Question about Furuno 1650wf/Nt Gps/Chartplotter/Fishfinder
How can I connect my chartplotter to my flatscreen tv
I own a Furuno Chartplotter model 1650 which is mounted on the flybridge of my boat. I want to hook it up to a remote screen in the cabin to view from the lower helm. I have a flat screen TV by the lower helm...can I hook the two together?? How??
    New Friend:
  • 132 Answers
Absolutely not! sorry that is the answer, no video out available period
Posted on Jan 18, 2010
Where can i get a manual for a furuno gp1650 chartplotter
Here is a link for the manual.
http://www.furunousa.com/ProductDocuments/GP1650%20GP1650D%20Operator's%20Manual%20N3.pdf
If the link doesn't work go to furunousa.com and enter unit model number in search bar. Select the unit then select the manuals and documents tab. Operation manual is there and can be viewed and/or downloaded in pdf format.
Nov 04, 2013 | Furuno Boating
Furuno FCV627
Yes, using a NMEA connection between the two units. Refer to you owners manual on how to set this up.
Jul 24, 2013 | Furuno FCV627 5.7" Color Sounder 50/200KHZ
My Furuno gp1650wf chartplotter is showing the wrong speed in knots. It shows 20 knots when we are doing 28 knots. At an estimated 42 knots it says 32 knots. I have cleaned the GPS plug and the gps...
Congratulations the device is within functionality. As a matter of fact devices without shark lense are least impactful. For example, the device may least capture images or receive data in realtime however provides accurate flight resources.
Jul 24, 2011 | Furuno 1650wf/Nt...
How many pins on the furuno 1650F?
depending on which port you are referring to: The power has 3, the datas have 6 and 7 and the transducer plug has 10 pins.
Sep 07, 2010 | Furuno 1650wf/Nt...
My furuno chartplotter is out about 2 km on the chart how do i correct this problem it is a furuno 1650wf
Make sure your time offset is correct and also make sure you have not accidentally offset the chart. Also keep in mind that there are places in the charts that you can overzoom which can also cause this problem.
Feb 25, 2010 | Furuno 1650wf/Nt...
Can I use my furuno gps navigator to supply position data to my rdp-139 chartplotter and if so which wires need to be connected
Yes the output forom the Furuno GPS (like a GP31) will be yellow and green, hook these to theinput on the plotter blue (or black) and white. Use Data1 on potter as the input and select a nav source of "ALL" in setup menu.
Jun 05, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Navnet 500
I have been doing some research and I haven’t been able to determine if the Garmin has a compatible output for your Furuno. I can not recommend any service center particularly since I have no idea where you are located, but any good marine shop should be able to help you.
The Furuno uses NMEA Inputs for the GPS, and like I said I haven’t been able to determine if that Garmin uses that as an output. I would suggest that you inspect your installation to determine if there are any cableing between the two units. If no wires connect the two that you can be sure that the units are not communicating.
As far as the chartplotter goes you can buy data cards for them, either on-line or from a good marine supply store.
Apr 03, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno 1650wf/Nt Gps/Chartplotter/Fishfinder Logo
257 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Furuno Boating Expert? Answer questions, earn points and help others
