Question about Dell 1700n Laser Printer
Printer problem -Dell Laser printer model 1700.
Printer image shifted 3/8" to the right. How do I get it back. Is there some adjustment I can do.
  • smithmanor Jan 28, 2009
    My margins shifted to the right on my dell 1700n printer. Paper tray is set ok.
  • Anonymous Mar 16, 2009
    no!
    Genius:
  • 2,120 Answers
Make sure the side guides in your paper tray are tight against the paper.
Posted on Dec 20, 2008
5mm vertical gap dell 1720dn
Any time an imaging drum is replaced on a 1700, 1710, or 1720 model dell laser printer, you must reset
the photoconductor count. The following procedure illustrates how this is done:
1. Open the front access cover
2. Press and HOLD the Cancel Button (Red X)
3. When you see the LED's 'Chase' turn the printer off
4. Close the access cover, and turn the printer back on
5. Press the Continue Button (Green Triangle) to print a settings report
6. Under the section 'Cartridge Information', locate the item 'PHOTOCONDUCTOR COUNT=0K' indicating 'Zero Thousands'.
s now been reset, and you should now be able to print now ok
May 06, 2014 | Dell 1720dn Laser Printer
I have a Dell 1700 printer - it was showing an error and when i pressed the green button it printed a help guide. This said that i needed to replace the imaging drum and it would no longer print until this...
After you replace the imaging drum, you should reset the imaging drum's counter. To
reset the counter, press and hold the Cancel button until all lights flash in sequence.
May 03, 2011 | Dell 1700 Laser Printer
I have a Dell 1710 printer. My laptop crashed so I took it in to get fixed. Got it back today and now it no longer shows my printer. How can I reinstall my printer without a cd?
Go to www.dell.com . At the very top right edge of the page you'll see technical support. Click on that, on the page that you are taken to, click on the green "Start here" button under the Home Users section. Click on Drivers and Downloads, click on the green Select Model button. Under "Select your product family" click on printers, click on the printer, click on 1700 mono laser printer, click on the green "Confirm" button. Select your operating system and you'll see all of the drivers and firmware updates available for your printer.
Aug 10, 2010 | Dell 1700n Laser Printer
Photoconductor kit? Dell 1700 printer
The photoconductor kit is another word for the drum or imaging drum. All three words refer to the same part.
Here is a link from the Dell site for this model.
http://accessories.us.dell.com/sna/PopupProductDetail.aspx?c=us&l=en&cs=dhs&sku=310-5404
Once you replace the drum, the printer has to be manually reset. If this is not done, the printer will continue to give this print out. By resetting it, the counter is set back to zero. The drum is good for around 30k prints.
From the Online Manual for the 1700, to reset the counter:
http://support.dell.com/support/edocs/systems/1700n/en/index.htm#online_documentation
To reset the counter, press and hold the Cancel button until all lights flash in sequence.
NOTICE: Resetting the imaging drum's counter without replacing the imaging drum may damage your printer and void your warranty.
Jun 18, 2010 | Dell 1700n Laser Printer
Printer will only print from one program (it will not print from microsoft office or anything), however when it does print from this program, the document is overprinted with either computer code (I am...
have you set the dell 1700 Laser Printer as your default printer? Go to printer & faxes, right click on dell 1700, choose "set as default printer"
Apr 10, 2010 | Dell 1700n Laser Printer
System shuts down when printing to dell 1700 laser printer
You may have a 'recalled printer' Check out this link!
http://support.dell.com/support/batteryrecall/index.aspx/en/main 1700/1700n Printer RecallIn cooperation with the U.S. Consumer Product Safety Commission, Dell is voluntarily providing the Customers who purchased the 1700/1700n printer (from June 8th, 2004 - August 18th, 2004) a free replacement printer. [Announced September 7, 2004]
May 11, 2009 | Dell 1700 Laser Printer
Dell 1700 image drum
After you replace the imaging drum, you should reset the imaging drum's counter. To reset the counter, press and hold the Cancel button until all lights flash in sequence.
Dec 13, 2007 | Dell 1710n Laser Printer
Flashing lights
you can try calling Dell support at Technical Support 1-800-624-9896 to verify if the problem is electrical. We had a customer have the same problem after he replaced the imaging drum we found out that the unit still had the problem. He finally figured out that the unit has been exposed to an electrical surge and it caused a problem with the board inside the unit. I would try using a new imaging drum but if the unit is still covered by Dell I would have them replace it.
May 18, 2007 | Dell 1700 Laser Printer
Dell 1700n Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
