Question about Zanussi F1245W Front Load Washer
Zanussi 1245w fails to spin
Hello My 1245W is doing it all right, except when the spin cycle at the end of the washing cycle is selected. To put it simply, it is draining but not spinning leaving all the load soaking wet. Any ideas?
  • james millar Mar 31, 2007
    Thanks for the reply - it is rotating on wash and managing a slower speed spin when on drain mode, but still no high speed spin.
    President:
  • 1,462 Answers
Suspect it may not be rotating on wash either. check the moor brushes
Posted on Mar 30, 2007
  • douglas smith Mar 31, 2007
    cant give you a definitive answer but could be:
    1) there is an out of balance detector which prevents spin if load will not balance. however this would obviously not operate every time only when unbalanced load.
    2) points to a defective motor control pcb. sometimes it is worth visual examination to see if any dry joints. less likely is a defective motor
    i assume it is draining completely - no drain, no spin
Zanussi aquacycle 1200.After a wash has finished and i empty washing, reload again,it wont start and none of the lights come on.eventially it works ok again after a good 5-10 mins.
you have probably done no harm. try selecting spin and drain again to ensure the water has drained properly.
Machine starting on its own after 5 minutes or so is usually the door lock failing, again not caused by your actions.
Sep 05, 2016 | Zanussi Washing Machines
Washer skips rinse cycle
Possible defective washer control panel.
Jul 13, 2017 | Zanussi Washing Machines
Zanussi FLE1216w Repair Manual
Hi, my zanussi fle1216w is skipping the fabric softener stage of the cycle. I've cleaned the dispensing drawer and the surrounding areas, even put on a boil wash in case somethihg was gunge up or visits the Zanussi Owners Manual.
Mar 22, 2012 | Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Zanussi washing machine is making five beeps and not workign - what does this mean? It is not in the manual
My Zanussi Fs1555w is not finishing it's cycle and beeping 7 times. If I put on spin the cycle lasts less than a minute before the end button beeps, then it will beep repetitively 7 times until turned off. Please help
Feb 05, 2010 | Zanussi FS1455W Front Load Washer
Zanussi ZJD1219 Washer/Dryer - noisy spin and dirty spots
Sounds like the main drum bearings have failed, and the marks on clothes are probably grease spots from the main bearings.
It is quite an involved repair, and not one that I would recommend you tackle yourself unless you are competent to do so,as it really is involved.
Please rate my solution.
Thanks.
Nov 15, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
THE WASH REACCHES DRAIN AND SPIN STOPS THEN ENDS CYCLE
pump is blocked check your filter at the front some have a small drainage tube there to remove the water. failing that tilt back machine slighty open door and remove with a jug, remove filter uscrew and pull and check for foriegn objects i.e coins screws,whilst tilted back squeeze the two rubber tubes to the pump to make sure they are clear or unclip if need be MAKE SURE POWERS OFF lay some towels down sit machine back down slowly there will be excess water and with filter out run machine SPIN ONLY if it does you've solved your problem also check your waste and outlet pipe your waste could be pushed too far down the outlet pipe 6" is adequate enough.good luck
May 18, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi ZWC1300W Front Load w'Machine
is it spinning during spin cycle
your timer may have gone
Jan 18, 2009 | Zanussi ZWC1300W Front Load Washer
At bottom left of machine there is a small metal flap where you can drain off water. Next to that is a grey pipe you can keep pulling and pushing i have done this quite a few time and it has let out sludgey stuff put washing machine is now spinning and draining. Good Luck.
Aug 29, 2007 | Zanussi ZWF1420W Front Load Washer
Machine stops and goes to end half way through a cycle
Check the filter is not blocked it sounds as if it cannot drain in the time allowd at end of wash cycle. Regards Advisor
Jan 17, 2007 | Zanussi ZWF1430W Front Load Washer
Zanussi F1245W Front Load Washer Logo
320 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
