Question about Kenmore 17459 Free-standing Dishwasher
Plug at end of power cord for kenmore freestading dishwasher
As I was unplugging the dishwasher from the electrical outlet one of the blades, not the grounding wire, came off in the outlet. What I would like to know is where to purchase and install a new cord on the dishwasher
    President:
  • Kenmore Master
  • 2,651 Answers
Heres a part number for a power cord 8566201, it costs about $50.. the same cord you can purchase at the big hardware store chains, home depot or Lowes, a heavy duty extension cord, with one end cut off, will be a fine sustitute and probly only $10 tops.. just buy a real thick extension cord
Posted on Dec 19, 2008
Kenmore 665 no power
No power at all? First thing to check is that the dishwasher power cord is plugged in under the sink. Make sure the plug didn't become dislodged. Then, check the circuit breaker at the electrical panel to make sure the breaker didn't trip. Open up the door to the electrical panel and look for a switch marked "dishwasher" or "kitchen outlets." Switch it off and then back on to reset it. Those are the easy fixes. Next you'll need a repairman.
Feb 08, 2014 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore Elite HE 4t front load washing machine leaking water bottom right bottom at the end of wash
Unplug the power cord from the electrical outlet. Pull the machine far enough from the wall to get behind it to work
Use a putty knife to pry up and remove the end caps from the control panel. Remove the retaining screws from the control panel with a Phillips screwdriver.
Lift the control panel, and push it toward the back of the appliance. Unplug the wiring harness from the control panel. Remove the retaining clips using a flat-tip screwdriver to release them from the cabinet. Tilt the cabinet of the washer away from the frame, and set it aside.
Remove the pump retaining clips using a flat-tip screwdriver. Pull the pump from the motor shaft. Release the hose clamps using a pair of pliers, and pull the hoses from the drain pump.
Connect the hoses to the new drain pump using a pair of pliers. Place the pump on the motor shaft, and secure it with the retaining clips.
Set the cabinet in place on the washing machine frame, and install the retaining clips with the flat-tip screwdriver. Plug the wiring harness into the control panel. Close the control panel by pulling it forward, and install the retaining screws using a Phillips screwdriver. Install the end caps on the control panel, and push firmly to lock them into place.
Plug the power cord into the electrical outlet. Push the washing machine into place against the wall.
Custom Car Parts
Jun 06, 2012 | Kenmore Washing Machines
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
WON'T TURN ON. PLUGGED IN AND BREAKER IS ON.
Unplug the washer and get a short HD extension cord and plug in to another KNOWN good (has power) outlet. Or plug in a small appliance where the washer was plugged in and see if it works. Designated outlet for washer could be defective. Never work on electrical devices until you have the correct breaker switched OFF. Good luck, best regards.
Feb 01, 2011 | Miele 24 in. G892SCU Plus Built-in...
I cannot turn the printer on
These are the possible solutions:
  • Press power button.
  • Disconnect and reconnect the power cord. Plug the printer's power cord straight into an electrical outlet that other electrical devices have been using. Bypass any surge devices or power strips.
  • Unplug the power adapter from printer (rectangular black box inserted in the printer where the power cord is attached). With the power cord attached to it and other end plugged into the power outlet in the wall, check if it's warm/hot but not too hot, that means it's working fine.
If these does not help, it could be a possible defective power adapter issue. Please contact Lexmark technical support for additional assistance. Thanks.
Dec 14, 2010 | Lexmark X4690 Wireless InkJet Printer
Whirlpool 665-13442K901 dishwasher electrical plug in shorts out
You reversed the black and white wires on what? Don't ever do that. One is the line and one is common. They are polarized for a reason.
Immediately stop using that outlet before you burn your house down. Switch the breaker off to that power circuit, then have a qualified electrician check it out.
Jan 28, 2018 | Whirlpool 24 in. Built-In Dishwasher w/...
Cord heats up electric percolator when it makes coffee. What is the problem?
It is not unusual for this to happen - particularly near the ends (the plug end and the coffee pot end). This happens due to one or more of the following: at the coffee pot end the heating element inside the pot is actually transferring to the cord connector and the cord, where it is exposed to room temperature air and is cooled down. The cord shouldn't be warm more than a couple inches from the end. At the outlet end and the pot end: can be caused by weakened contacts inside the outlet itself. Repeated plugging and unplugging cords during an outlet's normal service eventually causes the spring of the contact metal to fatigue. The weakened contacts do not "grip" the prongs of the plug, so the power needed by the pot has less area to pass between the outlet and the prongs of the plug. You only notice it on the high power devices such as toasters, hair dryers, etc.
You might consider replacing the outlet and seeing if the problem is reduced or goes away. In the case of the pot, the spring metal contacts are usually in the cord connector. Replacement of the cord should solve the heat problem in this case.
Please take a moment to rate this advice is you found it helpful. Thanks - and good luck!
Jun 29, 2010 | Faberware FCP240 Coffee Maker
Plug does not go into outlet. Three blade plug with one "J" shaped blade. The outlet has three straight hole to acommodate three straight blades.
Replace the power cord to accomodate the outlet you have. You can purchase them at any hardware store for about $20. This is the easier option than trying to replace the outlet. To replace the cord follow these steps:
1. Remove the access cover on the terminal block on the back of the dryer. This is where the existing power cord is installed.
2. Remove the existing power cord from the terminal block.
3. Remove the power cord restraining clamp (if equipped). This secures the power cord at the entry point on the back of the dryer and prevents it from stressing the terminals and prevents chaffing of the outer insulation on the power cord. NOTE: Its a good idea to have this installed for safety reasons.
4. Remove the old power cord and install the new one following this color scheme at the terminal block:
RED (Hot) - 120VAC
BLACK (Hot) - 120VAC
WHITE (Neutral) - 0 VAC - Should be connected to the terminal block and grounded to the equipment cabinet via a grounding strap.
NOTE: If the power cord or wires at the terminal block are not color coded, the outer two wires (LEFT and RIGHT) are the two hot leads. The center conductor is Neutral.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Dec 22, 2009 | Dishwashers
Kenmore dishwasher... filled up with water and its lights went off.. no buttons work acts like no power. check the house fuse box - ok ... check the 2 door switch - ok .. checked the thermal fuse - ok ...
Did you check power to the unit? Double check the common and grounds. When servicing I will disconect(unplug from wall) power to the unit. Is it pluged in? Use another outlet(the outlet under the sink may be wired thru a switch for a disposer)even if you need an extension cord. Hope this helps.
Nov 12, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Electricity plug
Here is a little video to show exactly what to do. If you have an outlet to plug your dishwasher into just add a power cord to the connecting wires. Otherwise do as it shows in the video and hook the dishwasher up to a power cable coming from the electrical panel.
May 04, 2009 | Kenmore 1621 - Multiple Color Dishwasher
Kenmore 17459 Free-standing Dishwasher Logo
310 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
