Question about GE Monogram ZDI15C Automatic Icemaker
ZDI15 make too much ice
The ice bin overflows with ice. The high level sensor is in place but does not stop the machine making ice.
  • evaez Jan 23, 2009
    same problem. In fact it pushes the ice bin cover out of its tracks
  • md70118 Feb 02, 2009
    The bin in my icemaker fills above capacity. I have cleaned it twice. Any suggestions?
  • 4 Answers
High level sensor is bad.
Posted on Mar 13, 2009
My refrigerator in-door ice maker jams up with ice. Some ice cubes are connected together. Maybe the freezer bins are overflowing. Does a defective timer at the end of the ice maker cause this?
We have one also. We put the ice in a bag and whack it in the sink to break up -- or simply toss. Make sure that the ice bucket in the door is not dirty, a beam is sent across it to sense ice level and turn the maker on/off. Also clean sensors either side of the door inside with soap and water. make sure it is dry.
Feb 27, 2018 | Whirlpool Washing Machines
Machine has stopped working and is in alarm
Possibly a stuck or defective ice level switch in the ice bin. It's supposed to cease the ice making when the bin gets full and then return the ice making components back on when the ice level drops to a certain level. Should be an easy fix if the switch is bad. The wires have push connectors on them.
Sep 06, 2017 | Kitchen Appliances - Others
I have a Scotsman Cm3 which will not stop making ice. When I come back to work in the moring and open the door, ice falls all over the floor. Is there a way I can fix this?
Is the ice building up into the ice head enough to break the beam on the bin sensor. if so replace the sensors. if ice is not up far enough shut machine off remove plastic grid reach in and down to where bin sensors are and watch to see if light blinks on and off if so they are good. next step check the bin there should be a white ice deflector with 3 thumb screws in the top of it make sure this deflector is mounted so it makes the ice build up high enough to cause ice to reach bin sensor. if the sensor is not seeing ice then it will let the machine keep making ice. If this is all working good then replace the service controller but make sure you look on the back to set the right model program for your machine.
Sep 16, 2012 | Scotsman Ice Machine, Cuber, 1930 lb....
Have manitowoc ice machine model sdo452a . water constantly running already changed water valve
CK TROUGH LEVEL SENSOR! THE PROBE OR SOLENOID ARE DEFECTIVE. LEFT BIN LIGHT ON GRN+ PROBE LIGHT OFF RED. TO PROVE WATCH FOR 3 MINS TROUGH WILL OVERFLOW INTO BIN >DRAIN.
Jul 23, 2011 | Refrigerators
Water keeps overflowing over the ice making coils
Do you mean that it is overflowing the sump tray into the bin? If so there are two things to check. First make sure the unit is level. Second their is a simple water float valve much like an old toilet float that keeps the sump full. Turn the machine off and make sure that the float will stop the water flow 100% when the sump water level is just over the bottom of the water pump impeller. If the float will not stop the water flow either the water pressure is too high or the float valve is bad and has to be replaced. In general water pressure should be between 20-40 psi.
Dec 18, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
The automatic ice machine does not make ice. the water dispensor works.
check if the icemaker is switched on.And place the ice bin correctly.If it is not placed properly it will not function.Check the ice cube level arm(microswitch) or the ice sensor(in some models to detect the ice cubel level) not blocked.Check the user manual if is there any self test mode of the icemaker.
Jun 30, 2009 | Maytag Refrigerators
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
Free standing 25lbs ice machine
It sounds as though the bin therrmisotr is defectice, which as you stated the unit is not sensing the temperature and just continues making ice.
The second issue would appeare to be a drain issue, it should be a gravity drain into either an open drain or a sealed pump.
Apr 08, 2008 | Viking Professional Series VURI140TL...
GE Monogram ZDI15C Automatic Icemaker Logo
605 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
