Question about Kenmore 22422 Top Load Washer
Kenmore 22422 seeping water from under machine
My washing machine is seeping water from underneath the machine during wash and rinse cycles. I looked in back, and there is no water leaking from the hoses or faucet. It is a slow seep at the moment.
    Problem Solver:
  • 4 Answers
Look underneath the washer.there sould be a hose there.sometimes an unbalanced load can cause the hose to rub up against sharp metal when the machine vibrates.mine had a zip tie that held the hose to close to the edge of the machine which had some sharp metal and it put a small hole in the hose.hope this helps.
Posted on Dec 19, 2008
Rinse cycle doesn't work
Your cold water valve is clogged. Most likely needs to be replaced or at least cleaned.
www.oc-repair.com
Feb 09, 2010 | Kenmore 22422 Top Load Washer
Machine is leaking water from somewhere?
there is a seal between the drum and transmission,more than likely thats where its leaking. also check your fill hoses and valve
Jan 09, 2010 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Washing machine not rinsing
Set your machine for warm wash warm rinse.
If it works OK.
Replace the water inlet valve.
Feb 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore 22622100 Top Load Washer won't drain the water, nor rinse
HI!!! you seem to have a bad lid switch on your washer..I would also check the timer on it good lucck.
Feb 13, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
145 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
