Question about Whirlpool LER4634J Electric Dryer
I HAVE AN OLDER WHIRLPOOL DRYER WHEN YOU FIRST TURN IT ON IT GETS HOT BUT A LOT OF THE TIMES AFTER IT RUNS FOR A LONG TIME YOU WILL CHECK IT IT WILL HAVE NO HEAT AT ALL IN THE DRYER AND THE CLOTHES WILL STILL BE WET COULD i JUST REPLACE ALL OF THE EMPERATURE SENSORS AFTER DOING A CONINUETY CHECK ON THE HEATTING ELEMENT???
  • 979 Answers
Check the breakers first, then the connections in the back for tightness. Have you had the thermostat looked at? It might not be allowing power to the element. I am surprised the element is O.K.
Posted on Jan 14, 2009
My dryer only works sometimes model #ggw9200w1
I would 1st check and see if the vent pipe assy is clogged up with lint.
GL
Sep 14, 2014 | Whirlpool Dryers
Whirlpool Duet dryer runs way too hot, even during air only cycle.
sounds like restricted air flow to me . check filter and the vent for plugged pipe
Apr 18, 2012 | Whirlpool WED9400S Electric Dryer
I have an older model gas dryer with the lent catcher located on top of the dryer. It spins and it gets hot but it is not drying properly. I have to run the dryer three times to completely dry my...
you might have a restriction in the exhaust system. check the entire exhaust vent tube/hose from the back of the dryer to the outside of the building for any restrictions. check the outside exhaust vent for any restrictions or obstructions. make shure the exhaust tube/hose are as short and straight as possible any sharp curves or bends can restrict air flow.
Oct 07, 2011 | Whirlpool GGW9868K Gas Dryer
Our 4 cycle whirlpool dryer runs for 5 -10 minutes gets hot and shuts off.
check to see if the dryer vent is clogged up - When a dryer gets to hot it will shut off to prevent catching fire!!! If the vent is clogged it forces the heat from the dryer to stay in and that causes the dryer to over heat!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Jun 25, 2011 | Dryers
My dryer runs and gets hot but cloths don't dry.
Your problem may be attributed to a clogged exhaust system (e.g.: clogged inside the dryer's vent, flexible vent behind dryer clogged and/or clogged inside wall, etc.).
Feb 22, 2010 | Whirlpool GEW9250 Electric Dryer
Old avocado green Whirlpool Dryer, door switch?
dryer gets hot 4 awhile then gets cold
Aug 16, 2009 | Whirlpool Dryers
Our Whirlpool dryer runs, then cuts out. After a
Sounds as if your motor is defective. It has an internal thermal switch which cuts the motor off before it gets too hot. After it cools, the switch makes up and the unit is able to run again.
Aug 01, 2009 | Dryers
Dryer only works until it gets really hot
Hello Joyce Dozier,
Some of the older dryers are the best and if you can keep them operational.. they can last a very long time.. Based on your problem description, you more than likely have a thermal cutoff switch that is cutting off power to the heater.. Over time, these thermal switches fail from age ( I can relate to that as well).. Anyway, please provide the Whirlpool model number and I may be able to track down the most likely suspects for you.. You , however, will have to rope a friend or family memeber in to replacing it... It could also be the themal sensor on the motor too..
I would unplug it and open it up to gain access to the motor.. and vacuum away all lint that may have accumulated around the motor and other areas... Provide the model number ( normally found on a tag someplace on your dryer..) and I will help you find a solution..
Regards
Rick
Jan 05, 2009 | Whirlpool Dryers
Dryer doesn't get hot or turn off.
yes very possible timer but my guess on the times i seen the problem would be the heating element are the thermo fuse on the elemnt canister when the heater does not come on the timer will not move ck the heater and the fuses on the heater canister it will fix your problem
Feb 28, 2008 | Whirlpool LER4600 Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
