Question about Frigidaire FullFGX831C Size Stack Gas Laundry Center
Dryer spins but does not heat
When I try to dry a load of clothes on high heat, the dryer does not heat but does spin. I have made sure the breakers are fully on for the outlet and there has been no change to the gas valve and it is on.
  • Anonymous Mar 28, 2014
    drum spins but clothes don't dry
  • 5,911 Answers
It sounds like to have a bad igniter. In order for your dryer's gas valve to open,the igniter has to be functioning properly. This is a built in safety feature to prevent gas from flowing without ignition. The igniter is located inside the machine usually under the drum near the gas valve. If you can access the inside look for a glow after you push the start button. If there's no glow, your igniter is bad. I hope this helps.
Posted on Apr 29, 2007
Dryer is taking a longer time than normal to dry unless we switch it to timer. Replace sensors?
  • Remove and clean the lint filter each time it is used. The filter can be washed with warm soapy water to remove fabric softener residue from the screen.
  • Check the household fuses and circuit breakers. Most household dryers use two fuses or circuit breakers. It is possible for only one of them to trip and the dryer still tumble, but not heat.
  • The washer controls may have been improperly set. If the clothes are wetter than normal, coming from the washer, this could be the difficulty. If the gentle speed is selected for a normal load the washer will not spin adequately. High speed or extended spin removes more water from clothing decreasing drying time
A lint filter that is full of lint will restrict airflow and lengthen dry times. To keep your dryer working correctly, clean out the lint folder after each and every use. Check the lint filter for any buildup of fabric softener that will restrict airflow and wash with soapy water to clean. If the filter is damaged then replace it.
Nov 09, 2017 | Dryers
My dryer is Tcm570 it started leaking water on the floor while clothes are drying, then not drying after circulation. But if I try to put it on now it turns all the power in the house off. What's
There are a lot of parts to this problem: First don't plug it in again or try to restart it...yet, Make sure before you reset the circuit breaker that you unplug the dryer. So now your home should be fine! The dryer is another story... I have answered this problem for others and with other dryers... Please focus on your washer, there should be very little water that remains in your clothes after the wash cycle and the clothes should Definitely not be dripping. Check to see that your spin cycle is working and if necessary run it through the spin cycle again. You may be overloading the washer. Back to the dryer...NO water should EVER drip from a dryer! If you do not wish to call a service person I would wait about 1 1/2 weeks for the dryer to dry itself and give the dryer another try after that and set it for Air dry only (no heat) if you don't have a problem at that point then stop the dryer and set it for a low heat cycle and try again. I think at that point you should be OK? If you do have problems.. you will have to call in a service person. But please remember clothes should be quite dry coming from the washer before going into the dryer.
Jan 12, 2013 | Dryers
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Dryer is Electric. spins clothes but no heat?
What is the setting on for example towels,check lint trap in back when dryer turns does the back of drum turn red,look through door and watch. If you still don't feel heat its the coil,It should be under warrenty.
Jul 26, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryer is spinning and working fine, just no heat to dry the clothes?
Hello Could be sevral things the motor that sopins the dryer and the control are 110 volt the heal element is 220 volt if you blew half the breaker you can get spin and no heat. If it is not the breaker it could be a bad element or a senso which would require a repairman
Jun 23, 2009 | GE Dryers
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Will not dry clothes,blows cold air.
need brand.most dryers have thermal fuse that protect the element from going bad.I would first check your breaker and make sure it isnt tripped.a dryer will run but not heat if breaker is tripped.
Mar 10, 2009 | Dryers
Estate Dryer takes too long to dry load
Since you say the vent is clear, Make sure that the lint filter is cleared before each load. Make sure the door shuts close and is reasonably sealed. If the dryer draws air past the door, it is not fully drawing heat from the element or burner. Also make sure the washer is doing it's job in the spin cycle. It takes much longer to dry fabrics that are still soppy wet. You might try resetting the washer in the spin cycle to further evacuate the water from the clothes before placing in the dryer. See if that makes a difference. Maybe the washer spin is just being lazy. If it's a top loader it may have a loose belt causing the problem.
Dec 16, 2008 | Estate Dryers
The dryer heats up & spins,clothes don't dry,lint areas are now clean
restriction in your vent check it from the back of the dryer it must be 4 inches in dia and clear get a flashlight and look behind the dryer see if its mashed coiled or folded check the dryer hood make sure if there is a bird screen on it its clear easy way to tell if vent is at fault disconnect from dryer and do a load then let me know
Jun 05, 2008 | Roper REX5635E Dryer
Frigidaire FullFGX831C Size Stack Gas Laundry Center Logo
142 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
