Question about Zenith SC652 Remote Control
No remote, cant get aux or video
Zenith conceirge series H2013Y
1995 27" zenith tv picture dark with red glare won't adjust
THE TUBE IS CARBONIZED -IF YOU HAVE A TECHNICAL KNOWS
PUT 9V CA or CC IN FILAMENT AND A LAMP MAX 15WATTS IN SERIE WITH ANODE AND RED GREEN BLUE CATHODE (ONE AT TIME) -OFF FILAMENT AND YOULL SEE SPARKS INSIDE THE TUBE WHEN DESCABONIZE. REPEAT AT LEAST 3 TIMES
Sep 25, 2013 | Zenith B27A11Z 27" TV
Zenith instruction manual Model # MBA3026
get in contact with the manufactor or the store that sells them.
Jul 16, 2012 | Zenith Home
I've a Zenith TTL SLR camera with loads of lenses
Hi, The lens' you currently have have a M42 mount on them so you'll need an adapter that will convert M42 to the micro four thirds mount that Panasonic uses on their G series. http://www.bhphotovideo.com/c/product/646915-REG/Novoflex_MFT_CO_M42_to_Micro_Four.html is one option of a mount you can get that will make it so your lens' can be used. Hope that this helps =)
May 16, 2011 | Zenith Photography
I am having convergence problems and need to know if there is really a difference with Sanyo and Sanken STK IC convergence chips?
Just the name, Sanyo quit making the STK series several years ago Sanken, Toshiba and Mitsubishi all have good versions of the STK series.
Aug 25, 2010 | Zenith R50W46 50" Rear Projection...
Model abv441 need a manual
I did find a manual for the abv341 manual...perhaps there something here that might help you:
https://www.manualslib.com/products/Zenith-Abv341-Series-4031192.html
Jul 02, 2017 | Allegro DVD/VCR ABV511
My Zenith Projection HD TV is displaying a series red lines
It probably needs the convergence circuit repaired by a qualified technician.
Sep 09, 2009 | Zenith R57W46 57" Rear Projection...
Generator available light rapid flashing
press the reset key(button) on the controller (asumming you have a R-M4 controller.) The R-M3 controller should have a reset button too.
Jan 17, 2009 | Zenith GE ZTX Series 100A Automatic...
Zenith R49w36 problem
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com The kit had all the parts and simple step by step photos of the repair. At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly. You guys rock!
I will spread the word.
Louis
May 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
Televison & Video Logo
169 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
