Question about HP Compaq nc6000 Notebook
My keyboard does not work on my NC6000 , I havee googled the error and found it to be a common error corrected by taking the laptop apart and tightening the screw next to the fan for some reason this helps the connector for the keyboard
This might sound obvious, but try removing the keyboard, and check to see if the ribon cable is connected. I just purchased a used nc6000, and had no response from my keyboard. 2 screws on the back, and 4 little plasctic tabs between the f keys at the top. The tabs just slide down. Hope this helps.
Posted on Feb 23, 2009
Continually get error message " unfortunately, Android keyboard (AOSP) has stopped" I can't use the keyboard. How can this be corrected?
Without knowing your phone I can't give exact answer, BUT this is a work around. Assuming touchscreen still works open settings>applications>all find your keyboard, clear data and cache and restart phone. If that doesn't work or you can't find it you can always download new keyboards from the play store (I recommend Google Keyboard by Google, Inc.
Mar 07, 2016 | Android Cell Phones
Keyboard only works when I hold down the shift key
the driver is corrupt. Uninstall and reinstall again. you must have the correct driver download from your supplier HP go to www8.hp.com
Use the antivirus, and malware for to see if there are some virus or malware.
God bless you
Oct 16, 2012 | HP Compaq nc6000 Notebook
Some keys do not work any more
Ever find a solution yet?
Jun 30, 2010 | Compaq Keyboard
Hi i have the Microsoft wireless optical desktop 1000 keyboard but it's not working correctly when i press 'a' it writes 'b' is it a production error or it's configuration error and how can i fix it , by...
double check your operating system is set to use the keyboard layout (found in control panel)... I believe it is still a qwerty layout so it does sound like a hardware fault. what happens when you type "b"? do you get an "a"? you could confuse everyone and just swap the keys round :O)
You can remap the keys so they work correctly using special software like kbd edit but I would get a replacement if it's a new keyboard.
Oct 11, 2009 | Microsoft Wireless Optical Desktop 1000...
My HP NC6000 keyboard will randomly stop typing or freeze up
it is not the keyboard that have problem its the operating system that you are using. try to clean up your system by deleting unwanted files and the try to defragment.
Aug 13, 2009 | HP NC6000 df647av Keyboard
Wireless for Compaq NC6000
where is the on and off button above the keyboard
Jan 25, 2009 | HP Compaq nc6000 Notebook
Frustrating Keyboard Malfunction (HP Compaq NC6000)
please tell the solution of this problem of keyboard
hp nc6000 mobile technology
Oct 22, 2008 | HP Compaq nc6000 Notebook
Dead
    1. Check your Keyboard-Video-Mouse (KVM) switch. If the system is connected to a monitor, mouse, and keyboard through a Keyboard-Video-Mouse (KVM) switch, or console selector switch, then disconnect the switch and connect monitor, mouse, and keyboard directly to the system. If this solves the issue, please contact your switch manufacturer for support and compatibility on the switch. Some switches can have a firmware update applied to resolve common problems.
      Note: BladeCenter Telco chassis - The KVM module contains keyboard port, mouse port, Power LED, Location LED, Critical Telco Alarm LED, Major Telco Alarm LED, Minor Telco Alarm LED and a video port. The PS2 keyboard and mouse connectors are standard 6-pin Mini Din. The Telco alarms mirror the Telco alarms located on the front panel of the media tray because they use the same signal lines. The KVM module allows the connection of a VGA monitor for system maintenance and control. The video connector is a standard 15-pin VGA. The KVM module is hot-swappable. It is docked into an edge card connector located on the backplane:
    2. If you have your system daisy chained for KVM capabilities using the C2T port (e.g. xSeries 330),
      then you must flash the C2T firmware after flashing the system BIOS, in order for the mouse and keyboard to work. Otherwise, after a BIOS flash, you will lose keyboard/mouse capabilities unless you walk up to each machine and push the select button.
    • If you are using NetBAY Advanced Connectivity Technology (ACT) CAT5 cabling in your rack server, instead of KVM cabling, click here for ACT information.
    1. Check for POST/startup errors. If you are getting a POST/startup error on the keyboard and/or mouse:
    2. Verify that all items are firmly connected to the correct ports, and that the cables are undamaged with no bent pins. The PS/2 style mouse and keyboard ports look identical, but are not interchangeable. The mouse and keyboard must be attached to the correct ports in order to be recognized by the system and to function correctly.
    3. Swap each item for known good units. If a new item works where the original did not, then the original component must be faulty.
    4. If the keyboard works during the POST/BIOS screens, but not in the operating system, check software logs for device driver errors. Contact your software vendor for more support in configuring the I/O devices.
    5. Check the F1 Setup error logs for system component failures or errors. These are found under Event/Error Logs. Troubleshoot suspect components further to determine if the hardware is faulty. If an IBM component is determined to be faulty, please contact your local IBM Support Center for warranty replacement of the part(s). Please have the Field Replacement Unit (FRU) / Customer Replacement Unit (CRU) part number and Machine Type, model and serial number ready.
    1. Run hardware diagnostics. Replace any parts found defective.
    Download the latest diagnostics for your system
    1. If you can down the system, check the keyboard cable connector on the system unit for proper voltage.
    2. Power off the system.
    3. Disconect the keyboard cable form the system unit.
    4. Power on the system and check the keyboard cable connector on the system unit for the voltages shown:
      PIN Voltage (Vdc) 1 +5.0 2 Not used 3 Ground 4 +5.0 5 +5.0 6 Not used
    5. If the voltages are not correct, replace the system board. Otherwise, replace the keyboard.
    6. If these steps have not solved your problem:
    7. musekye318@yahoo.com
    Jun 30, 2008 | IBM NetVista PC Desktop
    Compaq nc6000 notebook?
    Now a chineese had found out what is wrong. You have to resold a part on backside of the motherbord - Google on NC6000 MAX1987 and you will find a solosion.
    Nov 17, 2007 | Compaq NC6000 Notebook
    HP Compaq nc6000 Notebook Logo
    149 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
