Question about Frigidaire GLWS1339CS Top Load Washer
My washing machine gets stuck after rinse cycle
When the machine is finished with the rinse cycle sometimes it will get stuck. All the water will be gone from the tub but it continues to run and drain out of the machine into the drain, which if left unattended can be a huge waste of water. But if you advance the timer just slightly it will go into the spin cycle as it should. Could the timer be bad? Please help.
  • Joe Customer
    Joe Customer Dec 10, 2007
    We have the same exact issue on a Whirlpool model LSQ9110PW4. When the rinse cycle is reached, the water keeps pouring into the tub. The tub does not overfill because the water is somehow also draining out at the same time. If the timer/selector switch is pulled and advanced just a bit, then pushed in again to start the rinse cycle, the wash job completes as normal. This is an intermittent issue as it does not always occur in every setting, or water level selected.
  • Anonymous Dec 15, 2007
    my rinse cycle becomes stuck with water continuously flowing. I have to manually turn the dial to spin cycle
Before spending any money calling a repairman or changing parts, check the drain hose. If it is too deep down into the drain pipe then pull it back so that only about 6 to 10 inches is down the pipe. If it is too far down then it creates a vacuum which drains the water as it is trying to fill for the final rinse.
Posted on Mar 05, 2011
  • LAURA HEINEKE Aug 01, 2012
    thank you so much for this solution. We just moved recently and i noticed our washer was just running on the rinse cycle and wasting water. We pulled the drain hose out a bit just like you suggested and viola, our washer is fixed.
  • 5,911 Answers
It sounds like you have a timer that has gone a little "flaky" on you. If it's only happening at the spin cycle increment, you may have a dirty contact inside the timer. Sometimes you can open them up and clean them with an emery board or some alcohol and a cotton swap. If you don't want to bother you can replace the entire timer, but they can be pricey. Good luck.
Posted on Apr 29, 2007
    Novelist:
  • 114 Answers
Not a bad idea to check if the loading door saftey switch (which prevents spin cycle when door is ajar or opened) is intermitently breaking contact. I do agrre with the Guru on the timer solution. Door saftey switches usually are not realated to the water still running continuously. when they go bad or the contact goes "open" the spin cycle will not work at all.
For some reason my GE GBVH6260 washer cycles are getting hung up on either the wash or rinse cycle. Some days it will stay stuck in the wash cycle & some days it will stay stuck in the rinse cycle for...
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
Jul 10, 2017 | Washing Machines
Ge quiet by design washer stoped on the wash cycle and I can not get it past to be able to rinse and finish the cycle
most of the time it is the door lock that get broken but it might be that your water valve got something stuck in it.
Jan 02, 2010 | Washing Machines
My washing machine will not drain. It finished all the cycles but didn't drain after the rinse cycle. It still spun afterwards with water still in it.
Aug 10, 2009 | Whirlpool Washing Machines
Washer will not discharge water after wash or rinse cycle
Pump failure. Unit probably has something stuck in pump....the washer eats the socks not the dryer. suggest shope vac to get water out, and then remove hose from pump and check to see if its clear.
Jun 08, 2009 | Kenmore Washing Machines
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
Whirlpool Ultima Wash II Intermittent Rinse/Spin
Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
Feb 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Stuck in rinse cycle
Mimmi, If the water isn't reaching temp this will happen. It sounds like a heating issue.
Guest,
The spray arm being blocked will not cause this. Again your machine isn't heating the water to temp.
Oct 27, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Front Loading Washing Machine - stuck in cycle.
there may be a simple solution. on rinse the water level is higher. it is just possible that the water is syphoning out. try putting the drain hose higher in a swan neck
Apr 05, 2007 | Frigidaire GLTF530DS Front Load Washer
Frigidaire GLWS1339CS Top Load Washer Logo
3,179 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
