Question about Bushnell Deep Space 78-9512 (120 x 60mm) Telescope
I just sent in product # 560519/Lab repair #2115426
Just dont know who to ask? Blazer 3-9x50 Matte C/P it was shooting 2&half inches low at 25 yards.just wouldnt rise up?
  • Roberta Smith
    Roberta Smith May 11, 2010
    what product are you talking about... i'm guessing it's not a telescope
  • 57 Answers
Dear Glajauin,
No. It is not possible.
Thanks.
Dhananjay
Posted on Jul 09, 2011
I bought the new mossberg 22 tactical rifle . I tried to mount 3 different scops and they all shot off by 8 inches at 25 yards, the incline on the scope rail is at an incline. Is their another rail I can...
Off which way at 25 feet. If the gun is shooting low at this distance i would back off to 25 yards. It may shoot low because the scope is mounted a about 1 1/2 inch above the bore of the gun. In the 25 feet there is not enough bullet rise to compensate for that sight being that far above the bore. You may have to go with a red dot type or just add a laser if you are going to stick inside your 25 foot zone.
Aug 19, 2011 | Optics
At 30 yards im 6 inches high to be dead on at 150 im shooting a 270 and i have never had this problem before
the scope is mounted to high on the rifle try a lower set of mounts,,,this is called parallx error and is very common if you have high mounts,,,,
Nov 24, 2010 | Simmons 510513 3-9x40 Blazer Riflescope -...
1. HOW TO READ SCALING OF SCOPE.? 2. What is
You have not provided enough information for us to help you. What type of rifle? What do you mean by scaling?
With the scope on 3 power you should be able to sight it in at 25 meters. Going to a higher magnification may cause blurring at that distance.
You also may have mounting problems that are causing the scope to move around when you shoot. Your rifle may be fine.
Oct 09, 2010 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
I zeroed in my 25/06 at 100 yards. at 200 yards 1/4 inch high using 2nd line on drop compensator , at 300 yards shot 41/2 inches high using 3rd line on compensator. What am I ding wrong
It sounds good to me, don't forget, the 25-06 is a flat shooting round, you have your scope pointing up, the bullet crosses the line of sight twice, One at 100 yrds, your zero and the other on it's way down at about 500 yards. You can check the ballistic coefficient of that bullet and see where you need to be zeroing it in at. I would think about 250 yards, will be 1 1/2 low at 100 yards, 3/4 inches low at 200 yards, dead on at 250, then it will start coming down, say 8 inches low at 400 and 18 inches low at 500. Something like that. So your BDC will not be needed till you reach out past 300 yards, which is varmint country stuff. I have my .22 marlin sighted in at 100 yards, and it will put the lights out on anything at that range. You can probably find the charts on line someplace, if you don't have a reloading manual. Check it out.
Jul 12, 2010 | Pentax 4-12x40 Gameseeker Rifle Scope...
Worn drive on my CP half-inch impact
That impact is distributed by Harbor Freight, though I doubt it is 25 years old. They may have a rebuild kit there, but a new one just like it is around $35.
This one:
is priced at $24.99
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95310
Mar 25, 2010 | Chicago Pneumatic 1/2" Air Impact Wrench
Scope is maxed out for adjustment, is till shooting low dav
if your scope is shooting low and you dont wont to buy a new set of mounts the only way to lift the point of aim is to pack out the eye end of the scope mount with 35mm film or a soft type of shim that wont scrach your scope i use 35mm film at its mostly water proof but there are other shims that do the same thing put about 25th of an inch under the eye end between the scope mount and the scope this will lift the "bell end" up and lower the point of aim there by rasing the impact point of your bullets dont over do this idear as if you go to far you wont get the turrets to drop the point of impact and you could also bend the scope, but 25th of an inch is not a lot but its over 10 inches at 100 yds with a .22 rim fire rifle
good luck shoot safely and good hunting
Nov 30, 2009 | Leupold 54120 2-7x33mm European 30mm Matte...
I have a Bushnell Sprotiew 4x, 15mm scope mounted on a Mossburg .22 rifle. My shots are hitting left six inches and low. Can you please tell me how to adjust this scope? Thank you.
Keep in mind Diane this is for a set distance. if you are taking a shot at a target further than your are set for (ie a target you wont get 3 shots @) remember how the bullet is travelling as it goes down range
one idea would be to set your rifle up down range and zero it in on a target (preferably paper) now adjust 1 MOA (try and have target @ 100 yards and 200 yards)
see how far the bullet moves for each moa adjustment. then check it against the next range.
this should remain constant @ a set number of inches per 100 yards.
so if you zero in @ 100 yards and then move 1 moa any direction and it adjusts (lets say and hope it is 1.047 inches") then you do the same for 200 yards. it should be twice as much movement. ie 2.094"
once you know what 1 moa represents on your scope you can adjust alot more accurately.
REMEBER the total inches of movement / adjustment per MOA is directly related to range (a precise range helps in shooting) so if your squirrel is 150 yards and your first shot is off 9" to adjust you divide 9" by the inches per moa so 1.5 (150 yards /100) X (Inches per 100 yards per moa you measured hopefully 1.047") its 9" divided by 2x1.047 = 9" / 2.094 = 4.29799
this number needs to be rounded to the nearest click on your scope (most are 1/4 MOA scopes and you can tell by looking at how many clicks/lines are inbewteen each large number on your windage and elevation dials
so to turn this into an adjustment we round 4.29799 to 4.25 which is 4.25 MOA or 17 clicks on a 1/4 min scope.
GL and any questions just post and ill help
not please rate this as fixya :)
Note i can provide EXACT information that would allow you to determine range, and windage and elevation adjustments by looking through scope and estimating range
then factoring in weather variables. NOTE you hafta enjoy math or just want to know how to shoot really well. :)
Dec 22, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
1990 blazer electronic dash not working
IT IS MOST LIKELY THE CLUSTER ITSELF THIS CAN BE SENT OFF AND REPAIRED THRU DEALER FOR ABOUT 350.00
Sep 08, 2008 | 1990 Chevrolet S-10 Blazer
Moyer Diebel Model 201LT heating element failures
Without looking at your defective elements it sound like the chemical eat through the element and produce tiny pits tell your Eco Lab Tech to change to another type of chemical they have many kinds to suit your need. Try that . God Bless.
Feb 22, 2008 | Moyer Diebel 48 in. SW400 Dishwasher
Bushnell Deep Space 78-9512 (120 x 60mm) Telescope Logo
94 people viewed this question
Top Bushnell Optics Experts
Marvin
Marvin
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
