Question about Dryers
I have a new gas whirlpool dryer that works, but does not heat. What should I do?
  • Dryers Master
  • 8,220 Answers
Clean out the lint and replace this fuse:
WHY?
Posted on Dec 19, 2008
My whirlpool gas dryer is turning and air is working but it is not getting hot
Because you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice
Jul 25, 2011 | Whirlpool Dryers
I have a whirlpool lgq8611pw2 gas dryer. it has stopped producing heat. gas supply seems fine and other gas appliances work fine. Took front lower cover off and blew out dust> pulled and replaced...
go to this site..
I think the first item is what is bad. here's where to start.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-5-654402-/new/Whirlpool-Dryer-not-heating-LGQ8611PW2
Jan 07, 2018 | Whirlpool WGD5200TQ Gas Dryer
Whirlpool gas dryer lgr7646dq1 is working but will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 20, 2010 | Whirlpool GGW9200L Gas Dryer
Our Whirlpool Gas Dryer (Model No. WGD5200VQO) doesn't seem to heat up. It runs for hours and hours to dry a load of laundry. Admittedly, it never really worked that great since it was new. Any ideas on...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 02, 2010 | Whirlpool Dryers
Our whirlpool dryer has no heat. Is there a
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 28, 2010 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Craetions Dryer AWZ129: No Heat
heatman101
May 15, 2010 | Whirlpool LER5636P Electric Dryer
Installed a new whirlpool gas dryer. no heat.
Well being "new" I'd not suspect many parts being defective other than the ignitor for the gas burner. You can view its operation behind the kick panel below the door. It should glow brightly when your dryer is calling for ignition. It may have been damaged if you had dropped it or very roughly handled your dryer wrestling it into position.
Otherwise i'd suspect that the gas line is still turned off, or a wire loose somewhere, or the heat setting in "air fluff"..
best of luck, and have fun,
ttfn
Feb 01, 2010 | Whirlpool WGD9500T / WGD9500TC / WGD9500TW...
Brand new Gas whirlpool duet sport drier will not heat up. Gas line hooked up correctly HELP
Good day,
If it's new, and your sure there is gas in the line to the dryer, then you are entitled to a service call under warranty.
Whirlpool warranties it's dryers for one year from date of purchase.
Call your selling dealer. New one's won't work sometimes.
Dec 31, 2009 | Whirlpool Dryers
Whirlpool lgr4634eq3 gas dryer-runs on low heat or heat fails to work-sometimes. Timer is new; plenty of gas, the ignition element obviously works
i would check your gas valve coils
they are probably weaking or at least your hold is
but i would replace both
they sit right on top of your gas regulator behind the ignitor
two littly tube like things
Oct 09, 2009 | Whirlpool Dryers
Whirlpool gas dryer
check new gas line for foreign objects
May 06, 2009 | Whirlpool LGR5634L Gas Dryer
Dryers Logo
Top Dryers Experts
