I want to test the control Htp defrost and thermal fuse thermostats located on the heating coils, there are two thermostats moulded into one, pair of blue wires and pair of white, at rm temperature blue are showing closed circuit and white are about 1 to 2 mega ohms, is this correct or indicate a faulty thermostat, otherwise it is my pcb which after a few days shows a flashing green led.
SOURCE: Replacing the PCB
There are two screws located underneath the silver sticker, of all places. You need to pull the sticker back just a few inches on either side and there you will find the two hexagonal screws.
Remove these two screws and the PCB Board will slide out. You will also see where the thermostat probe plugs into the board and then snakes to the back of the fridge.
SOURCE: Hoover HCA 33 FSK
gp to repair clinic.com it sounds like the temp sensor or the or the defrost timer either way it probably isit defosting. The fan will run every time the it call for cold
Ok so I've done more investigation and have update to help those who come after me.
The 2 blue wires are the thermal fuse the heating element goes throught this and should always have continuity it is connected to the second connector left to right on back of pcb control panel.
The two white wires are the defrost thermistor and should be open circuit when thawed going high impedence when frosted.
I have also realised the first connector to the right of the control pcb is the fridge thermistor which activates the compressor.
next to that going left is the ac in.
The first connector at the left of pcb board is the light switch, and the heating element is f1 and f2.
I put ac straight on f1 and f2 and the heating element located at the back of the freezer behind the panel warmed up, thus now I know all the bits in the fridge works it has to be the timer activating the heating element which is on the pcb itself in the form of an ic thus I have ordered a new pcb.
hope this info helps others.
