Question about Polaroid FLM-3225 32 in. LCD Television
No power on
I have polaroid 3200 32in lcd hdtv and power went off and won't come back on. what is problem and where can i by part to fix
  • 2 more comments
  • wrenowned Dec 21, 2008
    gallagher my board is different than the one your showing but will check for those caps. now my status light do not come on and fuse seems to be good. any more suggestions?
  • wrenowned Dec 22, 2008
    ok i changed caps and still no power. I do not get any lights at all and fuse seems to be good. any other suggestions
  • markmach Dec 27, 2008
    If the capacitors look fine, could it be the whole power supply?
  • pleeellen Jan 06, 2009
    I have the same problem. No red light, no blue light, nothing. Brought it to a repair shop, they told me it was the power supply, however, they could not get Polaroid to send them the $20 part. Called Polaroid myself, they told me for $225 they would send a tech to fix it after they sent me the part. If I wanted just the part and no tech, it would cost me $200. I took the bait, picked up the tv and twice, they sent the wrong part and the tech could not fix it. They refuse to do anything else or even give me my money back. It wasn't until I found the e-mail to the customer relations person that he told me they would send me a refurbished tv instead. got the refurbished and its all scratched, missing parts and not the same model. Now they are harrassing me to send my old, broken tv to them otherwise they are going to send me an invoice. Polaroid is absolutely HORRIBLE and the tech guy (independant) as well as the tv repair shop told me they are the absolutely worse tv's around. Now....the problem is the power supply, not the caps. It is a separate part in this tv (model 3201) and I believe that is true in mode 3225 as well. According to the tech, it takes about 15 minutes to change if you can find the part.
  • 3 Answers
Is the status light on wheather red or blue if eather one then the fuse is fine if not check the fuse. if the lights are on then chances are your caps are gone its a huge problem with these tvs. if it is your caps than just replace them as i did and the tv is working like new again. These are the caps I replaced they where only a little swollen I was worried if they where even the problem but I changed these three and was very happy that my TV is now working like new again the two top ones I replaced with 1000uf 16v the lower one is 1000uf 35v ok well I hope this helps ya
Posted on Dec 20, 2008
  • gallagher524 Dec 21, 2008
    i would still go with the caps, check them real good because one of mine where hardly noticable and after i changed it it turned rite on. the board that i am showing is the power board and where these caps are junk and cant handle the heat that theye are seeing i would still suggest replasing them for an hours worth of work and about ten dollars in caps its so worth the shot to get the tv running again.
Tv has power, but no picture
I hit the button on the sidea and it went to channel 17 I got it back to channe 3 but it still says no signa I do not have a Polaroid remote
Sep 27, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Help new power supply will not power up.
if you had a surge, it could have damaged more than just the power supply. When you plug in the unit, does the power indicator light up??? your main board could also have damage. The main board sends a signal to wake up the power supply thus turning on the TV. If you have to replace the main board as well, it probably won' t be economical to repair the set.
May 19, 2012 | Polaroid FLM-3734B 37 in. LCD HDTV
I have a Polaroid tv 32" flat screen tv and I heard a noise like hissing! It got louder and then my tv went out and smoke came from the top of it! So, can it be fixed and how much would it cost to...
99% chance the problem is in the inverter board that provides the AC needed for the flourescent lamps behind the LCD monitor.
There's a small chance it is the power board.
Oct 25, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
My polaroid hdtv started smoking and then the picture went out. It will still turn on and has sound but no picture. There is also a flashing red light on the back. Can this be fixed and if so how?
Yes,This is not a power supply problems,u have power and sound,just no picture.Because the LCD inverter board help get picture is dead have burn parts in the board.Tries Websites Shopjimmy.com,Ebay.com to buy a LCD inverter board for the replacement.It a long board in shape.
Mar 25, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid flat screen TV's picture went to black after 53 weeks. Help!
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 13, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
POWERS UP BUT NO PICTURE OR SOUND WILL NOT SHUT OFF POLAROID 37" HD LCD TV-2 YEARS OLD
my POlaroid 37" did same thing blue light stayed on no pic or sound was 2 electrolytic caps on power supply board took back off and they were noticably bulged at top radio shack sells these caps at $3 apiece fixed mine works like new saw a video on here how to do it
Dec 07, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
TV won't turn on with remote or manually. I've replaced the power board.
If you replaced the power supply module due to bad capacitors or blown parts, it could have damaged the main board when it went out.
You can download the service manual here: http://www.polaroidsupport.com/polaroid/en_us-sm.html
Dec 01, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid FLM-3225 32 in. LCD Television Logo
175 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
