-   i have lost d driver cd for mercury pnmcp73v board can any1 send me d link for driver download my email id is choudharynitin31@gmail.com
-   choudhary297
Drivers are generally for your system (sound, display, NIC, etc) ... Whereas searching with the name of your motherboard may often only result in you finding updates to your bios.
Onboard devices (such as your sound/audio device) that might be built in to a motherboard are often referred to by the maker of the device/chip that handles the task on the motherboard. (for example. a person may have an ASUS motherboard but it's onboard display might be 3D Labs Oxygen VX1 ... you would likely need to search under 3D (etc) , not ASUS)
Bottom line - the drivers for your system will require you to know what devices are in your system by model and manufacturer. Make a list of the all the information ... Sound/Audio, Display/Graphics, Network Interface card, etc. etc.
A couple of the first places you could try would be the websites of the maker of your motherboard, and the maker of your system (i.e. HP etc) and see what you can come up with.
Once you make your list of devices as I noted above, then go to DriverGuide.com ... one of the best free driver sites on the web.
HI, MB M2N32 WS - at first Bios rev. 2001 05.05.2008 doesn´t work, and freeze up, flashed...
(More)
HI, MB M2N32 WS - at first Bios rev. 2001 05.05.2008 doesn´t work, and freeze up, flashed rev. 2001 dat. 05.08.2008 seems better, but during or closed after booting WXP ...freeze up system ...need restart, but after that, same... Athlon X2 5600+ 2,8, DDR2 Geil 800MHz 2x2 Gb,GPU Asus 8800 ultra, Pwr - Corsair 650W, 2 HDD WD, water cooling
hello im booting my 2635 and problem 0163 and 0161 coming up.after i set the right date i press ok...
(More)
hello im booting my 2635 and problem 0163 and 0161 coming up.after i set the right date i press ok and then the lapto restarts and show me exactly the same errors and coming to same situation as it was.what i can do
