FixYa.com
Tags:
H45 Quick DVD External DVD Drive
External dvd drive repair or replace?
posted by 777guitarman on Mar 30, 2007
I have had my drive for years and it is very picky now with blank dvds most of the time it does not even recognize that the dvd in the drive is blank. I'll put a disc in and go to burn a dvd and get the message please insert a blank dvd.
I have over a dozen dvds that are now only good for "frizbies" my burner messed up. Nero gives a write disk-9 error and so does clone DVD. Roxio I have the most success with but this last time I received this new error at 99% burn, it only had 1% left to go!!!! It stopped and said tracking servo error, I looked this up and it seems to be saying I need to realign my drive. Since I know nothing about that, and my drive is old, and may need to be replaced. (By the way cds seems to be no problem so far.)
I was wondering if I could repair this or replace the drive it self with a new internal drive in the old external dvd case maybe?
I haven't much money or experience and would like the easiest and cheapest way for me, buying a whole new external dvd drive right now is too pricey for me.
Thanks
Wade
Comment by 777guitarman, posted on Apr 13, 2007
My DVD player is an external Pacific-Digital dvd burner 4x max cd 2 times max dvd. The last error it gave me was a tracking servo error.
I try to burn DVDs and most of the time it does not even recognize I have a blank dvd in the drive ready to burn. It will tell me please insert a blank dvd, which is exactly what that is in the drive.
I just bought Maxwell DVD-R disk a pack of 25 not one single dvd does my drive recognize! the Sony DVD-R's I have at least once in while it will recognize, but truthfully I have made way more coasters than I have successfully burned.
So there seems something up with my dvd burner that does not affect my cd burner which is the same burner. Maybe because the dvd burner must be more accurate? also I am using a usb 1.0 port my computer is before 2.0
I figure I would like to fix it or replace it the cheapest way, money is short. I thought if I have to replace it, if I could just replace the drive itself maybe with an internal drive in the external case and not the full external dvd burner if that could be possible.
Thanks,
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 23, 2007
Helpful (85)
noperson
Rank:Guide Guide
Rating: 85%, 6 votes
Hi, have you tried one of those cleaning disks for DVD drives? It might help to clean the laser lens and not to be so picky, otherwise like all lens based drives it needs to be changed in some time anyway. Robert
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 24, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Yes I have apparently it does need to be changed, the disk cleaner did not help it at all. But thanks for the suggestion.
Can you Help with these DVD Drives problems?
DVD Drives
icon showing without installing...
I use to rom, one is dvd/cd... Answer This...
DVD Drives
Cant play DVD video
I have a LG DVD writer model... Answer This...
DVD Drives
DVD drive not running specific...
my dvd drive, on a vista home... Answer This...
DVD Drives
SOLSTAR DVD PLAYER, DVD 15SS
The DVD Player did not have a... Answer This...
DVD Drives
I have a problem with DVD-ROM
Good Night My name is Sergio I... Answer This...
Repair Service
Find DVD Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
