Question about Frigidaire Dryers
Frigidaire dryer feq1442e error code 9e, what does it mean?
  • 8,197 Answers
The error code 9E indicates that low voltage is being detected at the control board of the dryer. This could be caused by the following factors:
  • The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
  • Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
  • If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board. (NOTE: The dryer should always be unplugged when accessing internal components.) A loose wire or burned connection in this area could result in this error code.
  • A failed control board could cause this problem.
If you are unable to determine and repair the cause of this problem, I recommend calling a service technician to diagnose and repair your dryer.
Good Luck
Please rate FixYa!
Posted on Dec 19, 2008
Dryer works for 20 sec and then beeps 6 times and stops
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134420600es.pdf
this is a web site with you manuals. check it out and see if this does not get you started.
http://www.frigidaire.com/manuals
here is another with more manuals.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134509400efs.pdf
this one reads the error codes.
Good luck.
May 01, 2010 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire FEQ1442ES dryer beeping three times and flashing lights. How do I stop it. Have removed and cleaned lint screen and the cage.
I have the same problem with the same dryer, but don't know why either. I was reading on one posting that a button might be stuck so the dryer thinks the button is constantly being pressed.
Jan 16, 2010 | Frigidaire FEQ1442ES Electric Dryer
Dryer overheats, already checked venting
Does the unit shut off when it overheats? According to the wiring diagram it could be the Heater Relay or High Limit Thermostat. See the wiring diagram for instructions on error codes and how to obtain them. It is easily found on their website. Hope this helps
Nov 25, 2009 | Frigidaire FEQ1442ES Electric Dryer
Error code 9E What does that mean? Cannot find tech sheet
9E code is a door switch circuit problem.
You can check the wiring and connections and the door switch.
If the problem is not isolated to one or more of these parts then the control board is malfunctioning and must be replaced.
The manual states "unplug the dryer for 1 minute" "reconnect and if the problem re-occurs to check the components.
Maytag has a special circuit board that can be plugged in to evaluate the existing circuit board. Only Maytag certified techs have these test boards, and not all of them have it.
Check your door switch and wires.
The door switch is a inexpensive part compared to the cost of the circuit board. If in doubt, replace the door switch before proceeding.
Door switch part # y305753 and cost about $20.00
Mar 20, 2009 | Maytag Dryers
Dryers Logo
223 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
