Question about Toshiba Tecra A3 Notebook
Cannot find how to disable the Touchpad
I have a Toahiba Tecra A3. It had a terminal illness & the fat table was totally corrupted, so my pc tech. installed Windows xp, but didn't have the relevent Toshiba rocovery disc. I now cannot find anywhere to disable the touchpad & it's driving me crazy, as I keep accidentally touching it, so it's like 2 drivers trying to drive the one m/vehicle. I have tried Control Panel and am now at a total loss. HELP please??!! Thanks Wendy
  • 1 more comment
  • Wendy Maxwell Mar 31, 2007
    Hi
    Thanks for your time & the information. I am a total techno dinosaour, so when I clicked on the link, I then ticked the windows xp to d'load, but I don't know if it actually d'loaded it or not, as it didn't ask me if I wanted to 'run' it or not.
    My other problem then, is that if it did d'load it, I don't know where to find it on my system.
    Sorry to be such a dope, but I'd really appreciate your 'holding my hand' through your help please.
    Many thanks again.
    Wendy
    Thanks printerhater for your suggestion, however I tried doing that first, but there is no touchpad option available in the Control Panel.
    Unfortunately, I don't have the manual for this laptop, as someone borrowed my carry case & removed the manual(permanently.!
    I live in Australia. There are no further letters, etc. beside the Tecra A3, so can't help with that either. There are numbers that may help .... However, it does give the Part number as if this helps.
    I stated earlier that I was running ME prior to the reformatted h'disk, but after looking under the case, it states that WindowsXP Professional was installed when I purchased it.
    Thanks again for your help ...
    Wendy
  • EzyMedia Feb 25, 2009
    My toshiba A3 Tecra keeps freezing. Started now and then 24 hours ago and now its all the time, within 10 minutes tops of rebooting.
    Novelist:
  • 86 Answers
Hi peony, For some reason, I suspect you're not within the borders of the US, and it turns out that there are at least three versions of the Tecra A3, so please let us know which country you are located in, and if you have the A3, the A3-S711, or the A3-S731... it might make a difference in the drivers you need to install... You'll need to check your Tecra user's manual, or look on the bottom of the laptop for a label with the specific information about your system, and post the details here... In the meantime, I've copied these instructions for you directly from the Toshiba Tecra A3 online instruction manual. To disable the TouchPad, follow these steps: 1. Click Start, then Control Panel; the Control Panel will open. 2. Click Printers and Other Hardware. 3. Click the Mouse icon. 4. Click the TouchPad ON/OFF tab; the TouchPad ON/OFF tab will appear. 5. Select Disable or Enable, whichever is appropriate. 6. Click Apply. 7. Click OK 8. Close the Printers and Other Hardware Window. Once you've done that, reboot the system, and test it to be sure the TouchPad is now disabled. After you provide the details I've requested (which version of the Tecra A3 are you using), we should be able to provide you with more specific information on which driver you need to download and install. Good luck; post the information I've requested, and let us know if you have problems disabling the TouchPad...
Posted on Mar 31, 2007
  • Printer Hater Mar 31, 2007
    UPDATE FOR PEONY:
    Hi Wendy,
    Thanks for the information about your Tecra A3; now, you should be able to download and install the proper TouchPad driver, reboot the system, THEN disable the TouchPad through the Control Panel. I suspect that the TouchPad is working through some generic Windows driver, or that it is utilizing the basic mouse driver; with a little luck, we'll be able to correct that, and make it work (or NOT work) as you prefer...
    You can download the TouchPad driver directly from here:
    http://cdgenp01.csd.toshiba.com/content/...
    Click on that link (or, copy and paste it into a new browser window); you should then be able to download the TouchPad driver directly onto your system. BE SURE to save it to the Desktop, so you can find it easily once the download has finished (it is only about 2.5MB in size, so it shouldn't take long to download).
    Once the download is complete, CLOSE ANY RUNNING PROGRAMS, then locate the file (ta3tpadx.exe) on your Desktop. Double-click the filename, and follow the prompts to install the driver. Once the driver has been installed, REBOOT THE SYSTEM, then test it to be sure everything is working properly.
    Lastly, once the proper TouchPad drivers have been installed, and the system rebooted back to the Desktop, following the steps I posted previously should allow you to disable the TouchPad through the Control Panel.
    Good luck; keep us "posted", OK?
  • 57 Answers
Hi, Please visit the following URl and find all the drivers needed for your machine. http://driverscollection.com/?H=Tecra%20A3&By=Toshiba Hope i was helpful enough.
Posted on Mar 30, 2007
My laptop dynabook my first windiws japanese version i try to convert english , but cannot continue the installation any windows system i try windows 98 , windows 2000 , then windows vista , windows xp but cannot accept all system Pls.... help me solution my laptop.thk u
Posted on Sep 17, 2008
Toshiba tecra a10 touchpad does not work. I have tried under win7 and fedora, but no joy. Last resort is to check cables
Is it disabled? Have you Upgraded the OS recently? Did it work before the upgrade? Open Device Manager, is it there?
Dec 26, 2012 | Toshiba Tecra A10 Notebook
My onborad mouse on my toshiba Tecra A3 pta3u14004 is not working how can I fix it
You can enable or disable your onboard mouse with Fn+F9
TouchPad Enable/Disable ( Fn+F9 ).
Regards
Jun 03, 2011 | Computers & Internet
Where to find driver for touchpad scroll toshiba tecra A3-s611
To Enable the Pointer Device, go to, Control Panel, click (Mouse) in the Hardware and Sound category. Go to, Device Settings, in the (Devices) block, click on, and Highlight; the item you want to (enable) this being the Pointer Device. Click the Enable button, just below. Be sure to (Click) on the Apply button, click OK. You may need to Update Drivers. Click on Hardware, click Properties, click, on Driver. If the, Update Driver (block) is not Grayed-out click Update Driver, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. I hope this Fix it. paul7of9
Jan 21, 2010 | Toshiba Tecra A3-S611 Notebook
I had a Thoshiba Tecra A3 Laptop nwhich is not loading OS
When you hear about the long beep it is a RAM problem which is not totally inserted. You need to check the RAM remove and reinsert it again and try to power on.
Dec 13, 2009 | Toshiba Tecra A3 Notebook
Message says FAT corrupted
FAT stands for File Allocation Table.  It is basically the table of contents like a book would have.  It tells whatever device is using it where the information is stored on the memory.  If there is nothing on it that you absolutely need saved, I would connect it to a computer and format the card.
May 30, 2009 | SanDisk Sansa Fuze MP3 Player
Boot up problem with Toshiba Tecra
easy:
1. get a window cd reinstall a more time.
2. go on line to download your laptop model's drivers. (www.toshiba.com).
just take a little long to do so.
it is not a big deal.
base on your case, you have nothing to do about, unless follow what i say, becasue you have a sries problem.
Jan 10, 2009 | Toshiba Tecra A3 Notebook
Toshiba Tecra A3 Notebook Logo
394 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
