Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I need a tv code for a mitsubishi tv model-wd 62526 2006
One day when i disconnected the tv then turned it back on it said (this tv is temporary blocked) and then it told me to enter a 4 digit code with my remote that i dont know....? my tv is a mitsubishi WD 62526 -2006M
  • 179 Answers
Use your remote and press QV and 9 together. the reset the code
Posted on Dec 29, 2008
How do I fix DVI cable between FMT and Engine disconnected
Are you sure its disconnected? It may have a FMT failure. The cable is inside the back of the TV. you need to remove the rear panel to see it. There should be a white ended cable that plugs in that looks like a monitor wire but short.
Sep 15, 2015 | Mitsubishi Televison & Video
Code 34 replaced lamp with 2 new osram lamps may run for 5 min or 5 hrs shuts down solid red light code 34
I have a Mitsubishi model WD-60737 and to make a long story short 1st time problem lamp replaced fine for a month til my uncle hooked a DVD player to my TV next day turned on with solid green light then TV kept turning off after 2 to 3 minutes of beingetting turned on and a solid red light to show after. What does that mean? It's a brand new lamp and worked for a month so why shut down now? Could my uncle have did something to where it shook up the circuits or something?
Sep 25, 2014 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi WD-65638 turns itself off and I see no status codes afterwards
Press menu and input on front of TV for 5 seconds. Green light will flash two digit code 5 times. '12' is no error(no problem.)
May 22, 2014 | Mitsubishi WD-65638 65" DLP HDTV
Air flow vent is blocked, tv keeps shutting down, mitsubishi ws-55615, how to fix ?
Mitsubishi's product line includes a wide array of LCD, Flat Panel, and DLP televisions to suit your home entertainment needs. The electronics division has the distinction of inventing the first rear-projection television and selling the very first HDTV in America. Their 400,000 square foot manufacturing facility, located in Irvine, CA, boasts the ability to produce more than 1,000 projection TV's in one day. The company's oft-stated goal of unmatched excellence is driven by their mantra: "Technically, anything is possible." In June, 2008, Mitsubishi introduced a new premium flat panel TV with an integrated 16-speaker sound projector.
Warranty Information
There is in-home service on all big screen models, which have warranties of 30 days for screens and one year for parts and labor. The LCD televisions have a one year warranty on parts and one year on labor with carry-in service. For plasma sets, in-home service is available on all models. There is a one year warranty on parts and one year on labor. The faulty thermal sensor, mentioned in the commmon repairs section, is now covered by an extended 2 year warranty, as is the problem related to the optical engine.
Common Repairs
For the following models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD-65732, WD-57831, WD-65831, the most common repair problem stems from television shutting off almost immediately after it has been turned on accompanied by the message, "TV will shut down in a few seconds. Please check if the air flow is blocked." According to the Mitsubishi website, this issue is caused by a loose connection as a result of a faulty thermal sensor. For models: WD-73727, WD-73827, WD-73927, WD-73732, WD-7383, the most encountered repair problem has been in relation to the optical engine. Another common situation consumers have encountered is failure of the TV to turn on along with unceasing flashing of the green power light. The solution for this problem, caused by the DM board, will vary by repairman. Consumers have also encountered issues with moving vertical or horizontal lines appearing on the screen which can either be due to problems with the capacitor, light engine, or formatter board.
Jul 26, 2012 | Mitsubishi Televison & Video
Mitsubishi WD-60735 Control issues
This set has aside from the recessed front reset two more done with the Mitsubishi remote.
The soft reset "should" be with set on Menu, 1,2,3, enter
The hard reset requires a 4 digit number code and is based on model number and also done with the Mitsubishi remote--try to see if soft reset works at all on this model.
Mar 31, 2012 | Mitsubishi WD-60735 Projection Television
My tv keeps shutting down when I turn on. The message on the the TV screen said that "the TV will be shutting down in a few minutes". I resit the lamp in the back of the TV and the TV works after I reset...
The first would be excessive dust causing inadequate airflow through the lamp cage. Cleaning the filter may resolve the problem.
It could also be that one, or both, of the temperature sensors could be defective. This is a known problem to the extent that Mitsubishi extended the warranty an extra two years on your model and similar models with the same design.
Mitsubishi Digital Electronics America, Inc (MDEA) 2006 DLP® Projection Televisions Models: WD-52631, WD-57731, WD-65731, WD-Y57, WD-Y65, WD-57732, WD- 65732, WD-57831, WD-65831.
As part of our commitment to quality and customer satisfaction, MDEA is announcing an extension of the warranty coverage to replace the thermal sensor for the above referenced models. For a period of two additional years beyond the one year limited warranty, MDEA will cover the cost of the thermal sensor (parts and labor) at no charge. All other terms of the MDEA limited warranty will continue to apply.
Nov 30, 2017 | Mitsubishi WD-57732 Projection Television
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
Blue screen on WD-52525
wait the 4 days. any work done on it by a non authorized party could ruin your warranty
Dec 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
300 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
