Question about HP OfficeJet 6110 All-In-One InkJet Printer
Original jam error keeps displaying but nothing is jamed, I try to reset the wole printer by pluging it while pressin #+6 or #+3 but it thinks that the buttons are stuck.
    Problem Solver:
  • 6 Answers
There is paper jammed in the machine or something is blocking the sensor for the paper path.
Remove the obstruction (try a vacuum cleaner nozzle down the feed path) and the machine should be right again
Posted on Dec 19, 2008
My paper keeps jaming
paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
Nov 09, 2010 | Brother MFC-3240C All-In-One InkJet...
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
Hp 3210 is leaking magenta
Resetting the printer. After the Ink Service Module has been replaced, trigger level 1, 2a, 2b, or 3 will still be displayed when the printer is turned on. Reset the printer to remove the trigger level messages.
CAUTION: Do not reset the printer if the Ink Service Module is not replaced. The spittoon may overflow. Follow the instructions below to reset the printer.
  • Turn on the printer
  • Press and hold down the Cancel button
  • While holding down the Cancel button, press and hold down the Resume button
  • Hold the Cancel and Resume buttons down for 8 seconds and then release both buttons. The Right Print Cartridge LED and the Resume LED will go off and the printer will return to a Ready state.
  • When the printer returns to the Ready state, it indicates the printer was successfully reset.
    OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech...
    James Cowan: HP error code 0xc18a0001
    Earnest: I will assist you in this regard. I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
    James Cowan: Correct
    Earnest: May I have the model number of All-In-One you are using?
    James Cowan: c6250
    Earnest: Please let me know the room temperature in which printer is replaced
    James Cowan: 67 degrees F
    Earnest:: OK. Please perform the below steps on the front panel of the printer to resolve the issue
    James Cowan: OK
    Earnest:: Press and hold the "left arrow" key. Press the "Setup" key and release both keys, display should say "Enter Special Key Combo". Press and release the "OK" button
    Earnest: Please ignore the above steps
    James Cowan: OK yes nothing seemed to do anything
    Earnest: Please perform the below steps on the front panel of the printer. Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo". Press and release in sequence"Red Eye Removal", "Print Photos", "Red Eye Removal"
    Earnest: Display should say "Support" and display the FW rev (something like R0616R)
    James Cowan: COxxFN0723BR
    Earnest: OK. Press and release the right arrow button until the display says "System Configuration Menu"
    James Cowan: OK
    Earnest: Press and release the "OK" button
    James Cowan: OK and it says hardware failure status
    Earnest: Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Please do not try to print at this stage
    James Cowan: OK
    Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Let me know once you are done with the above steps
    James Cowan: OK its unplugged
    Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "Use POWER button to shutdown the printer" followed by "Press OK to continue". Press OK
    James Cowan: OK
    Earnest: Let me know the message displaying on the front panel of the printer
    James Cowan: printer preparation occuring - do not interrupt
    Earnest: OK
    James Cowan: OK its done
    Earnest: Let us print a self test page from the printer now
    James Cowan: OK deal
    Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray
    2) Make sure that the printer is on and loaded with unused plain, white paper
    3) Press Setup. The Setup menu appears
    4) Press the down arrow button to select Tools and then press OK
    5) Press the down arrow button to select Self-test Report , and press OK. The self-test report prints
    James Cowan: OK printing
    Earnest: OK, please check whether all the colors pritned perfectly on the test page
    James Cowan: Perfect
    Earnest: Great... Cheers!!!
    James Cowan: Thank you very much
    Earnest: Now you can continue using the printer.
    Sep 25, 2009 | HP Photosmart 3210 All-In-One InkJet...
    "Clear paper jam" error, but there is no jam!
    Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
    May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
    E appears on my printer
    why dont u contact cannon abt r problem i can not think of anyhing but hte cannon printers is faulty.........
    Oct 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    hi,
    CANON PIXMA MP160 All-In-One InkJet Printer
    has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.canon.com/printer/prob676ijt65/solution
    prirweto-i-23
    Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    Carriage jam
    Try this (it may not work) -
    Perform a Semi-full Reset on the unit by following the steps below:
    1. Make sure that the unit is on, and disconnect the power cord from the back of the unit.
    2. On the unit keypad press the # and the 6 keys simultaneously and hold both keys down while plugging in the power cord.
    3. The Semi-full Reset message will appear on the unit display.
    Wait until the unit initialization process is complete. The unit will have recovered its original settings.
    I've had this error before and had no obvious fault with the carriage (it moved freely and the encoder strip was in place) i managed to clear the error by stripping the printer down and cleaning around the service station area
    May 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Canon mp 130 paper jamed
    Step1
    Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
    Step
    Turn off the printer.
    Step
    Remove any paper trays. Inspect them for wrinkled or damaged paper.
    Step
    Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    Step
    5
    If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
    Step
    6
    If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    Step
    7
    If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
    Step
    8
    Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    Step
    9
    If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    Jan 31, 2008 | Canon PIXMA MP130 All-In-One InkJet...
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    149 people viewed this question
    Ben Johnson
