Question about ASUS P4S533-MX Motherboard
Memory problem Is DDR400 and DDR333 is ok to put in together are they compatible... does my computer would not have an error... ??
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Actually depends more on how good the memories are. You can but not advisable. If ever you are forced to do so, the 400 wouold shift down to 333 and that is when the trouble starts, BSODs. If during Windows installation, the install would have a hard time completing without errors. In some instances, on boot, "NTLDR missing" message. For mission critical machines, gaming or 24/7 servers, better not.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 19, 2008
Have acer veritron 5600g does it take high density or low density memory
Your computer can take either DDR333 MHz or DDR400MHz (pc2700, or pc3200) NON ECC memory. Even though it can take either you need to use matching modules/ not mixed. DDR400 or pc3200 memory is faster but these are also backward compatible. The memory will only run as fast as your FSB (front side bus) rated frequency. Click HERE to go to Crucial memory advisor page for your model.
Apr 25, 2011 | Computers & Internet
I PLUG IN 2 NEW 512 MEM PCBS & WLL NOT BOOT. 1 BEEP FOLLOWED BY 3 BEEPS FOLLOWED BY 3 BEEPS FOLLOWED BY 1 BEEP. THEN NOTHING.
Remove the "new" RAM.
Look at the labels for PC2100 or PC2700 or PC3200,
or for DDR266 or DDR333 or DDR400.
Compare with the label on one of the "old" sticks of RAM.
Be sure that the labels on the "new" RAM are "equal" or "higher" than the labels on the "old" RAM.
For example, if the "old" RAM are DDR333, then you can use DDR400, but your computer will not accept DDR266.
Reinsert one of the sticks of the "old" RAM.
Does it still beep multiple times?
If not, then the new RAM is *NOT* compatible with your computer.
Jun 15, 2010 | E-Machines T1742 PC Desktop
ASUS P4S533-MX MOTHERBOARD FAILED TO RECOGNIZE DDR400/DDR333 RAM
In you case compatibility is your problem or your memory needs a clean up. First clean up the memory's pins. Use a pencil eraser. Then try only one by one so that you will know if there is a problem in each memory. Insert one of the memory then turn on your PC. If it boot up or it is okay try the other one. Then if it is also okay, try both of it inserted and turn on your PC. If it not okay there is a compatibility problem. Make sure the brands are the same so the compatibility are never be a problem.
Mar 10, 2010 | ASUS P4S533-MX Motherboard
ECS PT800CE-A 3.4 P4 HT CPU and DDR400 (PC3200) problems
I seem to be unable to find any information about what an ERAND error even is. No one is really identifying it on the net. One thing you may try though is to find out if the bios settings are maybe causing this. Is the system overclocked at all? Are the voltages correct? Maybe try resetting Bios to default settings and trying again.
Oct 04, 2009 | EliteGroup ECS PT800CE-A...
Adding memory to Asus p5v800-mx motherboard
if they are compatible with your motherboard, different versions of RAM do not conflict
May 04, 2009 | ASUS P5V800-MX Motherboard
Hello!
I think the best solution to your problem would be either to go to www.crucial.com or www.tigerdirect.com . They both have memory configurator tools that will make sure the memory that you are purchasing is compatable with your laptop. That is your safest way to know. I myself prefer tiger direct, they seem to have the lowest prices. the link below will take you right to the memory configurator. If the DDR333 is an option it will let you know. Hope this helps! :)
http://memoryselector.cnetchannel.com/tigerdirect/
Oct 09, 2008 | Compaq Evo N610C Notebook
How much ram can i install on a hp compaq d220mt?
Laptop Computer Memory Desktop Computer Memory Printer Memory Memory Applications All data processing and execution takes place within the memory module(s). The program's directions are replicated into memory from a hard drive, external drive or from a network. The processor then extracts the directions from the memory and puts it into the circuit for analysis and execution.
Memory is so important that it cannot be wasted. RAM is allocated by the operating system and programs, and then released when not needed. Errant applications can grip RAM and not release it, which results in a diminishing amount of memory available as you load and use more programs.
If you could actually look into memory, you would be astonished. By watching how much and how quick data and commands are written in and out of it each day, you would realize it is a marvel that it works so we
UpgradeComputerMemory.com is here to help you speed up and breathe new life into your computer by adding more RAM memory! We have hundreds of relationships with different manufacturers and carry all major computer memory brands. This includes Dell Memory, HP Memory, Samsung Memory, Micron Memory, Toshiba Memory and many, many more. We can cut through all that computer jargon and provide you with the part that will work each and every time. Our 100% guaranteed compatible RAM memory upgrades are available for more than 21,000 different computers, laptops, servers, printers and other electronic device.
Jan 15, 2008 | Computers & Internet
Recommended memory for p4i45gv R5.0
IF UR RAM IS SDRAM THEN U CANT UPGRADE TO DDR BUT IF ITS ON DDR RAM THE U SHOULD B ABLE 2 UP GRADE 2 1GIG OV DDR RAM RUNING AT 400MHZ
Dec 25, 2007 | Asrock P4I45GV R5 Motherboard
Ddr ram for my motherboard
PC2100 is DDR266 memory. PC2700 is DDR333 memory. PC3200 is DDR400 memory All are backward-compatible with PC2100. Memory is designed to be backwards compatible, so generally you can safely add faster memory to a computer designed to run slower memory, but... your system will operate at the speed of the slowest memory module or system component. Keep in mind that the memory does need to be the same type, for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. ZT3000 "Beta tester of "0"s and "1's"
Aug 25, 2007 | EliteGroup P4VMM2 Motherboard
ASUS P4S533-MX Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
