Question about HP Pavilion dv6000z Notebook
Home networking i need to set up a home net work can yoy help me.
  • Louie  Role
    Louie Role May 11, 2010
    Hi and welcome to FixYa,
    Initially, pls post back details:
    • how many computers;
    • what are their OSes;
    • wired or wireless:
    • do you have a router or a switch or a hub;
    • will they be sharing a single Internet Connection, a printer;
    • will there be more than 1 user per computer.
    Good luck and Thank you for using FixYa. Happy Holidays.
  • 126 Answers
Call 0845 20 20 118 for free home support
Posted on Dec 25, 2008
I was trying to manually the router up as wireless.
If you want to connect to the router wirelessly you need to know the SSID or the Name of the Router (Nework Name) and the Network Key or Wep Key. The Default Wep Key is the 10 digit key located on the bottom sticker of the router. It is near the Bar Code. You can also personalize the Network Key by simly accessing the router. I've listed the steps on how to access the router incase the Network Key on the sticker is not working.
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
  • Connect to your SSID by clicking on START then click on Connect To, Select your SSID then it will ask you for your Network Key. Type the Network Key then hit Connect
Rate me if this helps so i can help others
Thanks for using Fixya.
Jan 31, 2011 | 2wire 2700HG-B Router (2700HGB)
Need to find my wep key for my AT&T 2 wire 2700HG-B DSL router
Jan 31, 2011 | 2wire (2701HG-B) Wireless Router
Get stuck changing net settings, ie ssid...
if your home is set up with wireless modem or router and your computers are connected wirelessly its pretty simple to set up. more likely you or someone who set it up probably set it up securely meaning with security key and password. So you do have to know few things about your home network. like what is the name of your home network (SSID). the security setting of your home network. and finally the password of your network. if you don't know these things about your home network you will not be able to get connected wirelessly. but if you do have these info on hand read along....
JUST MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont work if you don't have a wireless setup and u are trying to connect wirelessly. people overlook this no brainer.
1) go to Settings
2) Network Settings
3) Internet Connection Setting. confirm on "O.K."
4) easy *it may or may not give you a message reading "checking network configuration2_bing.gif"
5) wireless
from this point on you need to know few things about your network.....
6) scan -- once scanned it'll give you other wirelss access point for you home network and some other near your home along with few information such as SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) SECURITY (this is the password you set up your network with) SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network will probably not do you any good since it'll probably be all locked with password and such and so should yours be.
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network. if you don't know ask the person who set up your home network)
9) on WLAN SECURITY SETTING2_bing.gif page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
10) WPA KEY - which basically means password. input the password you used to set up your home network (this is another thing you should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input all the correct info you should get the "setting list" screen
12) press "X" to save the setting
13) do the connection test and if all things were entered correctly you should have success.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network security setting, and the password of your home network.
on the other hand if you are setting up a wired connection it makes it a whole lot simpler. you don't need to know your network name, security key, and password.
make sure you have the ethernet cable plugged in to your ps3 and to your modem or router
1) go to Settings
2) Network Settings
5) wired
6) auto-detect
7) automatic -- for the IP address setting
8) do not set
8) automatic -- DNS setting
9) automatic -- MTU
10) do not set -- PROXY SERVER
11) ENABLE -- UPNP
save connection setting
test connection
if your home network is set up and u got the ps3 connected it should work
May 19, 2010 | Sony Playstation 3 (PS3) Console
Upgraded to win7 and can not get home net to work
the settings on windows 7 need adujusting to accept the new network,
Log into the router from your machine
turn off the other machines then try the router
from your explorer bar enter 10.0.0.1
this should log you on to the router
if it doesnt then you need to check the setting for your wireless adaptor,
check your ip address's are set to the routers sub net mask are
Mar 27, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Internet
- Make sure that your PSP WLAN switch is turned on!
Where's your PSP manual?
OK here, I'll go through all steps to get to use the net on ya PSP!
PSP on...? Check...
WLAN switch on & working properly? Check...
Now...
go to Network > Enter Internet Browser > You probably don't have your net on 'Auto-Select' or have set a 'Home Page Setting', so enter a URL in the Address Bar > it'll then come up with 'Network Connection', 'Select connection', enter '[New Connection]' > 'WLAN Settings', enter Scan, probably the easiest for you > 'Select the access point to be used'. Select your home access point > 'SSID', name correct?, press right arrow button to continue > 'WLAN Security Setting'. Select the correct one if incorrect. If you need a PW for your connection, WEP, WPA Key, then enter it, if not, enter None > 'Address Settings', enter Custom > 'IP Address Setting', enter Automatic > 'DNS Setting', Automatic > 'Proxy Server', don't think you need that!, enter Do Not Use > 'Internet Browser', Start > 'Enter the connection name.', name it what you what it to be > 'Setting List', scroll through to see if everything's correct > 'Press the O/X button to save settings.' > Now it'll appear on the 'Select connection' page again. This time, click on your home connection... DONE!
- I suggest you to save say Google as your Home Page, so it'll be more convenient for you on the future! Tools > Settings > Home Page Settings > type in a URL that you want as your Home Page!
- PSP net have very little net memory, so to save some memory, go to Tools > Settings > View Settings > Conserve Memory On.
Don't forget to thank me! Thank me by rating me positively, & 'Was this Useful', YES! XD =)
Nov 11, 2009 | Video Game Consoles & Games
Canon ir 330-400 copier
it is supposed to use a separate scanning board (Interface Board-D1) with SCSI connectivity and TWAIN software.
Mar 15, 2008 | Canon imageRUNNER 400S Copier
HELP, LG SHINE 970
Internet Setting Cingular:
Profile Name: Cingular
GPRS setting:
APN: wap.cingular
User Name: WAP @ CINGULARGPRS.COM
Password: CINGULAR1 (ALL UPPERCASE)
Time Out: Off
Primary Gateway IP: 66.209.11.61
Port: 9201
Secondary Gateway IP: 0.0.0.0
Port: 0
DNS Server:BLANK
CSD setting:BLANK
Dial in number NONE
Query at Logon: (NO CHECK MARK)
User Name
Password
Baud Rate Auto
Line Type: ISDN
Time Out Off
DNS Server:
Then go to your browser and enter the following settings:
Profile Name: MEdia Net
Homepage: device.home
Network Link: Cingular
MMS Settings:
Profile Name: MMS over HTTP
MMSC: http : //mmsc.cingular.com/ (No Spaces)
Max Sending Size: 30K
Network Profile: Cingular
Internet Setting T-Mobile
T-MobileWeb Settings:
Primary IP Address: 216.155.165.050
Secondary IP Address: (Blank)
Access Point Name (APN): wap.voicestream.com
Data Bearer: GPRS
Profile Name: GPRS
Username: (Blank)
Password: (Blank)
Home Page: http://wap.myvoicestream.com
Picture Messaging Settings:
Multi-Media Service Center (MMSC) Address: http://216.155.174.84/servlets/MMS
Validity Period: 72 hours
Hide ID option (if option exists): set to off, no, or disabled
Internet Setting FIDO
Profile name: FidoWAP
GPRS setting:
APN: wap.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.11
Port 8080
Secondary Gateway IP: (blank)
Port: (blank)
DNS Server: (unchecked)
CSD Setting:
Dial in number: (blank)
Query at logon: (unchecked)
Username: (blank)
Password: (blank)
Baud Rate: Auto
Line type: Modem
Timeout: Off
DNS server: (unchecked)
Then press Save.
To get MMS working (what I haven't included are the blanks and all boxes should be unchecked unless specified)
Setup-->Data Network
Profile Name: Fido MMS
APN: mms.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.13
Port: 8080
Baud Rate: Auto
Line type: Modem
Timeout: off
Then click SAVE.
THEN
Messages-->Service Setup-->Multimedia Message
Default profile: FidoMMS
(all other settings are to your preference)
Tap the box beside Default Profile and ensure that FidoMMS is the default profile.
Settings for MMS profile goes
Profile name: FidoMMS
MMSC: http://mms.fido.ca
Max Sending Size: (your preference)
Network Profile: Fido MMS
Internet Setting Rogers
Proxy Name: Rogers MMS
Proxy Address: 172.25.0.107
Access Point: Rogers MMS
Home: ((Set whatever page you like here))
Port Number: 8080
Authentication Type: HTTP-BASIC
User Name: media
Password: mda01
Access Point Name: Rogers MMS
APN: media.com
Authentication Type: PAP
User Name: media
Password: mda01
DNS: <>
Linger Time: 180
MMS Accounts (Main Menu -> Messaging -> Messaging Settings -> MMS Settings)
Profile Name: Rogers MMS
Proxy: Rogers MMS
Relay Server URL: http://mms.gprs.rogers.com
Master Reset
Dial the following 2945#*#6 or 2945#*45#
Feb 14, 2008 | LG Shine KE970 Cellular Phone
HP Pavilion dv6000z Notebook Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
