Question about Philips SA3025/37 Flash MP3 Player
My philips gogear sa3025/37 wont work
It wont turn on, my computer (mac) wont recognise it, and it wont charge up at all on my mac. how do i fix it?
  • sweetbabygur Jan 01, 2009
    I HAVE THE EXACT SAME PROBLEM IT WONT COME ON AT ALL. MY COMPUTER WONT EVEN READ IT OR CHARGE IT
  • 8,596 Answers
The SA3025 is not compatible with Macintosh. It will show up as "Internal" or some such, but you won't be able to load the songs into there properly. That is why the documentation says:
System requirements
• Windows® 2000, XP, Vista
-Tha Mp3 Doctor
Posted on Mar 06, 2009
My gogear does not recognize by my computer what should i do
What should I do if my player is not recognized by my PC?
Reset it. Use a pen tip in the RESET hole on the side of the player.
Connect the player to the PC to see whether the player is recognized.
Faulty USB port, try connecting the player to another USB port (or try another computer).
Is your computer Mac or Windows? eg Mac OS 10.7.2 had issues recognising media players that could be fixed by resetting PRAM.
Install Philips Songbird software and try Repair mode. Note this will delete files on the player.
Philips GoGEAR MP3 player SA2RGA04KS RaGa 4GB with FullSound
Sep 19, 2012 | Philips Gogear SA2RGA04KS Mp3 Video Player
My computer doesn't recognise my gogear, how do i charge it?
Your computer must have, the service pack 2, if not, you can´t charge your reproducer.
Dec 12, 2008 | Philips GOGEAR SA6045 MP3 Player
Phillips gogear sa6185
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Oct 24, 2008 | Philips GoGear HDD075/17 MP3 Player
player says i should not connect and then that detachment is ok.
Oct 22, 2008 | Philips GOGEAR SA6045 MP3 Player
MY PHILIPS MP3 WONT TURN ON !!!!!!!GRRRRR I NEED HELPPPPPP!!!!PLIZZ
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Apr 04, 2008 | Philips SA5125/37 MP3 Player
Wont stay turned on.
1) Make sure the usb charger is in the lock position before trying to charge.
2) Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
3) after repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
-Tha Mp3 Doctor
Feb 07, 2008 | Philips GoGear SA178 MP3 Player
Please connect to pc
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Dec 29, 2007 | Philips GoGear HDD1850 MP3 Player
Phillips GoGear not turning on
-Tha Mp3 Doctor
Nov 29, 2007 | Philips GoGear HDD6330 MP3 Player
My Phillips GoGear 30GB wont turn on
omg mine did the same thing. such a rip off :(
Oct 13, 2007 | Philips GoGear HDD6330 MP3 Player
Philips SA3025/37 Flash MP3 Player Logo
610 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
