Question about Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax
Scanner Not Working
I have all the appropriate functions installed, but when I click scan it keeps telling I have no paper in the feeder when I actually do. I'm also not sure where to press the 'start' button.
    Problem Solver:
  • 6 Answers
The application currently assigned to the Scanner Not Working - font93.gif Start button has the Start button icon added to its application icon.
Posted on Dec 19, 2008
Feeder in my canon mg5250 is not working properly. It seems to feed one side and twists the paper and then sticks.
Did you check, nothing is in the paper feeder? Could be just a little piece of paper or a staple is blocking proper functioning of the feeder.
Keep the paper try clean and take care you never drop or leave anything in the printer, that does not belong there.
Mar 08, 2014 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Am unable to use the feeder tray - it keeps saying paper jam. There is no jam -- something seems to be blocking the mobility of the paper. I have it on "office" use and the regular scan works one...
Click on the link below and download the User guide which will help you solve the paper jam problem.
User Manual
The above link has complete information for your Epson Scanner.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 13, 2010 | Epson Perfection 4490 Office Flatbed...
Fi-6140-Rollers keeps moving even when doc feeder is empty.
There may be a piece of paper stuck in the sensor area, the scanner assumes there is paper and it keeps working. Blow gently and remove all shreds of paper.
S. Mohan
Aug 09, 2010 | Fujitsu fi-6140C Document Scanner Flatbed...
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    Canon DR-9080c scanner not lifting error no page found in feeder
    There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
    S. Mohan, India
    Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
    Print OK - Scanner Problem
    I have the same machine and I can not fax or scan. Do I need special software?
    Jul 02, 2009 | HP LaserJet 3015 All-In-One Printer
    Will not scan from glass but feeder will?
    Using your scanner program such as PaperPort, you really have to pay attention on where the document/photo is located for scanning.
    Steps
    1. Click on Start, Programs, Paperport
    2. Right above the Word "SCAN", you will have several options on;
    a. Document or Photo
    b. Flatbed or Feeder
    3. Once step 2b has been selected, the M20i will scan your document per your instructions.
    Note:#1
    If you place your document on Flatbed but your selection on your screen says "Feeder" where do you think the scanner will look for your document? The answer is --> Feeder!!!
    Note #2
    Make sure that you click Accept,& DONE, other wise M20i will just sit and wait for your next command.
    I hope this resolves the confusion between GLASS and FEEDER scanning.
    Jun 29, 2009 | Xerox WorkCentre M20i All-In-One Laser...
    I have a brother mfc-7420 flatbed and am trying to scan multiple pages through the automatic feeder but it only scans whats on the flatbed? Is the feeder only for copies and not for scans? Anything i can...
    First install everything, than go to my computer at the bottom u will have Scanners and Camera, click on Brother MFC-7420 USB
    Than if the window pop ups than click on Microsoft Scanner and Camera Wizard
    Now u will have new Window "Scanner and Camera Wizard" click Next
    On next page u will see Choose Scanning Preferences in there u will find "Paper Source"
    click on the Scroll down option and pick "DOCUMENT FEEDER" and Click next
    than hopefully u know wat to do pick the name fro scans that u going to make pick the folder to place it in and it will start scanning by it self and will send i to ur computer.
    And put ur Scan paper with the side that u wanna scan FACE UP in the FAX tray which is on the Top or all in one Printer
    Dec 02, 2008 | Brother MFC 7420 All-In-One Laser Printer
    No Paper in Document Feeder
    I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
    May 23, 2008 | HP LaserJet 3055 All-In-One Printer
    Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax Logo
    48 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
