 55.
Unknown what product you have.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Add a comment and describe product in detail
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 07, 2013 | Water Heaters
I have a 16 SEER Goodman air conditioner and during the morning hours, temperature ranging 75 degrees outside, the compressor comes on but not the outside fan. It only runs for a minute and a half then...
The fan is shutting off in order to maintain head pressure when the outdoor temperature is low. This is common on 16 seer and above systems. It helps your system be more efficient.
Jun 06, 2011 | Goodman Heating & Cooling
Hi: Last week, a contractor installed the above-mentioned new 16 seer heat pump, an air handler and a heat kit. Our house has 3 levels, each about 800 square fit. Initially the house would not heat above...
That is worrysome about putting refrigerant in hap hazzardly... There is a math style process involving pressures and temperatures in two locations that dictate how much ref. goes in. Anything else shows clueless installer. Too much or too little ref. will not work correctly.
Heat pumps do not work below about 33 degrees outside temp. Above that them, aux heat should not be coming on...
You would need to verify that the system you have is rated for the space that you are trying to heat...
Heat pumps heat more slowly than gas or electric, so using set back thermostat is not recommended. True economy comes from maintaining constant temprature. System has to work to hard to raise the temprature, and eats up savings in efficiency by allowing temp set back.
Feb 14, 2011 | Heating & Cooling
My 01' Jetta over heats while driving...1 fan doesn't turn on.
Check that the other fan will run if power applied directly to it.
From wiring diagram, it shows both fans are wired in parrallel- thus should run together.
Sep 21, 2009 | 2001 Volkswagen Jetta TDI
The computer is an acer 5630 laptop. Before i changed the motherboard I would turn on the laptop and five seconds later The fan would shut off and all the lights would stay on. I purchased a motherboard...
fan always start working when u switch on the laptop, then it stop because it monitor your cpu temprature if CPU temp is blow the level of heating then it stay stop and if it exceed the limit of cooling then fan automatically start to just kick out heat of CPU, so it is normal, but tell me did u get display when fan switch off? let me know
Aug 24, 2009 | Computers & Internet
Over heat ?
Normal operating temperature on the bike should not go over 220 degrees F for very long, even in stop & go traffic. Riding down the highway on a hot day you might be 190 F. At start up there won't be a reading until the sensor gets over the minimum which is probably around 100 degrees. You should be able to see it rise after a minute or so of idling. You should hear your fan come on around 190-200 degrees. Your thermostat probably opens at 180, allowing coolant to flow through the radiator and if that does not cool the bike enough the fan comes on next.
Apr 28, 2009 | 2006 kawasaki ZX-6R
Robertshaw 9600: Temperature rises too high, fan doesn't stop.
It sounds like the thermostat is wired improperly. One quick was to check is by finding breaker to unit and shutting off power. Go to thermostat and remove from wall take all wires off thermostat besides wire going to R(might be RcandRh) and C(which is common) Tape all bare wires removed with electrical tape. Now go back to the breaker and turn power back on. Nothing should be running at all. Take a voltage meter and measure the voltage from R to W(which is heating). If you read 24V then the thermostat is open and not calling for heat. Now turn the thermostat up so it is calling for heat. You should read 0V from R to W. If this checks out your thermostat is probally fine. You can check the fan the same way by going from R to G. In auto you shoul read 24V from R to G and in th on postion you will read 0V from R to G. If the thermostat checks out then the problem is probably at the furnace or rooftop. Either with the thermostat wiring or the main board acting up
Jan 19, 2009 | Heating & Cooling
Over heat of vw polo
Hi, Try turning on blower, set to warmest setting.
If the blower is blowing cold air, the problem could be Water Pump needs replacing!
Sep 06, 2008 | 2001 Volkswagen Golf
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
