Question about Compaq Presario S3310CL (DF246AR#ABA) PC Desktop
I press the power button my PC and it starts beeping for maybe... 4 seconds, My hard drive crashed and i bought a new one.
  • gamefreek_91 Dec 19, 2008
    It was exactly what jmakris said, at least.. I think, It wasn't the video card, it was the ram. I took the ram out and put it into the other slot and powered on the PC. it started normally. Everything is fine now, i installed a clean copy of windows XP pro and it runs smoothly! All i need to do is get another stick of ram, new monitor, keyboard, mouse, and a bigger hard drive, 40GB is not going to last long. =]
    Thanks for your help!
    Im only 16, Sorry for the grammer and what not, im kinda bad at it =]
  • Roberta Smith
    Roberta Smith May 11, 2010
    do you happen to know the brand of bios... and count the beeps... long or short or both.... that should tell us what it is
    Robert
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
This usually happens when something gets knocked loose such as the ram modules or video card, if nothing displays on the monitor, then the video card is potentially loose (unless you are using the onboard video) If you have any cards plugged in to the motherboard, take them out and re-seat them (put them back in :-)
If the beeps continue after that, remove the hard drive and then power on the system - if something shows on the monitor, then you know the hard drive is not supported by that system
Posted on Dec 19, 2008
My HP xw4300 does not start?
What happens when you hit the power button to start it?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 02, 2012 | Computers & Internet
How too start my computer wen the power is interrupted
Apr 01, 2012 | Compaq Computers & Internet
How to start my computer wen iam not shut dow
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
Mar 31, 2012 | Computers & Internet
Hello,my laptop didn't get started it is charging
How do you know it is charging? What does it do when you hit the power button?
Mar 30, 2012 | Computers & Internet
CANNOT START THE CORRECT HARD DISK WAS NOT FOUND
To solve this problem follow these steps :
Step 1. Turn your PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later, then beep once more and turn off into standby again. Release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, then 5 seconds later beep again and then there will be 2 quick beeps together. Release the power button when you hear these 2 beeps.
Step 4. The PS3 will start up asking you to connect your controller via USB and press the PS button. Do this and then continue to the next step.
Step 5. The recovery menu will load. Select 3 "Restore File System". This will rewrite the hard drive system and hopefully get your PS3 working again. You shouldn't lose any save game data but that is not guaranteed. Ignore any messages about the hard drive being corrupt.
If the above method does not work try steps 1-4 again but select option 4 from the recovery menu. If that doesn't work as a last resort select option 5. Selecting this option WILL erase your data!
I hope this helps and thank you for using FixYa
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Corrupt hardhrive msg comes up and can not do anything
Follow these steps to try and bring your hard drive back to life :-
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later and then beep once more and turn off. When the console turns off please let go of the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, then beep 5 seconds later, then there will be 2 quick beeps together. When you hear these 2 quick beeps let go of the power button.
Step 4. The PS3 will start up asking you to connect a PS3 connector via USB and press the PS button. Do this and then go onto the next step.
Step 5. A menu will then load. Choose option 3 "Restore File System". The PS3 will restart and may report that your hard drive is corrupt, ignore this and click on "OK" to continue. Let the PS3 do its thing and hopefully when it restarts all will be well again.
If this procedure does not work, follow steps 1-4 again but on step 5 choose option 4. If this does not work try again but with option 5.
If none of these procedures work then I am afraid it looks like your hard drive may have become faulty. This will mean you will have to purchase a new one.
Hope this helps and thank you for using FixYa
What do i do when it says hard disc system is corrupted on my ps3
Ok try to follow these steps in order to restore your hard disks structure again.
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later and then beep once more and turn off. When the console turns off, release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, then beep 5 seconds later, then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
My ps3 has stopped working! It says: "Cannot start. Correct hard disk not found." Please, please, please can you help??? Many thanks, Mark & Michelle
Ouch, Bad news Mark and Michelle. This is a fatal error on the hard drive. Basically, the hard drive needs to be replaced :( Sorry
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
I press the power button, the computer beeps 4 times and stops
Please check the battery. You might have to replace the battery bcos it definately gone bad already.
Oct 11, 2009 | HP Pavilion dv6000z Notebook
Compaq Presario S3310CL (DF246AR#ABA) PC Desktop Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
