Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Delonghi EAM 3400 keeps saying "Empty Grounds Container"
I cant get it to change from saying "Empty Grounds Container." I have emptied the container and then put it back into the machine but regardless of what I do, it just keeps saying to empty it.
Is there anyway to get rid of this? Is there something that I need to clean besides the container? Is there anyway of resetting the machine?
  • Anonymous Mar 26, 2014
    Got a 5500 machine, the light wont go out for the grounds container even though it is empty and we have hovered the inside too??
I think the microswitch that sensors the front door is not activated. Try to find it and "give it a massage" The machine resets the counter for the grounds container every time the door switch is activated.
Rgds
Michael
Posted on Jan 17, 2009
    New Friend:
There is no microswitch in the front door of the DeLonghi 3400 and there is no microswitch that is touched by the little plastic piece on the bottom tray. The microswitch is at the back of the grounds container. The other answers were helpful in getting me to look in the right place but the only microswitch was where the plastic tab at the back of the grounds container go through a hole in the back.
I took the bottom off (good luck in finding a screwdriver or bit to remove the screws) unplugged the microswitch and cleaned it up and it worked for a while. I'm ordering the $8 microswitch and hoping everything works with no problems.
Posted on Apr 10, 2016
    New Friend:
The water tray sensor microswitch was stuck. Therefore the machine thought you had never removed the tray to empty ground. To fix:
  • Unplug the machine from power for safety.
  • There is a little plastic tab at the back middle of water tray sticking out next to the ground container tray. Slowly insert the water tray and observe this tab poking into a square hole near the bottom of the machine. That's where the sensor is.
  • Use a cotton bud (or a few) to clean the inside of this hole, especially the upper side where the sensor is.
  • If you insert the tray all the way in and hear a click, the sensor is cleaned. Close the door, plug machine into power and enjoy your coffee again.
Good luck
Peter H from Melbourne
Posted on Jun 01, 2015
I am house sitting and do not know where Delonghi Perfecta Cap. machine's grounds container is located? indicator says to empty now...
Hello, Jean -
Delonghi makes a number of different cappuccino machines. If you had stated the model number of the machine, I probably could have found you the manual for the homeowner's machine online.
I found a user's manual for the Delonghi ESAM5500. The manual has an illustration which shows where the grounds container for that machine is located. If the homeowner's cappuccino machine is not an ESAM5500, the grounds container for their machine may be in a similar location.
This is the link to the user manual for the Delonghi ESAM5500:
http://kavegepbolt.hu/shop_ordered/9160/pic/Saeco/DELONGHIESAM5500.pdf
It is a PDF document, so you will need Adobe Reader software (free).
Page 17 of the manual talks about how to clean the machine, including cleaning the grounds container. In the instructions part A9 (which is illustrated on Page 3 of the manual) is identified as the grounds container.
Just to be sure, if you can contact the homeowners, do so and ask them where the manual for their cappuccino machine manual is located, so you can refer to it and so that you do not accidentally damage the machine.
Best wishes.
Feb 09, 2018 | DeLonghi Coffee Makers & Espresso Machines
Empty ground container issue
Once you have the drip tray out and the grounds container out - look inside the unit and clean any grounds that are still in there. Look for a switch that might be sticking (because it's cover with coffee residue) clean everything and check for freedom of movement.
Nov 27, 2014 | DeLonghi ESAM6620 Prima Donna Bean-to-Cup...
Descale eam3400 delonghi magnifica machine
Hi, you need to select descale procedure from menu options and then add descale solution usually 100-125ml to 1l of water to your tank. Also you should find this how to do in instruction manual.
Jun 28, 2014 | DeLonghi EAM3500 Espresso Machine/Coffee...
How to discale the unit
Delonghi EAM, ESAM, ECAM, Nespresso
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the appliance displays the message:
DESCALE
you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the button (the light over the button comes on) then press the button repeatedly until
the appliance displays:
DESCALE No
• Press and the appliance displays the message:
DESCALE Yes
• Press the button to start the descale programme.
• Empty the water tank and add the contents of one bottle (125 ml) of DURGOL descaler plus
one litre of water. For subsequent descaling, use descaler of the same type and brand as supplied
(available from technical service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
• press the button. Descaler runs off from the hot water spout into the container below. The appliance
displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RISRINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the programme must be started again from the beginning. Empty the water tank, rinse, fill with
clean water and run off a cup of hot water.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE GUARANTEE.
Jan 01, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Descale
DESCALE
Proceed as follows:
DESCALE No
DESCALE Yes
displays:
RINSING FILL TANK
Proceed as follows:
RINSING
Nov 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi Magnifica Light B12 in manual states that
I had a problem where the machine would not operate and the water and grounds lights were on steady (red). After contacting customer support, they directed me to do a reset. This is done by disconnecting the power and holding down the ground coffee and decalcification buttons while reconnecting power. Then release the buttons and power on the unit. This revived my Magnifica from the dead, maybe it will work for you...
Nov 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Eam 3400 'less coffee' message on display
turn the dial inside bean container too 3 .. if still doing it u need grinder seen too.. bsc appliances 07779933829 we cover repair services anywere ..
Nov 28, 2010 | DeLonghi EAM3400 Espresso Machine
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Descale
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Delonghi EAM 6600
You need to descale the machine with descaling solution.
look at following link for instructions
DELONGHI
May 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
7,881 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
