Question about Yamaha YHT-690 Theater System
All speakers not working
So i can get the front two to work at one time, the back two at one time, and the center by itself at one time, but i cannot get all of them to work at the same time, i can either just get the two front,back, or center to work.
How do i get all of them to work at the same time?
5 Suggested Answers
  • 93 Answers
SOURCE: Curtis dvd5029 home theater system only plays right front and center speaker
Some DVD players in SETUP MENU need to select AUDIO OUTPUT (i.e. STEREO 2 ch - SURR 5.1 - SUB ON/OFF etc.). Check this for start.
Posted on Oct 04, 2007
SOURCE: suround speakers and center speaker is not working
Well you can change the setting to hear from different speakers. Play with it you will hear the front on one setting then all 5 on another
Posted on Feb 29, 2008
Midwest-tech
  • 243 Answers
SOURCE: No sound coming out of Center, left and right front speakers
make sure you didnt turn off speaker set A on the reciever. cause from what i can tell from the manual you may have hit a button to turn them off. now on your reciever look below the power button on the unit itself. below that is a speaker A/B push the A button to make sure its on or the B depending how your speakers are rigged. if this isnt the problem let me know and i can help you with another solution -Nate
Posted on Jun 14, 2008
  • 5 Answers
SOURCE: My center ,subwoofer and back
defective speakers or defective right and left amplifiers
Posted on Nov 20, 2010
Only my front dash speaker and my sub works. none of the door speakers work
It would be helpful to know what vehicle these speakers are in? But just guessing I would suggest checking your crossover.
Feb 01, 2013 | 2004 Cadillac Deville
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Radio only one speaker
It can be the speaker itself or the radio.
Jul 01, 2012 | 1994 Chevrolet C1500
Rear speakers are dead, never got them to work. Changed front to back and rears work so speakers and wireing are good. Is it possible that because I did not hook up a center speaker this is the problem?
if its a 5.1 channels it means 2 front speakers,2 rear speakers or either the center speaker or the subwoofer.try to hook up either center speaker or subwoofer.
Jun 05, 2010 | JVC RX-888V Receiver
Sony HT 6500 receiver...center speaker jack crackles as soon as speaker wire is connected to it. Tried new wire, new speakers...same thing. Tried to reset to factory settings...ONly L and R front speakers...
try to spray contact cleaner into the speaker port itself.. Powered off of course.. let it dry and try again.. this will clean any connectivity issues due to bad contacts.. as far as replacing jacks.. try the suspected "bad" speaker and wiring in another port.. if it works then the speaker and wiring is good and you have to check actual jack in which you were asking and back to auto amplifier circuit or transistors.
Dec 16, 2009 | Sony Audio Players & Recorders
My speakers only work one at a time...
Check you have plugged them into the correct socket on the back of the PC ..
Chances are you have 3 sockets - first = 'front' (or pair), middle = 'back' (for 4+ speaker sets) and last = 'center & sub-woofer' ..
Sounds like you have plugged into the 'center & sub-woofer' socket :-)
Mar 13, 2009 | Dell A215 Computer Speakers
Rear speakers don't work
Speaker test confirms whether the speakers actually work but not the sound level you have them set at. Chack volume level of each speaker. This may be a separate button all itself.
Jan 06, 2009 | Audio Players & Recorders
Center speaker will not work
If you had the Speakers Set to A (not B) and no headphones connected when you pressed the TEST TONE button on the Onkyo HT-R540 (also known as the HTS-790) remote, and you had no sound from the Center Speaker then try the following steps. 1) Check the Center Speaker wiring at both ends under a bright light and make sure that there is not a strand of wire touching the Receiver Chassis or another speaker post. Check both + and - . If that looks okay, 2) unscrew the Center Speaker Post connections on the Receiver and verify that the bare stripped wire is making contact. Often, the insulation is too far into the connector. When screwed down, the wire's insulation is crushed and keeps the bare wire from making contact. If this looks okay and the unit is under Warranty, your last test is to: 3) temporarily swap the wires from the Center Speaker with the Right Front Speaker. Turn the volume down low and try the TEST TONE button again. If you now hear sound from the Center Speaker box itself and none from the Right Speaker box, then the Receiver is the problem. If you still do not hear sound from the Center Speaker box, then the Center speaker itself is defective.
Sep 25, 2007 | Televison & Video
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
Yamaha YHT-690 Theater System Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
