THE SHIFTER SHIFTS OUT OF PARK BUT WONT SHIFT BACK INTO PARK
On my '96 Olds 98, brake transaxle shift interlock is simply a pain in the ***. Solution: always press foot brake AND parking brake hard and hold while shifting into park and shutting down engine. Try not to park "downhill." Read owners manual;"shifting out of park." This even calls for opening and shutting the door! If you can't start in park, try neutral. If all else fails, unhook red battery cable for a minute. Re-attach and restart car, which should re-set computer to recognize your key, which has a computer chip embedded in it. Worst option EVER invented!
SOURCE: The gear shift is locked
It has a brake-transaxle shift interlock. You should just push the brake in to shift, but if you have done that, and it still won't shift, with foot on the brake, push the shifter all the way into park. Sometimes they don't always go into park all the way. Also if you park on a hill, it puts pressure on the btsi, so you cant shift it. Have someone push the vehicle back, just enough to take the pressure off and it should shift. I had this happen to me with my Grand Am.
SOURCE: can't shift out of park
the switch under the shifter is sticking.something might have got spilled.if you can get cover off and take some parts cleaner spray and spray around the switch this should loosen the switch up this happens more frequently than you might think good luck!
SOURCE: How to shift the transmission from park to neutral manually.
there is a shift linkage on the tranny ,look for the end of the cable on the tranny turn the linkage by hand , should be on top or right on front side.
SOURCE: Car starts and runs fine. Wont shift out of park.
CHECK BRAKE LIGHT SWITCH FUSE AND THE BRAKE TRANSMISSION SHIFT INTERLOCK SOLENOID FUSE.IF THEY BOTH CHECK OUT OKAY.YOU HAVE A FAULTY BRAKE LIGHT SWITCH OR FAULTY BRAKE TRANSMISSION SHIFT INTERLOCK SOLENOID.
The
shifter needs to be inspected. The shifter assembly is got misaligned, it has
to be open and realign.
There
are many other possibilities. But if it was working right up till now and
suddenly this occurred then its shifter
assembly alignment issue.
Also
i suggest you to refer these gear shift issues, which are mostly noticed. These
are direct links with appropriate solutions to
the specific problems of gear ****.
GEAR SHIFT ISSUES
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
The
There
Also
GEAR SHIFT ISSUES
Thanks.
The
shifter assembly is got misaligned, it has to be open and realign.
There
Also
GEAR SHIFT ISSUES
Thanks.
GEAR SHIFT ISSUES
Gear
indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of
Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
Automatic transmission will not go into high
gear?
Car won't downshift sometimes?
Buick Park Avenue: Transmission will
Not shift into drive?
No
First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key
is turned ON?
Third gear missing and engine losing power?
Chevrolet silverado has whining sound in gear?
2002 Chevrolet Avalanche Z71: Gear shift
Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
Car hard shift at slow speeds?
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold
mornings?
2000 Nissan maxima shifts hard?
Vehicle noticed sluggish delayed shifts while
driving?
2007 Hyundai Santa Fe: Will not Shift out of
Park Mode?
==========These details will help.Thanks.
Transmission not engaging in first
gear?
Vehicle only goes
in First gear?
Engine will not go out of park mode?
Car stuck in park?
Car will not come
out of Park?
Automatic
transmission will not go into high gear?
Car wont downshift
sometimes?
Transmission
will shift into drive?
Auto wont shift
from park?
Car Transmission
Shift indicator
directly goes to 2nd when key is turned ON?
Third gear missing
Vehicle has whining sound in gear?
transmission?
hard to move on cold mornings?
Gear shifts hard?
delayed shifts while driving?
This will help.
Thanks.
