Yahoo mail My computer won't let me send any pictures anymore and I don't know why. It keeps saying log into pop.mail.yahoo.com and asks for user name and password. I put in what I thought it was, but I can't get around it or change it.
Unable to access yahoo.com e-mail account. Keeps asking for my favorite aunt's name. My address is wildgirlginger@yahoo.com
When trying to log in, choose the Lost Password box and wait for a reply from Yahoo to let you in again.
Mar 15, 2014 | Computers & Internet
My yahoo account has been hacked today an email asking for money has been sent to my contact list..I do not know what to do as I have tried to send a email to all of those contacts to say disregard the...
Access your E-mail account from a different computer and then try sending the email to your friends. Your computer is probably infected by an automatic E-mail sending virus/malware. Update your anti-virus software and then do a FULL virus scan of your computer. If you don't have an anti-virus software, you should get one. You can get some for free or free trial. Avast and AVG are highly recommended.
Oct 04, 2011 | yahoo.com
Can I configure microsoft outlook 2007 to work with my yahoo e-mail if i'm connection through clearwire at home and I'm not on a network
If you are not connected to the internet, you can only work offline, and for example, if you write an email it will not send until you do connect to the internet.
You can configure Outlook 2007 to work with Yahoo.
If you want to "POP" your Yahoo! Mail into your Outlook 2007 application, here's how:
  1. From the Tools menu, select "Account Settings." If you do not see "Account Settings," place your cursor over the two arrows at the bottom of the list to display more choices.
  2. On the Email tab, click New.
  3. Check the box next to the first option, "Microsoft Exchange, POP3, IMAP, or HTTP" and click Next.
  4. In the Your Name box, type your name as you'd like it to appear when you send a message.
  5. In the Email Address box, enter your Yahoo! Mail address (for example, "user@yahoo.com").
  6. Check the box for "Manually configure server settings or additional server types" and click Next.
  7. Check the box next to the first option "Internet E-mail" and click Next.
  8. In the Server Information area, under "Account Type" select POP 3 from the pull-down menu.
  9. In the Incoming mail server field, enter: pop.mail.yahoo.com.sg
  10. In the Outgoing mail server (SMTP) field, enter: smtp.mail.yahoo.com.sg
  11. In the Login Information area, in the User Name field, enter your Yahoo! ID (your email address without the "@yahoo.com").
  12. In the Password box, enter your Yahoo! Mail password.
  13. Check "Remember Password" if you don't want Outlook to prompt you for your password each time you check your mail. Handy!
  14. Do not check the box labeled "Log on using Secure Password Authentication (SPA)."
  15. Click on the More Settings button.
  16. Click on the Outgoing Server tab and check the box next to "My outgoing server (SMTP) requires authentication."
  17. Click on the Advanced tab.
  18. Under "Incoming Server (POP3)", check the box next to "This server requires an encrypted connection (SSL)". The port number in the "Incoming Server (POP3)" field should automatically change from 110 to 995. If it doesn't, make sure the port number is set to 995.
  19. Under "Outgoing Server (SMTP)", check the box next to "This server requires an encrypted connection (SSL)". Enter port number "465" in the "Outgoing Server (SMTP)" field.
  20. If you'd like to keep a copy of your email messages on the Yahoo! Mail server, check the box next to "Leave a copy of messages on the server." If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook, don't check the box.
  21. Click the OK button.
  22. Click the Next button on the Email Account Wizard, then click Finished.
  23. Would you like your Yahoo! Mail inbox to be your primary inbox in Outlook 7? If so, click the Tools menu and select "Account Settings." If you don't see "Account Settings," place your cursor over the two arrows at the bottom of the list to display more choices.
  24. From the list, select the pop.yahoo account you've just added and click the Set as Default button.
  25. Click the Close button. You're done!
Troubleshooting instructions
If you followed the above configuration steps, you should be all set. However, if you cannot send or receive mail with your email client, try the following tips.
The Yahoo! Mail SMTP server requires authentication. Make sure you have enabled SMTP authentication. To turn this setting on, follow these steps:
  1. From the Tools menu, choose "Account Settings."
  2. Select the "E-mail" tab.
  3. Select your Yahoo! Mail account and click Change.
  4. Click on the "Outgoing Server" tab.
  5. Check the box next to "My Server Requires Authentication."
  6. Please make sure that "Log on using" is not checked.
  7. Click OK.
To control deletion of messages from the Yahoo! Mail server:
  2. Click on the "Email" tab.
  4. Click on the "Advanced" tab.
  5. Check "Leave a copy of messages on server" if you want to save your Yahoo! Mail messages on the Yahoo! Mail server as well as on your local computer. Please note that setting your email client to remove messages from the server will cause your messages to be deleted from the server. Once the messages are deleted, we are unable to retrieve them.
  6. Click OK.
  7. Close Microsoft Outlook and restart.
We strongly recommend that you enable SSL for both POP and SMTP, as detailed in the above instructions. This will ensure that your Yahoo! ID, password and email messages are transmitted securely between your mail client and the Yahoo! servers. However, if you choose to not use SSL for SMTP, your email client will likely default the SMTP port to 25. If your ISP blocks port 25 or if you're unable to send email, then you will need to use port 587 when sending via Yahoo!'s SMTP server. To make this change, please follow the directions below:
  1. From the "Tools" menu, select "Account Settings"
  2. Select your Yahoo! POP account and click on Change.
  3. Click on the "Advanced" tab.
  4. Click OK and Close.
May 05, 2011 | Microsoft Office Computers & Internet
Please describe your how to configure yahoo mail in micromax 07 problem
GO TO MESSAGES>SETTING>EMAIL SET UP.
NOW SET UP YOUR YAHOO MAIL BY FOLLOWING BELOW MENTION GUIDE.
EMAIL SETUP WIZARD
  • MAILBOX NAME- YAHOOO MAIL
  • EMAIL ADDRESS - YOURNAME@YAHOOMAIL.COM(YOUR EMAIL ADDRESS)
  • OUTGOING MAIL SERVER - smtp.yahoomail.com
  • USERNAME - YOUR USER NAME FOR YAHOO ACCOUNT
  • PASSWORD - YOUR PASSWORD
  • SECURITY PORT- ON(993/995)
  • A POP SECURE LOG IN - OFF
  • INCOMING MAIL SERVER NAME- pop.gmail.com
  • MAILBOX TYPE- POP3
NOW YOUR DONE ENJOY YAHOO MAIL ON MOBILE.
THANKS FOR USING FIXYA.
Mar 10, 2011 | Cell Phones
How do i set up my yahoo email account archos 10.1 internet tablet
Glad to help YOU!
For your tablet, to get Yahoo! mail you have to activate POP setting; to activate pop on your Yahoo!Mail account you have to pay for it.
Now, if you once signed up for Yahoo! Mail Plus, add a new email account to your email program with the following POP and SMTP settings:
1. Yahoo! Mail POP server: plus.pop.mail.yahoo.com
2. POP port: 995
3. POP TLS/SSL: yes
4. POP user name: your Yahoo! ID
5. password: your password
1. Yahoo! Mail SMTP server: plus.smtp.mail.yahoo.com
2. SMTP port: 465
3. SMTP TLS/SSL: yes
4. SMTP user name: your ID
5. SMTP password: your password
In case you will have some errors/problems having such settings you have to:
# Log in to Yahoo! Mail
# select OPTIONS > MAIL OPTIONS > go to POP/FORWARDING > choose VIEW POP on Yahoo!Mail Server.
Hope I was able to help you!
GOOD LUCK!
Mar 08, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
I can't get Outlook set up for my new ymail account. I keep getting asked for my user name and password. Then I get an error message: Task 'plus.pop.mail.yahoo.com - Sending' reported error (0X800CCC92)...
my understanding is that you need to have yave yahoo plus to get this to work, yahoo plus is the paid version for you to have pop access which means be able to use an email client (like outlook) to retrieve yahoo mail there.
now if you have not paid for yahoo plus you can do the following:
1. switch your yahoo account to be localized to asia, which should also (for now) allow you to use pop access on a free yahoo account, you need to look around into the account options (Its under Account Info, Account Settings,Set Language Site and Time Zone or something like that)
2. once 1 has been completed go into yahoo and add your yahoo account, * for logon info use only your yahoo user name (not the @yahoo.com) * enter your correct password *for incoming email server: pop.mail.yahoo.com *for outgoing email server: smtp.mail.yahoo.com
3. go into more settings>advance * incoming server port should be 110 *outgoing server port should be 587
good luck
Dec 19, 2010 | Yahoo Mail
I cant login to yahoo.
why, you can't log in your yahoo, is either your password or user name is not correct or properly entered. So check if you enter the right password or user name to log in. Because there is no way you enter the right user name and password and you can't in.be sure of what detail you use in creating your account.
Jul 20, 2010 | Yahoo Mail
I have yahoo id i wand configure to my outlook express i am getting this error There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server:...
There was a problem logging onto your mail server. Your Password was rejected. Account: 'pop.mail.yahoo.com', Server: 'pop.mail.yahoo.com', Protocol: POP3, Server Response: '-ERR [SYS/PERM] pop not allowed for user.', Port: 995, Secure(SSL): Yes, Server Error: 0x800CCC90, Error Number: 0x800CCC92
make sure your password is correct because this error description states that your password is incorrect
Jul 08, 2009 | Microsoft Outlook Express
I cannot get thunderbird to access my yahoo mail account
Do you have paid membership for the Yahoo services ?
As I know it will be only then available if you have Paid membership.. for free user Yahoo did not provide email Snynchronising with Outlook or Thunderbird.
Nov 11, 2008 | Yahoo Mail
Computers & Internet Logo
18 people viewed this question
Alun Cox
David Payne
David Payne
