Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Owners manual ruined. what type of oil do i fill w before use
What type oil does the 3 gal 1HP Craftsman Oil Lubricated air compressor use? Model No 921.153101
where can I get a replacement Owners Manual?
  • moconnor220 Jan 02, 2009
    I've misplaced my owner's manual for the same compressor. Where can I find a new one online since that would be easier than finding one at Sears?
    Scholar:
  • 65 Answers
You should be able to find the manual online if it's available if not Sears would I'm sure be able to tell you.
Posted on Dec 20, 2008
  • hdpanama
    hdpanama Jan 05, 2009
    Go to this page and scroll down and you'll see a bottle of Sears Craftsman 2 Stage Compressor Oil
    http://www.sears.com/shc/s/p_10153_12605...
    May be able to get an Owners Manual there also, check with customer service at the top or bottom of the page, I searched all over there and online and could not find one.
    Found an article about Sears not having copywrites to documentation for another compressor therefore they weren't able to provide it for download. The company that actually manufactured it for Craftsman would be able to provide it. How do you find that out would be by calling Sears would be your quickest sure bet I think. Here is a TOLL FREE NUMBER 1-(800) 252-1698
What level should the oil be in the view sight and what type of oil should be used to fill if needed?
Your oil level should be right in the middl of the sight glass as per the type of oil I'm sure Craftsman has there brand of oil they suggest. But any good quality compressor oil will work.
Jun 25, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My new 80 gallon Craftsman Professional air compressor's oil turned dark right away. I changed the oil and it happened again. Is there a problem? Thanks, Trevor
Problem sounds like the type of oil being used. The oil should be a gold color. It will get dark over time but not like oil in a car. Check your owners manual to be sure that the right oil is being used.
Compressors use a 30 weight non detergent oil. If you don't have a manual Go to any Sears Home and garden Department and they will be able to help you.
Feb 22, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
I have a 3 gal/ 1HP Craftsman air comp. When I plug it in and turn it on, I get the sound of current getting to the motor but it does not start. A failed Starting capacitor?
Could be, do you have a capacitor checker? It sounds like you have a compressor locked up. Do you have oil in the compressor? If the compressor is new I would take it back and see if it is still under warranty. before I did any thing to it.....
Dec 19, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I just bought a used Craftsman air compressor at a garage sale...100PSI, twin cylinder, 1HP motor. Model # 106.154440. Runs fine, but wondered how to check the oil level in the compressor case and if it...
I have a Sears 106.154581 most likely like yours. You will find a small plug (fill hole) and slightly larger plug on side of pump close to bottom (drain hole). Fill compressor with compressor oil to top thread of fill hole. Oil should look rather clear with very little odor. Compressor oil is available at Lowes for about $3. Good luck
Aug 16, 2010 | Craftsman Air Tools & Compressors
I have a Craftsman 3 gallon 1HP air compressor that will only build pressure up to 25psi. The check valve was checked and looks ok. The pressure regulaor appears to be working ok. Bled off tank.The...
Sounds like the compressor has failed -- probably the valve -- tear down and rebuild is probably the solution, or replace compressor, or just buy another unit. My nature would be to tear it down and see what's going on.
Mar 22, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
The air is coming out of the filter instead of intake . Craftsman Air Compressor 12-gal 1hp model 921.166400
if acualy exhaust / engine pressure is coming out of filter it likely to be a bad valve...does engine blow smaoke or oil? is there also pressure coming out of oil crankcase?....let me know , we'll diagnose it! good luck, marty
Jun 14, 2009 | Craftsman Air Tools & Compressors
Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Apr 25, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
1,131 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
