Question about Soleus MobilAir MA9000 Air Conditioner
E4 error being displayed
E4 error will come up and the system will shut off. Need advice what can be the problem
  • Achike Mar 14, 2008
    Error E4 is displayed on a Holtstar Remote Controlled Air Conditioner with 2.3GJWDCP PD212-12/01 and 2HCSJZB-PD3 01-11-04 Remote Controller Board and it does not take any other instruction once it is powered and the error E4 comes on
  • engraved Aug 15, 2008
    Can the ac be fix once yiou get the e4 error message, and how?
    MA9000 is what I have.
This error message is because the water tank is full. Just empty it out and put it back in and the AC will start to work again. If that doesn't work then I don't know what the problem is, but I just had the E4 error and did that and the problem was solved.
Posted on Apr 16, 2012
  • 944 Answers
Here is the manual if you need it; http://www.soleusair.com/Consumer/menus/Air_Split_AC/MA-9000AH%20manual-soleusair%2003-14-2006.pdf although it doesn't list error codes - the FAQ section on the site says; "What should I do if my unit has an E-4 problem? The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen." Have a look and see if that looks like it is the problem, and if you could post back with a photo we may be able to help you fix it, else contact Soleus for parts; http://www.soleusair.com/Consumer/index.htm Hope this helps :)
Posted on Mar 30, 2007
E4 is an internal error - it is not repairable. It's usually associated with a low freon or a freon leak.
Posted on Jun 01, 2010
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4. I press the program button, i select the washing program i want, but on the display the error code "E4" is being blinking. How do I fix it please?
The E4 Dishwasher Error. According to the manufacturer the E4 error will be given if the vent for overflow when water level exceeds the set level overflow water triggers the lower float, terminates operation and gives E4 warning.
Clean the level sensors.
May 15, 2016 | Dishwashers
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
Sep 25, 2010 | Kenmore 15762 Dishwasher
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
Hobart LX30 error code wrench & E5
What error code is displayed?e1,e2,e3,e4?I'm a hobart tech let me know.
Apr 10, 2009 | Dishwashers
Base unit displaying E4 after we experienced a power black out
e4 error code that means it ihas defective base unit. it happened due to a spike in the power lines that may cause this error
Feb 09, 2009 | Uniden 5.8GHz Cordless Phone
Error message E4
All sewing machines are 'picky' about being threaded correctly. As you seem to understand. There is no shame in asking the seller for help.
Jan 23, 2018 | Singer CE350
Carrier casement unit shuts off automatically
E4 indicates your unit is in need of service.
May 07, 2008 | Carrier XHC101D Air Conditioner
Unit shuts down
The E4 error in display its mean the wire sensor connector to thermostat is loose pls fix , or have a problem in PCB Board on thermostat, pls go to the nearest repairman to repair that.
Thank you,have a nice day
Edgz
Jan 22, 2008 | ACE -Air 18,000BTU Heat Pump A/C Free DVD...
Soleus MobilAir MA9000 Air Conditioner Logo
4,242 people viewed this question
Top Soleus Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
