Question about Janome MyLock 634D Mechanical Sewing Machine
I lost the instructions and dont know how to thread it!!!
The overlocker when i sew dosent put in the bottom stitch and i dont know what is wrong with it. if anyone knows what is wrong please help me. i have to use this machine for my VCE fashion assessment!! thanks
  • 944 Answers
They don't have a manual online, this link; http://www.janome.com/product_show.php?id=362 Gives you some more details which might help, if not i would contact them directly, they are usually helpful; http://www.janome.com/contact.php They do have a good list of FAQ's on that link also, maybe you see what you need there. Hope this helps :)
Posted on Mar 30, 2007
SOURCE:
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
Help plse, after threading it dont make the overlocking stitches. New machine, help with right way to thread machine and the smaller detail of threading.
Your machine is either not threaded correctly, or the individual threads have not been threaded in order. Be sure to ALWAYS RAISE the presser foot when threading the machine. You must follow the instructions exactly or the machine will most likely never work properly. Can you at least get a training class on your machine? A class is indispensable, especially when it comes to using a serger.
Even if it is not the same model, these instructions may be helpful.
Tutorial for threading overlocker
Make It Handmade Threading Your Serger or Overlocker
Need manual for an empisal 754D overlocker can get the tension right and...
Dec 14, 2016 | Sewing Machines
My Brother LS 2160 is threaded but not stitching
Hi there Kathryn... when you load/thread the top cotton through the machine.... and then through the eye of the needle.... do you also load the bobbin case... or is it already in there and loaded as per instructions... ? What I normally do... is load up the bottom and top threads first.. making sure to put the top thread through the needle and make the thread end go through and behind the 'foot'... when placing on fabric to try... I make sure to load the fabric... with the top thread's tail going out through the presser foot and behind your foot.. sometimes.. if its the thread (some machines don't like certain threads)... I will manually (wind the right hand wheel) so that the machine does a few stitches.. before I use my foot pedal!.. I have both a serger/overlocker... and a Brother 8500 (sewing/embroidery machine).. I have been sewing for over years now...
You will need to change your needle... when you've used it for more than 6-7 hours continuously.. OR you notice that the stitches are not as they should be... in your fabric...
Mar 22, 2014 | Brother LS 2160 Sewing Machine
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Aug 31, 2011 | Sewing Machines
It will not do an overlock it will cut the fabric nothing else I followed the directions on how to thread it but the only thing it will do is cut the fabric what am i doing wrong
for all Sewing machines to stitch the cloth, Top needles and bottom hemming needles timing should be configured. Please let us know the whether it is double needle / single needle overlock machine. and model number of the Machine.So that i can guide much better.
Apr 06, 2011 | Brother Sewing Machines
Hi, I am unable to do a overlock stitch , elna l1
Check with sewusa for a threading guide and manual.
Look inside the font door of the machine to see if there is a threading guide.
Feb 28, 2010 | Sewing Machines
Thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
May 21, 2008 | Husqvarna Viking 1
Janome MyLock 634D Mechanical Sewing Machine Logo
214 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
