Question about Dryers
Maytag MDE3500AYW heat selector switch fried
Switch 33002526 is no longer made. This dryer is only 8 years old. It is in great shape otherwise. Can't find this part anywhere. Part 33001640 is for a MDE2600AYW look exactly the same but has one more terminal mark OR(orange?) Will this switch work? It would be an absolute crime to send this perfectly good dryer to the land fill because we cant find a $15 switch. Can it just be wired direct red to black to regular heat? That is all that is used 95% of the time anyway.
  • parkbo_zeus Dec 22, 2008
    I have hit vertually every parts supplier I can ind online. All of them do not carry the part. The would get it from Whirlpool/Maytag if they still made it but they dicontinued it in July of 08.
    I have searchered and called vertually every parts supplier I could find on the internet. All of them do not carry the part but would order it directly from Whirlpool/Maytag if they still made it. The problem is that they stopped making it in July 2008.
    President:
  • Dryers Master
  • 2,651 Answers
  • Dryers Master
  • 8,220 Answers
Well you have 4 wires right? Neutral or N is white most of the time and marked on back side of the switch will be N (might be purple) so that is 1 wire next all you have to do is put 1 more wire to that one and you have heat. Individually tape off the other 2 wires. Make it work in cotton only. or perma press only.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 19, 2008
  • Dan Webster
    Dan Webster Dec 22, 2008
    If the partstore has it then I highly recommend you get it from there. Nice company.
Maytag Gas Neptune Dryer MDG5500AWW no heat
see this causes and fix it. God bless you
Dryer tumbles, but there is no heat
Sep 27, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer does not heat.
If the dryer comes on but doesn't heat, it is probably the heating element. If the dryer doesn't come on at all, it most likely is the dryer's motor.
Sep 18, 2009 | Maytag Dryers
I have a Maytag PYG3200AWW and it won't start.
Sounds like a problem with a limit control switch. Some are manual reset and some are automatic . Not sure about yours. They are located of course, in-line within the wiring harness limiting the amount of heat build-up within the machine. If yours had been running with a stopped up, or patially stopped up vent, (and your limit swithch IS AUTO reset,) then the switch could have been cycling the heat numerous times, over that period, preventing overtemperature conditions. This would weaken the switch because it is a safety device and not actually a cycling device. Also, in the vent exhaust, @ the back of the machine there may be a limit switch. And of course, it could always be the start button..........
Jul 27, 2009 | Maytag MGD6300T Gas Dryer
Maytag sde4606ayw heats up will not tumble when pushing the start button even after replacing a fryed temp. switch.
do you hear the motor trying to run? it could be a belt, or something electrical, door switch could be a option as well
Jun 23, 2009 | Maytag SDE3606A Electric Dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Buzzer will not shut off when load is done
If your dryer also starts without pressing the start switch, then the push to start switch
contacts are stuck in the closed position. Sometimes you can press the button on-off-on-off
quickly to unjam the contacts, otherwise replace switch.
Jan 12, 2009 | Maytag Dryers
Maytag PYE3300AYW Elec Dryer Runs, But No Heat
hello kellygubser,
If you are sure the thermal switch is ok.. have you checked the high temp ( bi metal snap switch) too? Here is a link to the wiring diagram of your dryer. You can see that there are a few other temp switches in circuit of the heating element that would disble it.. Hope this helps
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
171 people viewed this question
Top Dryers Experts
Marvin
Marvin
