Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Replaced bulb and still flashing redLED and no start-up
I ordered abulb from laptops for less. w/ applicable housing. Intstalled replacement bulb as per manual and no start-up only flashing red LED
Please advise. Circuit problem?? major repair??
  • 1 more comment
  • believer72 Dec 22, 2008
    I also bought a replacement bulb from Laptops for less and replaced my bulb. The TV works, but it will randomly shut down with no picture or sound. The green light will flash for about 20-30 seconds and then the TV will come on again. Could it be a bad bulb?
  • Anonymous Jan 07, 2009
    I got the replace bulb error light, bought a new bulb and now the TV works most of the time, but randomly will not start up and give the bad bulb indicator. Repeated attempts to start are eventually successful, so I know the bulb is not defective, there has to be something else wrong.
  • Any Guy
    Any Guy May 11, 2010
    ecallen007,
    How many times does the red light flash?
    believer72,
    It sounds like you either have a bad lamp or the one you bought is not installed properly
  • Sony Master
  • 5,138 Answers
Anthing is possiable when it comes to these sets / It could be your Fan going bad if so set will not turn on and run lamp.
Posted on Jan 02, 2009
The power button flashes lamp
Lamp bulb is failing. You should get a message to that effect, but sometimes if it has been replaced before it will not show it needs to be replaced. All you can do is replace the bulb, note that some of the newer replacement housing's are not exact fits, so you will need to modify it with the old housing. Good luck
Nov 28, 2014 | Televison & Video
Tv sound buzzing lamp
Contact any service technician.
Oct 09, 2013 | Mitsubishi WD-Y65 65" HDTV
I have a NEC VT700 projector. I replaced the bulb and housing because it would no longer turn on and the status light would blink every 2.5 seconds indicating the housing on the lamp had an issue. I...
I have solved that problems by replacing the plastic Lamp Cover. NEC says they wear out over the years due to the heat. If you have a spare VT700 about, swap covers and see if that works. or order one from NEC, thay cost 5 dollars.
Jan 12, 2011 | NEC VT700 Projector
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
I intstalled a new hard drive. When I attempt to
Make sure you have a compatible hard drive. They're not all the same.
Dec 08, 2009 | Dell Latitude D600 Notebook
Headlight plug w/all the wires coming of it continue to over heat and light blinks off and on. 1993 ford truck F350.I have replaced it twice and I have replaced several switches also each time the plastic...
the headlights flash due to high current draw. It allows you to get of road at night w/o having lights go out. Is it one headlamp doing this? Are both low beam bulb and high beam bulb on at the same time? If yes, it will melt housing. Otherwise look for short circuit. This assumes you did not put aftermarket high current bulbs in your headlamps.
Sep 25, 2009 | 1993 Ford F350
KDF-E60A20, picture and sound go out then re-appear every 30 sec
Was it just the bulb or the complete lamp assembly? If it was just the bulb you need to handle it with latex gloves to avoid getting oils from your hands onto the lamp.
Sep 10, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
My son and daughter in law bought a new home with all ge appliances and the dishwasher is americana. the dishwasher from the start has never worked properly. the water is cold and the drying cycle doesn't...
I agree, especially if it is less than 1 year old. See if the builder of the house will make arrangements for repair or replacement under his guarantee. If not then try the store or company that supplied the dishwasher. If the appliance was registered with the manufacturer when it was intstalled and if it is still under warrantee you should be able to get GE to handle it directly. Here is contact info for GE: http://www.geappliances.com/service_and_support/contact/
Jul 10, 2009 | Maytag Dishwasher
Changing fog light bulb
I just replaced the fog light bulb on my 2008 Azera. I went under the car and removed two screws from the protective shield. I pulled down the shield and reached up and turned the fog light socket and pulled it out of the housing, remembering which side the wires were on and removed the old bulb (Don't touch the new bulb with your hand) and replaced it with the new bulb. The job took less then 15 minutes
Aug 08, 2008 | 2002 Hyundai Santa Fe
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
