Question about HP Computers & Internet
Why won't my hp turn on?
I have an hp pavilion dv5. it was working about 15 minutes ago, but for some reason it will no longer turn on. i've tried playing with the battery and chargers, but nothing will work.
  • 55 Answers
The 1st thing to try is to make sure that the outlet you are plugged into has power. Try plugging in a lamp or fan or something and ensure that it powers on.
2nd some power packs have a seperate power cord from the power pack that may come loose ensure that it is plugged in tight if you have this model of power pack
3rd is to check the power pack you are using. The easiest way to do this is with a volt meter if you have one. They output in DC so ensure that you have it set to DC on the dial. If you do not have a volt meter check if there are any lights on the power pack that should light up when it is plugged in. If there are no lights on the power pack then there is not much of a way to check the power pack without a volt meter.
The last thing it could be would be the charging or power circuit of the motherboard. This would only be able to be diagnosed by a certified repair technician. If the laptop is still under warranty you will want to contact HP to have this checked.
Posted on Dec 19, 2008
I have a question HP Pavilion DV5 Full
That is you WLAN card (Wireless locale area network card) it is what makes the laptop conect in hotspots.
Oct 23, 2013 | HP New Pavilion DV5-1000 DV5 Series Silver...
My HP Pavilion dv5 1125nr laptop won't boot up. The screen never lights up when the power is turned on, the little hard drive light next to the power light doesn't flash at all (normally it flashes...
check by removing the battery then put it back again power it on, or without battery power it on directly then check, if still the same problem, the fault is in the motherboard of the laptop, better take it the service center or consult some technician in your area
Aug 02, 2011 | HP Pavilion dv5-1125nr Notebook
Pavilion dv4000 PC Notebook: My hp pavilion dv5 laptop runs very hot and then t...
The easiest way to clean it is to use a can of compressed air and blow it through the airflow vents.
Check out this link for other solution.
http://bootmylaptop.com/laptop-shuts-off-after-a-few-minutes/
May 18, 2010 | HP Pavilion dv4000 Notebook
Hp dv5-1002 laptop will not turn on. I've tried removing the battery. but wont turn on at all.
This could be because of a loos RAM. I would suggest you to take the laptop to the HP Pavilion Service Center. And If the issues is same as what I suspected, then the service center might be able to fix this issue in just 10 minutes and they might not even charge you for this. Please note, only go to the authorized HP service center.
Mar 11, 2010 | HP Pavilion dv5-1002us Laptop PC
Problems with HP HP Pavilion dv5-1159se 15.4
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 29, 2009 | HP Pavilion dv5-1159se Laptop
I bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
Aug 05, 2009 | Computers & Internet
My Hp pavilion DV5 Wireless is not working. The wireless assistant says its on, but its not on. Tried turning it off and on but it doesn't let me. Help Please
Have you tried deleting the wireless card from the hardware manager and then rebooting? It should reinstall it upon reboot and rewrite it's config file.
Apr 29, 2009 | HP Pavilion dv5-1000us Notebook PC
Computers & Internet Logo
48 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
