Question about Toshiba Satellite P25-S507 Notebook
Itz a P2509
Can not get power to stay on. after turnN on blue power button lights up, hard disk activity light for a second, three fans turn bout 4 seconds. The fans turn off momentarily, then the 2 outside fans start to spin. When I get lucky i get into bios sometimes it locks up then I go to boot it regonizez my brand new hard drive corertly, but when I try to boot I get stuck in a loop, dianogtist screen checks memory ok , hard drive ok, but earthnet card faulty disconnected cable disabling intel pxi ram, or something like that then it gets stuck in a loop repeating earthnet disconnect cable. Things that help me get lucky, Pulling battery be for booting while running on power supply only. Pressing FN botton & f5 or f1. f5 does screen swithing f1 does security bios unlocking. please Help me
  • 2 more comments
  • Sean Wade Mar 30, 2007
    found a Bios patch from Toshiba 1.60 aaa 10-29-03 to help systems containing the Media center package With Tv
    that hang during reboot
  • Sean Wade Apr 01, 2007
    sorry this does not my problem . Because 1st I have to boot, then when I do & get into Bios & disconnect all erternet & internet hardware I still fet stuck in a loop.
    Although as I posted earlier Toshiba offered a Bios patch to fix ya hang problems for the p25 with media package.
    Still looking to have a successful boot even if was bios. THanks doe says tion
  • artwinning2 Nov 08, 2008
    When i turn on my laptop, it starts up and works for about 6-10 min, but then gets this weird blue screen with some wrighting on it. The computer then shuts off. Could it be a virus or hard drive failure?
  • 24 Answers
Try to disable your eithernet card in bios and see if you still get the error.
Posted on Mar 30, 2007
SOURCE:
I lost the 27208 remote that came with two contractor-installed Hunter fans with lights (incandescent). The fans, lights, & remote have worked fine for 5 years. I purchased a new 27209 remote at Lowes...
If you are trying to use a combination of wall switch and pull chain control, the simple logic in the receiver can't figure out what to do. Try disconnecting all fan power at the source, removing and reinstalling the remote battery, restoring power, and trying all combinations of switch settings and power off - power on operation until you get results (or give up).
Feb 28, 2017 | Hunter Dryers
Inspiron 1521 will not power up
I'd say that you have exhausted your options. You can try to isolate the power on problem by removing your your memory modules, hard disk drive and see if it at least stays powered on. Here is a link from Dell for your laptop's manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1521_Owner%27s%20Manual_en-us.pdf
Feb 09, 2013 | Dell Inspiron 1521 Notebook
Compute turns on, lights light up, and fans move, but there are no beeps or bios showing up.
Computer turns on but no display. This issue is commonly caused by electrical static on the motherboard. Try doing a power drain.
If this computer is a laptop:
1. Turn the computer off by pressing the power button for a bout 5seconds.
2. Take the battery out of the computer.
3. Unplugged the ac adapter.
4. Press and hold the power button for about 30 seconds. (without any power source)
5. Put the battery back in and plug the ac adapter back into the computer.
6. Turn the computer back on.
If this computer is a desktop:
2. Unplug the power cable from the computer.
3. Press and hold the power button for about 30 seconds. (without any power source)
4. Plug the power cable back into the computer.
5. Turn the computer back on.
Thank you for choosing FixYa! have a good one!
Jun 02, 2011 | Computers & Internet
I have a three wire switch blue+black+red for the light on my ceiling fan need to know how to hook it up to turn the light on and off have four lights used to be five but took one out cause the fixture was...
Make sure the power is off.
Connect ALL White wires together -- from the ceiling box, the fan and the lights.
Connect the Black wire from the switch to the Black wire in the ceiling box.
Connect the Red wire to the Black wire on the Fan. That should activate on the first pull
Connect the Blue wire to the 4 black wires coming from the lights. That should activate on the second pull.
The third pull should activate both. To change the order, swap the connections to the Red and Blue wires.
Jan 19, 2018 | Westinghouse Electric Ceiling Fan 3-way...
MY LAPTOP WILL NOT TURN ON
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
If this doesnt work can you hear any fans or hard disk activity when you press the power button?
Jan 20, 2009 | Toshiba Satellite M35X-S349 Notebook
Won't boot. Power light on, No Video Signal message
It's also possible that your operating system has become corrupted. See if there is enough time to boot into safe mode, or choose a boot option to go into the recovery partition.
Have you made any recent hardware or software modifications?
Dec 12, 2008 | Gateway Media Center 610XL PC Desktop
Printer takes ages to process
NV RAM and HD
To initialize NVRAM
1. Remove any installed accessories (for example, a stapler/stacker).
2. Turn the printer off.
3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding
down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and
then remain on. This might take up to 10 seconds.
4. Press the UP ARROW ( ) button.
5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted.
7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron
sequence.
Hard-disk initialization
CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk
initialization only if an error code on the control panel indicates an EIO disk error. Always try
initializing the hard disk before replacing it.
NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see
Menu map and Configuration page). Use the information on the configuration page to reset
any customer-set printer configuration values that the hard-disk initialization procedure
changes.
To initialize the hard disk
1. Turn the printer off.
2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down
the PAUSE/RESUME button until all three printer control-panel lights flash once and then
3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK.
4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
Mar 12, 2008 | HP LaserJet 2420 Printer
Toshiba Satellite P25-S507 Notebook Logo
168 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
