My lcd monitor died does nothing
The monitor just doesn't work i plugged in an old crt and am using that at this time. I want to know if any one knows if this is a problem with these product. I am looking to purchase a new monitor and i want to know if i should even look at another BenQ product?
  • 1 more comment
  • eawm Dec 19, 2008
    Yes the power light turns on but nothing else happens
  • eawm Jan 01, 2009
    bought a new monitor will look at the old one which still doesn't work at another time. Thanks tho.
  • nickpower
    nickpower May 11, 2010
    check ebay for inverter board, also could be power supply. that problem can happen with any brand!
    does the power light come on when u turn it on?
Try replacing the large electrolytic capacitors on the power supply board (should be 4-6 capacitors for 5 and 12v rails). This works in most cases.
Posted on Dec 19, 2008
I have a Dell 1704 FPVt monitor I use it in conjunction with an touch board with a monitor split cable. when I plug the team board in the dell monitor goes blank. It doesn't do this with the old m
Isolate the problem per above. Eliminate the monitor, split cable and software settings so that each, individually work. Then eliminate team board - do you have a spare?
It could mean sharing the monitor signal means weakens it so that one can display and the other does not work. Prove it with a different source computer. Don't know if buffer devices exist or how to increase input sensitivity.
Mar 07, 2013 | Dell 1704FPVs 17" TFT LCD Flat Panel...
I have a black spot on my crt samsung monitor screen
I know some people still prefer old CRT monitors over more modern LCD monitors even today. Unfortunately Cathode Ray Tubes or CRTs aren't serviceable since they are a factory vacuum sealed unit and this probably why no-one has replied. The black dot is probably a burn mark on the inside of the CRT if it's always there. When there's a problem with the CRT itself there's nothing one can do except replace the unit and it's not worth changing the tube as it will cost much more than the monitor is worth and anyway I'd be very surprised if they even bother making these old parts any more. One can buy 17" CRT monitors as cheap as 10 pounds and larger CRT monitors for a bit more at recycling businesses like Speedie Computers near Birmingham in the UK, so if you you still want to use an old CRT monitor, replacing the whole unit is certainly the best option. There's currently still an excess of old CRT monitors that need recycling after being replaced by newer LCD monitors and recycling companies like Speedie often have literally pallet loads piled up high and they'll be only too glad to let you take one or more off their hands for next to nothing. It's better if you can find somewhere local to yourself rather than purchasing online if at all possible or you'll probably end up paying more in postage than the cost of a replacement used CRT monitor because they're fragile, heavy and bulky to transport.
Sep 18, 2010 | Computers & Internet
CRT works but LCD doesnt
You may need a driver for your PC as lcd differs from crt. They have a different signal input so update the video card drivers and you should be good to go.
Jun 30, 2009 | Computers & Internet
Switched from crt to lcd, no display!
You need to install the Display driver shipped or downloaded from net.
Mar 31, 2009 | Samsung SyncMaster 171 V 17" Flat Panel...
Gateway monitor will not work on non gateway PC.
Joe,
It's could be the backlight inverter are busted...try plugged to another PC. If it still the same problems... Replaced a new backlight inverter or repaired it.
Oct 14, 2008 | Computers & Internet
KDS K717s 17" LCD Monitor
This is a common problem across many monitors, unfortunately. The problem stems from one of two things, typically.
Itis either the Power Inverter board (Inverter Mirage Electronics AD-1700Rev:F 200-000-170DTL1 VERSION:A) or a weak or dying backlight.
Ifyour monitor comes on for a few seconds then you can test the backlight byusing the controls to get into the backlight brightnes settings on theOSD and turning it WAY down.
If that doesn't work or if it won't come on at all then it islikely bad capacitors on the Power board mentioned above. If you feeladventurous and know how to solder then you might be able to fix thisyourself. You need to be careful however because you are dealing withhigh voltage in there and capacitors CAN hold a charge long after youhave unplugged the unit. You can read more about this power board aswell as how to replace the bad caps HERE.
Ifthat's not for you then I would recommend taking it to a local TV shopfor them to fix. The parts shouldn't be more than $20, but labor can beexpensive.
Jul 30, 2008 | KDS K717s 17" LCD Monitor
Monitor Flashes Gray, Then nothing
try to decrease the screen resolution. try to 640 x 480 then raise to 800 x 600. for old CRT monitor maybe have a problem with 1024 x 768. if decrease not work, then you might have a hardware problem, you need to purchase a new one. try the test first. maybe you can test with your monitor of your friends first :-), if work, you need to purchase a new one.
Feb 17, 2008 | Acer AL1916W 19" LCD Monitor
Unable to use intex external TV tuner with acer 19''
Frontech external Miracle TV tuner not working with LCD(ACER 15") monitor. Error msg "input format not suppoting". But CRT monitor (samsung 14") is working with the same.
Pl give advice mr.reghu@yahoo.com
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Blank sceen
No, because it sounds like the backlight has blown. These LCD monitors utilize a backlight, just like the florecent bulbs we see in office buildings. Alot smaller! These things can be repaired, but by the time you figure out how and when you track down the bulbs you would have purchased a new for all of that time. But they can be repaired!
Nov 26, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
450 people viewed this question
David Payne
David Payne
