Question about Sony DAV-IS10 System
Only two speakers work. Need to fix so all five work at same time
No matter what soundfield i place it on only two speakers work.  Help befor i take it back to store.....
Did you try turning on the center and surround in the on sreen custom setup menu,,,,,Someone must have turned them off because they wern't useing them?
Posted on Dec 31, 2008
What Are You Trying To Hook The System Upto? Please Define What You Are Using With The Surround Sound System. :)
Posted on Dec 19, 2008
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
How do i turn on all 5 speakers for my yamaha rx-v463 receiver
To turn on all 5 speakers from your reciever you will want to press the audio selct button on either your remote or on the front of the unit itself. This will scroll through the different sound fields and the easiest thing to do is to look at the front right of the recievers display. While scrolling through you will see the speaker icons and all 5 channels should light up when your on the correct soundfield. Dolby digital 5.1 and all channel stereo are common soundfields that use all the speakers. It is important to remember that your surround speakers are only intended to reproduce sound effects, and not full range audio like the fronts. Of course, if it is your desire you can definately override this.
Hope this helped,
Thanks
Jan 03, 2011 | Yamaha RX-V463 Receiver
I already paid for an answer, but the experts answered questions i did not ask. i need to connect my dbx (brand) speakers (item) soundfield sf1-a (model). all you have sent me are suggestions on...
I can't finds anything about your previous experience with this problem.
Can you start over?
It says on the speakers they "requires dbx sfc-1a soundfield controller". Do you have that?
http://vintagedbx.free.fr/photos/sfc-1a.jpg
Sep 27, 2010 | Bose 901 VI Main / Stereo Speaker
In radio mode, all speakers do not work
Radio will default to 2 channel stereo. You will need to use one of the soundfield processing modes to expand. Try using surround mode button to get to 6 channel or pro-logic.
Dec 29, 2009 | Sony STR-DE597 Receiver
Program light and 12:00 are flashing, no buttons work
Press program set once, then switch to clock mode to set time.
Sep 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Dbx soundfield one speakers
Hello. Please need the service manual for
dbx Soundfield One
Jul 17, 2008 | DBX -215 Home Equalizer
Speakers
befor go deeper check your cable first -take the cable from the good one and test the three bad speakers with it-if no good result the problem is in the speaker itself or in the system-test bad speaker with good cable in the place of good speaker if it is working the problem in your system output itself not the speaker.do this for the other two speakers
Mar 24, 2008 | JVC TH-M505 System
Help installing speakers
Before tinkering with the unit,please check the manual that came with the product inside its box/packaging.Make sure that u have fully understood the instructions provided by the manufacturer. 1.Have you checked the power source at your house? 2.Does the product require voltage a specific voltage, 110V or 220V? 3.Have you checked if you have placed the connections inputs/outputs properly? 4.Another thing, have you tested the item before you bought and paid for it? If tested at the store, did it work? 5.Was it damaged during transport to your place? 6.Check also the warranty. Finally,call up the store because tinkering with it might void the product warranty.
Sep 24, 2007 | Creative Labs SBS-260 Computer Speakers
What power rated speaker shoud I use with my str-d865
Sony STRD865 Home Receiver - Dolby Pro Logic - 1995 Related Models << STRD665 ($300) | STRD965 ($400) >> Here's the specs, see below but looks like 100Wx2 speakers at 8ohms. Features: A/V remote; Digital Signal Processing w/ 6 soundfields (Dolby Surround, Hall, Theater, Stadium, Game, Acoustic), Soundfield link; 30 presets; 4 audio/ 4 video inputs (1 tape monitor); sleep timer Specs: Stereo: 100w x2 into 8 ohms (20-20k Hz) at 0.3% THD; Pro Logic: 100w x3; Surround: 25w x2; subwoofer preout; FM sens. 11.2 dBf; 17" W x 5 3/4" H x 14 1/2" D Hope this helps!
Sep 14, 2007 | Sony STR-D865
Sony DAV-IS10 System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
