Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My tv zooms in and changes the format.
When it does this it cuts off the sides top & bottom of the screen. so people may have their heads cut off or words cant be read
  • mgaquality Dec 19, 2008
    it changes by itself Im not doing it. i cant change it to just a regular format. thats what i want.
    Sergeant:
  • 233 Answers
This is normal - you are zooming in on the picture. Most people use the zoom feature to "stretch" a widescreen movie so it will fit the screen.
Posted on Dec 19, 2008
  • Josh Crager
    Josh Crager Dec 19, 2008
    have you tried checking the buttons on the front of the tv? alot of the time they can become collapsed and will make contact at will. If this is the case you can either remove the aspect button completely and just use the remote, Or for testing purposes, unplg the switch panel completely .
Insignia 32" 720p Flat-Panel LCD HDTV - High-Gloss Black Picture is too big for screen ,cut off all around, top, bottom and sides. Can't read things on screen, heads cut off etc. I've gone through...
try checking the menu setting on your Dish Network, there may be a television format in that menu set up, if it is only when a dvd player is playing, then check the format on that, so on so forth... that is one place to start, check if it is local (TV) or if it is from attached component ( Dish dvr/ dvd etc). also refer to your owner's manual.. if all else fails, call customer service @ insignia
Oct 17, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Cuts off bottom/top of videogames
that is because video games are not made for tv's that you use for tv
Jan 11, 2010 | RCA P52937 52" Rear Projection Television
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
My TV picture cuts off on the top and bottom
Check what format you are in. 4:3 is like a regular tv. Sides will be cut off in this format on a widescreen tv. 16:9 zoomed will cut of top & bottom slightly. You want just regular 16:9. No zoom.
Apr 08, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Picture format to large
There should be a format button on your remote to change between widescreen & fullscreen as well as the zooms. May say format or aspect. If not on remote look through your menus. Make sure which ever u select u do not choose a zoom. This will cut of top & bottom of picture
Apr 06, 2009 | Televison & Video
Mitsubishi WS-55513 55 in. - Picture to latge for scheen
Change your Display Format (widescreen mode) . You're using ZOOM. Press FORMAT on the TV remote control to cycle through the available display formats.
Feb 09, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
IMAGE IS ZOOMED ON SCREEN
use the format button, might be called screen size. You are looking at a format that the screen cannot show completely, I can cut the top and bottom off or make it widescreen and lose the edges on my TV
Feb 24, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
318 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
