Question about Canon imageRUNNER 2000 Copier
Paper shifts When coping a page I don't get about 1" of the side. It's like the paper shifts.
  • 163 Answers
This is just in addition to techbill. I assume you are copying LTR format. If this happens from the feeder and the glass something you might want to check is the paper cassette setup. Pull the casstette completely out and check the setup tabs on the back of the cassette. Also make sure there is no paper jammed in the back where the cassette slides in. Jammed paper back there will cause the machine to misread it as LTR-R. This usually cases a 2" blank area. Just something else to check.
Posted on Apr 03, 2007
  • 31 Answers
Does it happen both off the copy glass & thru the document feeder or only off the document feeder. If both - check the side guides inside the cassette to make sure they are tight against the paper. If it only happens when using the feeder- the feeder tray needs to be adjusted. There is usually 2 screws under the document tray that when loosened allow for side to side adjustment. Moving the tray should solve the problem if it is only happening when you use the document feeder.
Posted on Apr 02, 2007
Why when I select Glossy in the print settings, the print shifts?
Run this paper from the bypass tray located on the right hand side of the machine.
Try setting that paper type on the copier itself.
Load the paper. Go to the manual paper tray select screen. Select tray 1 and then change paper settings.
Glossy paper also tends to slip in these machines when the paper tray rollers are bad.
Oct 29, 2014 | Konica Minolta Office Equipment & Supplies
I have a paper jam on my very old canon fax machine...Canon Super G3. The paper is held up in the rollers and has can I release the rollers so that I can get the torn piece of paper...
To remove the paper jam, follow the procedure---
1. Open the front cover.
2. Remove the cartridge.
3. Open the face up cover and push down the green paper release levers on both sides of the face up paper output.
4. Hold sides of the jammed paper and carefully move it inward then gently pull out.
5. Remove if any paper bits present near the rollers.
6. Don?t pull the paper upwards but straight between the rollers.
Please check page#62 for details in the manual---
Canon Super G3 Fax
Apr 01, 2011 | Canon Office Equipment & Supplies
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
Replaced a hp 8150 with a ricoh 8200. When
That is the way duplexing works. Both sides of the page are read into memory and then the second page prints followed by the first page after the paper turns around.
Turn you paper stack over so the the 2nd. page prints correctly on the page and the first page should be fine. If it does not, please let me know and we can take some steps to look at the data going to the printer.
Mar 10, 2010 | Ricoh Aficio SP C820DN Laser Printer
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Printer can't receive 250gram photo paper. I get
If you put your hand inside there will be a paper picking Roller (rubber) clean them with the spirit ..
or with the wet Towel ..
which will solve your issue
if still not then follow the paper Jam steps - cleaning the rubbers when you open the rear
1. Turn off the product and unplug the power cord.
2. Turn the product around to access the back of the product.
3. Open the rear access door:
1. Locate the tab on the left side of the door and press it toward the right. The door will shift slightly to the right.
2. As the door shifts to the right, pull the door out slightly to release.
3. When the door is released, gently remove the door by sliding the door out and to the left.
4. From the rear access opening, gently pull the jammed paper out of the rollers.
NOTE: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the product. If all the pieces of paper are not removed from the product, more paper jams are likely to occur.
5. Replace the rear access door:
1. Insert the two posts on the right of the door into the holes on the right side of the opening.
2. Press the tab on the left side of the door toward the right. The door will shift slightly to the right.
3. As the door shifts to the right, push in the left side of the door to lock it into position.
6. Reconnect the power cord and turn the product on.
Jan 03, 2010 | HP PSC 2355 All-In-One InkJet Printer
I want copy from A3 (2*A4 pages) to A4 (landscape)
While coping A3 paper it result in A4 portrait not in landscape which is incomplete.How to manage it?
Feb 19, 2009 | Canon iR 2016i Black and White Copier
this sounds like you have ink on the paper look inside and clean the paper feed rollers with denatured alcahol found at the local hardware store
Jul 05, 2008 | Brother MFC-465CN InkJet Printer
Brother multifunction inkjet DCP770CW. How can you adjust the copy function to cope with pages of pencilled notes that come out too feint. Mike Cornwell
no way. the paper feeder of machine recognices the paper edges. there is no way to compute the exactly positon for different papers.
May 01, 2008 | Office Equipment & Supplies
Not printing properly....alignment
It is possible that the guides in the paper tray have moved?
If they are universal trays (meaning they are not locked down to only use one particular size), they could have easily shifted, causing what you have described.
Try copying using a sheet of paper through the bypass tray, and see if the image is centered. This will at least narrow down the problem to a particular tray.
Feb 05, 2008 | Toshiba 2060 Copier
Canon imageRUNNER 2000 Copier Logo
126 people viewed this question
old marine
old marine
