Question about Braun Syncro 7526 Electric Shaver
Charging claening unit
The part that you push done onto the shver will not stay down to clean or charge the shaver. Is there a way for me to fix it myself or do I need to buy a new unit?
  • GBar Mar 29, 2008
    I'm experiencing the exact problem, the vertical slide will not stay engaged when I put the razor in for cleaning. This sounds like a recurring problem and Braun should take this for action to solve. I can only manually clean my razor and I'm not keen on purchasing another to have this same problem reoccur again.
    I'm unable to open the base without potentially breaking it, can anyone tell me how to open the cleaning unit to determine if a spring is the problem?
    Walt
  • Anonymous Sep 20, 2008
    The arm of the charger base will not stay engaged. I used a spring clamp on it, and that really works!
    Novelist:
  • 124 Answers
You can obtain a replacement charging/cleaning base for only $18.99 at Shaver Outlet, as of this writing. Follow the link here: Shaver Outlet Parts. If the shaver is still working fine, it's worth getting the replacement base. Less than $25 shipped is a nice alternative to messing with velcro strips and rubber bands. :-)
Posted on May 23, 2009
  • 944 Answers
Here is the link to the user manual for your shaver if you need it; http://www.service.braun.com/line/SH/S5493/S5493_14_NA.pdf The release button on the back end of the shaver must activate a couple of small pins or levers that release the mechanism in the base unit to allow the shaver to be removed. If these pins or levers (sorry it isn't clear from the picture) are still moving in and out when you press the release button, the problem is in the base unit. Where these pins/levers would be if the shaver was in the base unit will be the latches that keep the shaver from coming out - it sounds as if one or both of these is broken or stuck - they are probably spring loaded, so a gentle poke with a small screwdriver or similar may free the latch. if they are not obviously broken or stuck, then the problem may be with the springs. this may well be easily fixable depending on how keen you are to take the unit apart yourself. Braun offer a two year warranty on this item, and even out of warranty their service is normally excellent - contact them on; http://www.braun.com/na/contact/servicepartners/americas.country.html?country=United States of America If you wish to try to fix it yourself and want some more help, please post again. Hope this helps :)
Posted on Mar 30, 2007
  • 3 Answers
I used a spring clamp. Works like a charm!
Posted on Sep 20, 2008
I found that putting a strong rubber band around the entire unit from the base to the top of the charging post solved the problem.
Posted on Feb 19, 2008
  • 3 Answers
I had the same problem - my fix is simple, cheap and works great - obtain some of those double sided hook and loop (Velcro) straps used to tie cables in a neat bundle - the 3/8" - 1/2" wide version works best, these are approx 4" long and usually black in color - costs approx $2 for a package of 10 straps.
Cut off a piece from one of the straps, approx 1" long and glue this to on side of the neck of the charging base. Glue the reverse side of the remainder of the Velcro strap to the other side of the neck, position it with enough length to go over the top of the push in plug (when closed), at the top of the neck, and cover the full length of the first piece of Velcro glued to the other side of the neck + remember allow some additional length so you can easily grab the end of the long piece to release the Velcro grip and let the plug raise clear of the razor.
When the glue is dry, pull the long end over the top and position it to hold the neck plug completely down, and be retained by the first piece of Velcro on the neck - trim the long piece to length, remember you need a little extra length, to make releasing the Velco grip easier. I just pull on the long end of the Velcro, this closes the plug into the razor and simply push the Velcro together to start the cleaning process - simple and cheap.
Mine has been working for years.
Posted on Oct 24, 2007
I had the same problem. What happened with my was a tiny hook has broken off, and the one thats left is not enough to lock it into place. So i took out the spring.. Works fine now, but doesn't have the "spring loaded action" anymore (obviously).. you'll have to pull the neck instead of pressing a button to free the unit.
Posted on Oct 23, 2007
SOURCE:
The top will not stay down for charging
This is a common problem with the clean/charge base for model 7526. The mechanism inside is broken. You can replace the upper housing that includes the locking arm or you can replace the whole system. Both options are available at shaveroutlet.com. See links below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Sep 22, 2011 | Braun Syncro 7526 Electric Shaver
Can't get the 7526 cleaning arm to stay down on the shaver for charging, cleaning, etc. Is there a sequence e.g. hold the arm down then select a cycle, or select then push down? What is the blue button...
The locking mechanism in the arm is broken. This is a common problem with your model. To repair it you will need to purchase a replacement part. You will find the part at shaveroutlet.com. See link below
If repairing your existing clean and charge machine is not an option, you will find the entire machine available at the link below
May 08, 2011 | Braun Syncro 7526 Electric Shaver
Wont run at all - gradually faded and then finally quit all together
It sounds as if the inside of the shver is full of old hair and the like. It needs a good cleaning. SOMETIMES this does not solve the problem and the brushes in the motor could be bad. it is cheaper to replace the shaver than fix one.
Oct 21, 2010 | Norelco 7610X Electric Shaver
My Braun 7526 will no longer clip into the razor for cleaning and charging.
If the arm on the charging stand no longer locks down into place to charge the shaver, you will need to replace the arm or you can replace the entire charging unit. You will find both items at shaveroutlet.com. See links below<br /> <br /> arm only<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html</a><br /> <br /> <br /> complete base<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html</a>
Aug 27, 2010 | Braun Syncro 7526 Electric Shaver
Hi, My braun bs 5301 does not lock my braun 7630 shaver in anymore. at the top where it clicks into the bottom of the shaver, its not actually clicking in and now it doesnt charge or clean unless i hold it...
While holding the neck, pull up hard on the charging piece with the blue button.... You will not break it, it will go right back in after...
DO NOT try to remove the whole neck, just the button piece will come up, an inch or two (NOT OUT COMPLETLY) The wire will only allow you to pull it up 1"-2" so dont try to remove it....
Then look inside and you can see a spring, it's not attached to anything it's just resting in a hole. Pull it out and then push the top charging piece back down till it clicks in...
Now it will stay down on its own... I had the same problem and this work around solved it.
Oct 23, 2009 | Braun Syncro 7630 Electric Shaver
Braun Syncro 7680
the red light tells you it is cleaning, a green flashing light tells you it's charging
Jul 28, 2008 | Braun Syncro 7680 Electric Shaver
Top housing for the charging stand for a Braun Syncro 7680 Electric Shaver
I just experienced the same problem and came up with this solution. Use a spring clamp to keep the top of the charging stand in place. It works like a charm.
May 28, 2008 | Braun Syncro 7680 Electric Shaver
Charging stand
I just had the same problem, where the top of the charger would not stay down. I tried a spring clamp to keep it in place, and that works like a charm! Try it!
Aug 19, 2007 | Braun Syncro 7680 Electric Shaver
Self-fixing base unit
if you take the cover off (do it carefully or you will break he plastic for the indicator lights, like i did) there is a white piece of plastic that holds the wand. just snap that piece back in place and it should now stay down again.
Jun 03, 2007 | Braun Syncro 7526 Electric Shaver
Braun Syncro 7526 Electric Shaver Logo
397 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Joseph Hoffmann
Craig
Level 1 Expert
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
