Question about Sector 2653940025 Wrist Watch
Side buttons stick on sector 890
The side buttons to start the chromograph do not push in smoothly. Is this just how the watch functions?
  • stefanrahove Feb 23, 2009
    I experienced the same problem with the sector 890 chronograph aligator strap. Moreover, the chronograph's seconds hand went crazy, starting reseting itself at different positions until it stopped working all together. I think the mechanism is made to click in the way it does even though I agree that it is quite annoying. One a more positive note, the design of my white dial Sector 890 is astonishing and I would even wear it just as a jewelry with no function what-so-ever :))
  • 2,334 Answers
All the pushbuttons must operate easy and snoothly. You will probably need just to clean them as grime and dirt goes in easily without notifying that.
Posted on Dec 19, 2008
Tip
HOW DO I SET MY DIGITAL -- (PUSH BUTTON) -- WATCH
mcdevito75 here, The Quartz Mechanism is made in such a way, that the battery"s electricity changes in a way, while going thru the Quartz and thus Display"s the Numbers and or Letters on the Dial or Display, By PRESSING these Various Buttons, you are Changeing the Battery"s Voltage thru the Quartz and thus Displaying the Numbers and or Letters. ---------- Genarally, you need worry about only TWO (2) of these Buttons to SET your DIGITAL (push button) Watch, They are the MODE and SET Buttons. ------------- The MODE Button is usually on the Right side of the caseing, PRESS this Button, depending on your watch you may have to hold down this MODE Button 2--3 seconds, once you see the Dial Or Display BLINKING you are set to RE--SET your watch, NOW, PRESS the SET Button, usually on the LEFT side of the caseing to change each Function (Hour, Minute Etc.) once each Function is SET, PRESS the MODE Button to move onto the next Function. ------ Once all the Functions are SET, PRESS MODE again to see a STEADY Display or Dial. ---- It May take a little practice so be patient. ------ Some DIGITAL watches may not have a MODE BUTTON, But Rather a DIMPLE on the watch caseing you would PUSH in with a PIN or Tooth Pick, same MODE and SET procedures would apply. --------- Use your watches name plus .com online to obtain a user manual or look for a small watch repair shop in your area to order a NEW owners manual for your watch.
on Jul 10, 2010 | Watches
I dont know how to adjust the time in nike led watches
My Nike LED watch has 4 buttons on it--two on each side. The two buttons on the left light up the screen, but don't do anything of note. The two pushers on the right side do all the work.
To adjust the time on your watch, push the top right button to illuminate the time. Then, while the time is displayed, push the lower right button. You need to give it a good push--a bit longer than just to light up the time. The hour digit should start flashing. Use the top right button to advance the hour to where you'd like it to be, then push the lower right button to switch to setting the minutes. Pushing he lower right button again will advance you through the opportunity to adjust the month, date, and year. When you've cycled all the way through and can see the time again, push on the top right hand button to restart the timekeeping function, and you should be good to go.
Jun 14, 2011 | Watches
Relic model zr66023 165 ft under water watch. how do you light the light to see numbers. 2 buttons on side, buttons on side push in but no light
This particular watch has no light. The two additional buttons are for the chronograph (timer) function. The top is the stop/start button, and the bottom is the reset button. Source: I own this model of watch and have the book on it as well.
Aug 16, 2010 | Relic Watches
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    PUMA FLUX watch - reset time
    Press and hold the button on the upper left until it displays "HOLD" then wait 'til the light goes out, you'll see the hour-digit blinking, set the hour you want, then for the minutes, press the lower left button. Press and hold the upper left button to set the desired time.
    May 02, 2010 | Puma Digital Alarm Chromograph...
    Fossil Chronograph--need to know what the two buttons on the side do
    Two push buttons is for chronograph function. When you push the upper button - chronograph starts, second push on same button - stops the chronograph. Push on lower button - chronograph resets to zero. Rate me, plz.
    Feb 03, 2010 | Watches
    Sector 250 Chronograph Alarm
    the middle dial on the right side of the watch is used to switch from watch settings to alarm settings..
    pull the middle dial out to put it in alarm mode.
    To set alarm:
    -pull the center knob out.
    -with it out you can now use the bottom (right) knob to set the alarm.
    -pull the bottom right knob out one notch
    -turn the knob clockwise or counter clockwise to set the alarm time
    -push the knob back in (all the way)
    the alarm is now set
    if the center (right) knob is pulled out the alarm is ON
    if the center (right) knob is pushed in the alarm is OFF
    I have owned this watch for about 10 years now and love it.
    the past few years the chronograph buttons (on the left side of the watch) were not working well rendering the chronograph and count down timer functions unusable.
    repairing a chronographs is expensive and watch makers usually charge several hundred dollars which is not a feasible fee for a watch of this value so i decided to open it up my self and clean it up and that did the trick.. its working like new!
    enjoy the watch!
    Dec 11, 2008 | Sector 2653940025 Wrist Watch
    How to adjust a Skagen Denmark Women's Steel Watch so it can fit my grandma?
    good morning ! look the smooth side of pin on side part of your watch bracelet, just push it use pointed puncher pin and anvil to do that ,good luck !..
    Sep 05, 2008 | Skagen Watches
    Rolex Daytona Chromograph
    ok. bear with me. lol. on most watches without a chronograph. the second is the largest hand on the watch and naturally that's what most people refer to as the second hand. On a chronograph the "true" second hand is the little middle dial. It should always be constantly moving and the large hand should only move when the stop watch funtion is in play. The way to employ the stopwatch funtion is by unscrewing both buttons. The top button starts the action. Once pressed then large hand will begin. The little dial on you left will keep up with each minute that passes. To stop the function, press the top button again. To reset the stop watch, press the bottom button. The little dial on your right is simply military time. Hope that helps. Good luck!!
    Apr 26, 2008 | Rolex Daytona 116520 Wrist Watch
    Sector 2653940025 Wrist Watch Logo
    416 people viewed this question
    Top Sector Watches Experts
    staicuma
    Level 1 Expert
    aravind shet
    aravind shet
    Are you a Sector Watch Expert? Answer questions, earn points and help others
