Question about AT&T E5813B Trio Cordless Phone
Change Date Hi, It's obvious on how to change time, when you hit the clock button, you can also change day and year but not date.
5 Suggested Answers
SOURCE: durabrand ph 3238 how do i change date
I use it with voip (computer) and it updated by itself.
Posted on Jun 11, 2009
consultel1
  • 860 Answers
SOURCE: how do I change the date
Changing the date on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#101"
the display should say system date and the current programmed date
enter the new date in mmddyy format
press feature "00" to logout
Posted on Nov 20, 2009
  • 102366 Answers
SOURCE: AT&T phone and answering machine combo 9351 need instuction manual to reset time and date!
9351: http://telephones.att.com/docMgt/public/art/339/9351_manual.pdf
1818: http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=286
Posted on Jul 22, 2010
  • 68 Answers
SOURCE: BIS 34-D phone - Display window blinks date time beeps multiple times/day
The display will blink if power is cut either by unplugging or if the control system is power-cycled. The cause of the power glitches needs to be located & corrected. Changing the ring tone/cadence depends on which control unit is being used.
Posted on May 12, 2011
How doI set the clock
Setting the Time (Without Date Display) If your vehicle has an AM/FM base radio with a single CD player and preset buttons numbered one through six, the radio will have a clock button for setting the time. You can set the time by following these steps: 1. Press the clock button until the hour numbers begin flashing on the display. Press the clock button a second time and the minute numbers will begin flashing on the display. 2. While either the hour or the minute numbers are flashing, turn the tune knob, located on the upper right side of the radio, clockwise or counterclockwise to increase or decrease the time. Instead of using the tune knob, you can also press the SEEK, FWD (forward), or REV (reverse) buttons to adjust the time. 3. Press the clock button again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing will stop after five seconds and the current time displayed will be automatically set. To change the time default setting from 12 hour to 24 hour, press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H are displayed, press the pushbutton located under the desired option to select the default. Press the clock button again to apply the selected default, or let the screen time out. Setting the Time (With Date Display) If your vehicle has a radio with a single CD player or a CD with DVD player, the radio will have a clock button for setting the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the clock button and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) will appear on the display. 220 3. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. If your vehicle has a radio with a six-disc CD player, the radio will have a MENU button instead of the clock button to set the time and date. To set the time and date, follow these instructions: 1. Turn the radio on. 2. Press the MENU button. Once the clock option is displayed. 3. Press the pushbutton located under that label. The HR, MIN, MM, DD, YYYY will appear on the display. 4. Press the pushbutton located under any one of the labels that you want to change. Every time the pushbutton is pressed again, the time or the date if selected, will increase by one. • Another way to increase the time or date, is to press the right SEEK arrow or FWD (forward) button. • To decrease, press the left SEEK arrow or REV (reverse) button. You can also turn the tune knob, located on the upper right side of the radio, to adjust the selected setting. The date will not automatically display. The only way to see the date is by pressing the MENU button and then the clock button when the radio is on. The date with display will time out after a few seconds and go back to the normal radio and time display. 221 To change the time default setting from 12 hour to 24 hour or to change the date default setting from month/day/year to day/month/year, follow these instructions: 1. Press the clock button and then the pushbutton located under the forward arrow label. Once the time 12H and 24H, and the date MM/DD/YYYY (month, day, and year) and DD/MM/YYYY (day, month, and year) are displayed. 2. Press the pushbutton located under the desired option. 3. Press the clock or MENU button again to apply the selected default, or let the screen time out
Nov 10, 2016 | 2007 Pontiac Torrent
Tip
Change time and date
Hold down the time or month/date buttons, then press either of the '<< or >>' (by CD controls) to move the time, or month/date. To change the year hold down both time and month/date buttons together to adjusting the year using the '<< or >>' buttons.
on Sep 04, 2013 | Brookstone CKD5810A Clock Radio Smart Set...
I have a DATEXX DRC-605 Exactime clock that just changed the date to two days ahead for some reason. How can I change it back to correct date?
Please follow these steps:
* Press and hold MODE button for 3 seconds: the year digit will flash.
* Press UP ( + ) or DOWN ( - ) to change flashing digits.
* After the first value is set, press MODE button again to confirm and move to the next parameter.
* Continue setting month, date, hour, minutes and temperature display format.
* Press MODE button for the last time to return to the time of day with seconds, after the last parameter is set.
I hope I could help.
Thanks.
gylacz
Aug 22, 2011 | DateXX DRC-608 Clock Radio
I plugged in my Emerson Smartset Clock Radio (model CKS2005) and the date is off by a couple. Today is August 4, Thursday, and it states August 7, Saturday. How do I change the date? The date button is...
You have to run the clock back. Press Time/Date and then press up or down after you run it 24 hours the date will change, and the date will move day to day.
Aug 05, 2010 | Emerson Smartset Clock Radio
Can't get the day of the week to go with the month and date
You have to set the calendar for the correct year. To see the year, you have to press the time & month/date buttons altogether. You will see the display change from month/day to year. Use the set+/Set- buttons to change the year to the correct calendar year. This will fix the day to work with the month and date.If you keep having this problem, you will need to change the internal battery. I hope this information help you with your problem.
Apr 08, 2009 | Emerson Smartset Clock Radio
Digital settings
Buttons are: A or Adjust (10 o’clock position), B or Time Memo (2 o’clock), C or Mode (8 o’clock), D or Receive (4 o’clock) and L or Light (6 o’clock)
To manually change time, date, year, month and day, hold A until beep and city code appears; press A again until 12H/24H flashes; press C to cycle through options as hour, minutes, year, month, and day flash; use B or D to change flashing option.
Aug 03, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Changing the date
Hi here are the steps to change the date and time
1.Press Menu
2. Use the < or > buttons to select System Setup and press the check button.
3. Use the < or > buttons to select Time/Date press check button
4.Use the < or > buttons to select the 12 oclock or 24 hour clock and press the check button.
5.Use the alphanumeric buttons to set the current time.
6.Use the alphanumeric buttons to set use two digits to specify the month,day and year and press check
Hope this helps.
Nov 05, 2007 | HP LaserJet 3050 All-In-One Printer
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Canon P170-DH
I played around with mine and found the keys that you change the time and date with by looking over the top of the keyboard. On my model there is a time and date key that has a little calendar and clock actually on the key. That key allows you to switch between date and calendar. After you click on that button you will either see a date or time. To change those numbers use the following keys: The equal (=) key will change date and time by holding the key down till the numbers on the display start to flash. Once they start to flash use the number keys to make your changes. The multiplication (X) key you can use to change am and pm. If you want military time use the division key. If you are changing the date there is an additional key that lets you change the format. What this means is the sequence on the display by the way you view the month, date and year. You can change it so year shows first then month and date or interchange day and month. Once I found those keys it was easy.
Jan 28, 2007 | Canon P170-DH Calculator
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Nov 04, 2006 | Canon MP-25DV Calculator
AT&T E5813B Trio Cordless Phone Logo
18 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
