Question about Fuji FinePix S700 Digital Camera
Flash not popping up or working on fuji finepix s700 digital camera
  • 1 more comment
  • Anonymous Mar 30, 2009
    Flash pops up, but does not fire. It doesn't work on any setting (force, red-eye, auto). Any ideas?
  • doggykano63 Apr 09, 2009
    tell me how to take the flash and reinstall some kind of a spring mechanism so it will come up when I need a flash. right now it has no spring to make the flash come up
  • Anonymous Mar 22, 2014
    deleting images from Fuji S700 camera
    Novelist:
  • 109 Answers
The S700 does NOT have a manual release for the flash to pop up, but it DOES have a spring already. DO NOT try to force it! Set the flash to "FORCE", leave your lens cap on and waste a shot to allow the flash hood to pop up. Reset your flash to the desired setting and now the flash is already open and ready for use without the delay and the startling effect it has when your concentrating on framing your shot. As for the other problem of no flash in any setting: Check your menus to see if you have the flash totally disabled, check your batteries, does the "charge indicating light" come on at all between shots? In RARE cases, the actual bulb that flashes may be burned out, or a component in the flash circuit itself,such as the capacitor, may have gone bad. Did the flash ever work? If under warranty, return for repair or replacement. There are NO user serviceable parts in these tiny cameras
Posted on Jul 16, 2009
Some how we have deactivated the flash to our fuji fine pix S700 digital camera and now the flash wont pop up or do anything can you help
I have looked on this site for the manual for your camera
http://www.fujifilm.com/support/digital_cameras/manuals/
However, as you will see when you go to this site, your camera model is not listed. Are you sure the model number is correct?
Without the model number, I can say generally, that digital cameras have a menu button that has many options in it which includes setting the flash to Auto or On or Off. Explore your camera options a little and I'm sure that you will find these options.
Good luck to you and Thank You for using FixYa.
Jan 07, 2011 | Fuji FinePix S700 Digital Camera
How do I fix the pop up flash on my fuji finepix s700
fix the pop up flash,,,,select manual M operation,flash donot pop up.
Apr 03, 2010 | Fuji FinePix S700 Digital Camera
Flash will not pop up. Can you help?
If it releases but doesn't properly pop up then this may be the answer.
Mine did the same thing. The problem in mine after extensive disassembly was the plastic had broken inside the flash where the pop up spring attaches.
This was a pretty extensive repair with full disassembly in my case, not for most people.
A workaround is to take a small rubber band, loop it over the top of the camera from the eyepiece for the viewfinder to the lobe in front of the flash. When you need flash, release the flasy and unhook the elastic fromt he front lobe and let it go under the raised flash unit and it will keep it up. If you case lets you, you can leave it that way. Not pretty but functional.
Dec 16, 2009 | Fuji FinePix S700 Digital Camera
The flash will not fully release, only opens up
Having the same problem. We rig it by tucking the strap into the pop up flas to hold it up...
Dec 05, 2009 | Fuji FinePix S700 Digital Camera
Fuji finepix S700 Built in flash not working
It is a common problem. Your flash probably does not pop all the way up. I fixed mine by gluing a spring I made under the flash. The spring is about 3/4 round x 1/2 high with about 1 1/2 turn. It took me a while to get the spring tension right.
Aug 04, 2009 | Fuji FinePix S700 Digital Camera
This model does not have a manual flash pop up release, so if the flash is not needed, it won't pop up at all. Use the "flash" button on the back of the camera to set: fill, forced, disable, etc. flash settings.
Jul 05, 2009 | Fuji FinePix S700 Digital Camera
Fuji s700 my flash is not popping up on auto and my camera is taking all dark pics
The flash on my S700 stopped popping up too. But I made a spring about 3/4 inch in diameter by 3/4 inch high with about 1 3/4 loops. I glued it right under the flash. It works quite well now.
Sep 01, 2008 | Fuji FinePix S700 Digital Camera
Fuji FinePix S700 Digital Camera Logo
1,080 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
