Question about Olympus Stylus 770 SW Digital Camera
I have the stylus770 camera. It doesn't turn on when connected to the computer to charge it. please help
    President:
  • 919 Answers
In order to charge the battery for the camera you need to use the supplied charger that came with the camera. The camera is not going to charge when connected to the USB port of the computer. Camera was not designed to be charged that way.
Posted on Dec 22, 2008
I connect my camera to the computer (mac) using a USB cable, and it doesn't come up
Yes, you need to charge the battery.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 22, 2012 | Sony Cyber-Shot DSC-P10 Digital Camera
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
My camera has been plugged into the computer for 24 hours now and the battery still isn't charged. How long does it take to charge and how will i know when it is done charging? i have a Vivicam X029
The manual merely says "a few hours." The LED on the back of the camera lights up while charging and goes off when finished. Not all computer USB ports put out enough current to charge batteries. If you're using a hub, bypass it and connect the camera directly to the port. If that doesn't do it, try another port if available. If that doesn't do it, use the supplied AC adapter and plug it into a wall outlet.
Aug 05, 2011 | Vivitar Cameras
My phone (Samsung i8000) doesn't charge when turn-on. even when connected with USB cable my computer doesn't recognize it. Please help.
Just follow this step.
* Your mobile charging socket as some problem.
* You just need to visit you are nearest Samsung service center.
* There they will fix you are problem in few minutes.
* After getting repaired check weather your mobile is charging correctly.
* Then your mobile will be just fine.
If you are satisfied with my answer then rate me.Thanks for your question.
Jun 24, 2011 | Cell Phones
My camera wont start, it wont even charge please help
There is a problem in your battery either you need to replace it or you can try to charge it through USB.
If you want to charge your camera through USB follow the instruction:-
1) In the computer turn OFF the hibernate, sleep or stand by Mode. 2) Turn OFF the camera. 3) Connect the your camera to the computer through USB Cable. 4) Wait for your camera battery to charge (Approx. 3 hours)
This may resolve your problem, Else you need to replace your battery
Rating the solution is highly appreciated...Good Luck
Mar 03, 2010 | Kodak EasyShare MD853 Digital Camera
MY CAMERA WONT COME ON THE TELESCOPE LENSE WONT GO BACK IN IT DOSNT SEEM TO CHARGE
Please try the following: Don't forget if you're charging though the computer NOT to turn the camera on. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 27, 2010 | Kodak EASYSHARE M1063 Digital Camera
My m863 kodak camera charging light won't turn on.
Is the camera charging? Remember when charging thought the computer NOT to switch the camera on since this will deactivate the model to charge. Try the following: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 24, 2010 | Kodak EasyShare M863 Digital Camera
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
Camera will not work and will not charge its like
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable/ battery. Please also try to upload new firmware: Connect the camera with the computer. Turn the camera on. Click onto the link and follow the instructions. http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=10542&product=EKN032941 If successful please give me the feedback as a rating or recommendation. Thank You
Dec 22, 2009 | Kodak EasyShare V1003 Digital Camera
My Lumix TZ1 stopped working
Simple solution. I recharged the camera battery and the camera came back to life. I wasn't expecting it to, because the battery was fully charged when I had connected it to the computer, so I figured the problem was not battery-related. Apparently keeping the camera connected to the computer for such a long time drains all the power in the camera battery.
May 11, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Olympus Stylus 770 SW Digital Camera Logo
62 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
