Question about Mitsubishi HS-U575 VCR
Manual input selection mitsubishi hs u575
Is there any possible way to navigate between input 1, 2 and cable without a controller, since mine broke and cant watch tv thanks
    President:
  • 3,130 Answers
No I'm afraid not, you must have the remote to perform these functions. You can get a original replacement remote from here: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=HSU575&brand_pn=MITSUBISHI_HSU575&mode=large&uid=11752605060460 Good Luck
Posted on Mar 30, 2007
Will not eject tape
take the top off the VCR, you will see where the tape is hung up. Reach down and release the tape and pick it up, now close the top.
Jul 31, 2012 | Mitsubishi HS-U575 VCR
E-2 error what does that mean
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
May 09, 2011 | Mitsubishi HS-U575 VCR
Mitsubishi HS-U540 VHS VCR How do you connect the red, white, and yellow cables?
The RED is Right Speaker the WHITE is Left Speaker and the YELLOW is for
Video. They connect with RCA Cables to the same color coded inputs on yout TV.
You may find it easlier to just use a CoAxial Cable; Use a CoAxial for the CABLE IN to the Cable Box then 1 CoAxial from the Cable Box OUT to the VCR IN then use 1 OUT from VCR to TV IN. That is much easlier then using RCA Cables.
Aug 14, 2010 | Mitsubishi HS-U540 VHS VCR
Changing channel from cable to input
Your control TV switches at the front are bad, need to replace
May 09, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Where do I find the input select? i am trying to connect a video game to my vcr which is a mitsubishi hs-u540.
Usually there's an input select button on a VCR's remote. You just press that, and it should work. It usually does.
Feb 15, 2009 | Mitsubishi HS-U540 VHS VCR
Mitsubishi HS-U680 VCR
Here are the possibilities:
1. really dirty heads - both video and audio
2. TV is not selecting the right input for the VCR.
3. difficult (but rare) failure in the VCR output circuitry.
Hope Ya Fix it!
Jan 22, 2008 | Mitsubishi HS-U680 VHS VCR
Mitsubishi VS-50603, input is gone
happened to me also. Go to the menu, select setting, thrn av (home theater) and see if "locked to input 1" is "on". Mine was. then I set it to "off" and everyting works great
Dec 06, 2007 | Mitsubishi VS-50603 50" Rear Projection...
Input selection
Many of the late VCRs have very limited funtion from the VCR buttons. Power, eject, play, perhaps channel selection, that is about it for most. I assume you don't have the manual? Looked on Mitsubishi website, didn't list a manual for your specific model, perhaps another model would be close enough. http://www.mitsubishi-tv.com/j/i/18344/OwnersGuides.html?tid=5&f1=2005&s=3 Replacement remotes here: http://www.vcrremotecontrols.com/Mfrs/Mitsubishi/MitsubishiVcr.htm
Aug 22, 2007 | Mitsubishi HS-U540 VHS VCR
Can tune mitsubishi HS-651V video player/recorder to watch TV.
Hi Jaco, Have you fed in your Antenna / cable into the Rear of the VCR? And if your VCR has a Input selection switch, just check input to Tuner. You will get Blue screen if input selction is not Tuner but Camera / External source. If this does not solve your problem, then there is no Input selection happening.
Apr 06, 2007 | Mitsubishi HS-U448 VCR
Mitsubishi HS-U575 VCR Logo
183 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
