Question about Maxtor (H01R300) 300 GB Hard Drive
Maxtor external hard drive is not accessable
Hi, i was connnecting my maxtor onetouch two 300gb external hard disk through USB 2.0 to my laptop as always. one day, when i open "my computer", i found the icon of the the drive was gone. i tried to check if the usb was plugged off or device was not regonized by the computer, but i found everything was runnig normally.except, the drive icon was not presented in "my computer".hence, i have no way to read and write or do anything with this maxtor external drive. i am planning to get it fixed in some pc repair shop,can anyone tell me a better solution or give me some advices? thanks for all. regards,
  • batgal May 03, 2008
    I was trying to access my maxtor external drive on my windows xp as always but this time for some reason my pc failed to detect my maxtor. When i'd click on my maxtor desktop icon, it would always say "no maxtor found".. but i checked the connection over and over..it was connected and turned on properly. I noticed though that when i first plugged it in, there was a beeping sound that wasnt there previously. I also tried accessing my maxtor on other devices like my laptop but it still cannot be detected. what's wrong with it?..please help.
    Novelist:
    Scholar:
  • 134 Answers
Follow what 'ImWireless' has suggested, but eventually you may have to remove the hard drive & install it into another housing or even into the pc as a slave or secondary drive. That way, you will know if it's a maxtor fault of a problem with your actual hard drive. Anyway, ImWireless appears to have the basic initial tests sorted.. Rgds,
Posted on May 03, 2008
    Scholar:
  • 113 Answers
- Do you hear any beep sound when you plug in the USB drive into the laptop? - You can also try a different USB cable - Try connecting the hard drive to a different computer and see if it works All those steps will help you determine where the issue is. Please revert back with any other observations. Good Luck
Posted on Mar 30, 2007
My pc and laptop not detect my Maxtor OneTouch III Mini External 100GB USB 2.0 Hard Drive R01E100 what can i do please help me soon as possible
Good Day Anantsharma8!
If your PC and Laptop can not detect your external hard drive, I do suggest you check its usb cable. A substitute cable will confirm if your current usb cable is faulty or has an open wire.
Most common reason why the external hard drive is not recognize by PC or Laptop is due to loose connection of the hard disk inside the connectors of the enclosure.
Anantsharma8, if you have a small precision screw, I recommend you open the enclosure of the external hard drive. Remove the front face where usb and power plug connects, then slide it out to expose the hard disk also. You will see two connectors. These are the ones that always loosen. Please disconnect both the connectors and then connect it again properly. Put the hard disk back, close the enclosure and try to connect again with your PC or laptop via usb cable.
Good Luck! I hope that it will soon recognize your external hard drive.
Jun 10, 2011 | Maxtor OneTouch III Mini Edition R01E100...
Would like to erase 150gb maxtor external drive and start over
Connect the drive.
Open "My Computer".
Right-mouse click on the icon for the Maxtor.
Click FORMAT.
Choose Quick-Format.
When it completes (in a few seconds), all the files on the disk will be "gone",
because a "blank" Table-Of-Contents has replaced the previous Table-Of-Contents.
Dec 20, 2010 | Maxtor OneTouch II external hard drive...
I have unplugged my maxtor 300gb external hard drive from one pc and have plugged into my laptop to transfer data. Light goes on but doesnt seem to be showing up on laptop 'My Comp'
you might want to try to unplug to HD's power and plug it back in then plu the USB into you computer....make sure that you remove the usb safely and not just unplug it.
Nov 24, 2010 | Maxtor OneTouch II external hard drive...
Other computers dont recognize my Maxtor OneTouch 4 Mini
Please Make sure you External Hard disk USB cable is working correctly. Your cable is probably having partial contact, so try another cable
May 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Erase and reformat to be compatible with new mac
Think I might have solved it myself. Here's how:
Open Disk Utilities and select the external hard drive. Select the "Erase" tab. Hit "Erase" at the bottom right.
That's all. Just dragged a folder onto it and it worked.
May 08, 2008 | Maxtor OneTouch II external hard drive...
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
RE: my external hardrive
Check cmos to see if usb ports are enabled? If Windos 2000 you need a usb driver disk.
Feb 28, 2008 | Maxtor OneTouch II external hard drive...
Maxtor OneTouch III Not Recognized by XP
sounds like the USb Port is burned out, might as well chuck it
Jan 09, 2008 | Maxtor OneTouch II external hard drive...
Maxtor (H01R300) 300 GB Hard Drive Logo
133 people viewed this question
Top Maxtor Computers & Internet Experts
Phil Whisenant
Phil Whisenant
Alun Cox
Norman Al-Anbar
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
